Shimming a saya is the prefered method for tightening a katana, wakizashi or tanto in its sheath.
You will need:
- wood veneer edging
- lighter/match
- narrow flathead screwdriver
- scissors
- your sword
Remove these ads by
Signing UpStep 1: Familiarize Yourself with the Saya
There is no need to shim the entire length of the scabbard. The blade doesn't actually contact the inside of the sheath. The only point of contact should be between the habaki (the metal collar at the base of the blade) and the saya.
Visit Our Store »
Go Pro Today »
http://www.musashiswords.com/shop/product.php?productid=37
It's by no means a top of line item. Though it's a handforged blade, the fittings are definitely not 100% traditional and historically accurate. I actually got this particular knife to cut my wedding cake - something I would never do with a high end blade. The shim technique is still useful as a cheap and easy solution that can be applied to any blades that are held in place by friction from the habaki. Cheaper swords are more likely to need shimming in the first place - plus the people reading this instructable are more likely to have mass produced swords than ones using 100% traditional techniques.
