Tilt Activated Switch
It's a 3 position SPDT switch that closes (on) when tilted. Made with 3 pieces of plastic, a washer, and three machine screws + nuts. I made this switch as a hack for a cheap r/c car controller, inspired by the wiimote controlled car.
I just realized, this can also double as a pedometer or a shake sensor
See the Hand Motion Controlled R/C Car Instructable
Step 1Materials and Tools
Materials and Tools
two #8-32 machine screw, 3/4" long
four #8-32 machine screw nuts
one #10-32 machine screw, 3/4" long
two #10-32 machine screw nuts
a sheet of 1/8" thick TRANSPARENT plastic, lexan or acrylic can be found in home depot
a washer, 5/8" wide on the outside, with a 3/8" hole in the middle
a 1-1/2" doorknob hole saw (it's a special drill bit, see picture)
a 1" forstner drill bit (or flat wood bit but i am not sure if it works)
a drill, drill press is best, and some standard drill bits
metal files, a thin round one and a larger flat one
76 comments
1-40 of 76next »
Nov 5, 2011. 9:42 AMdkalaichelvan says:
so basically it works like a normal switch excepy like a see saw.....i want to make one for a project
Nov 27, 2010. 8:23 AMAmit Tulshyan says:
I dont understand wats the use of the ring can anyone explain it to me
Oct 18, 2011. 3:52 AMicsnerdics says:
you tilt the thing, the ring touch the center screw and one of the side screws, that's it, you have a tilt sensor.
May 31, 2011. 8:12 AMJedx says:
Clever! Almost as good as a mercury tilt switch, and can be modified to suit your needs.
Feb 16, 2011. 8:51 AMbertus52x11 says:
This is very smart!
Dec 5, 2007. 3:16 PMNeodudeman says:
It's the same table he uses to chop up his murder victims.
Sep 5, 2010. 8:20 AMhomepago says:
lol
May 14, 2009. 3:16 AMrobot797 says:
i see it is blood
Nov 17, 2008. 10:24 AMKoil_1 says:
...in a word... WOW!
Dec 19, 2009. 9:37 PMastro boy says:
 man this is awesome just what i needed thanks. : D
Jul 3, 2009. 5:24 AManakuron says:
super! what a great idea! and what's best, really cheap. thanks for sharing
Jun 12, 2009. 12:53 AMvlad_tepesch says:
nice idea, thanks
Mar 3, 2007. 7:16 PMhomestarrunner247 says:
so... would it be possible to make a wireless "in-air" kind of mouse with this? that'd be cool! or hang this from a string with a pulley connected to the ceiling for a really unique switch!
Oct 19, 2008. 7:01 PMcasey321b says:
ill work on somthing that would do that ok..
Oct 19, 2008. 9:24 PMhomestarrunner247 says:
that'd be tight!
Dec 10, 2007. 3:29 PMtechnodude92 says:
this kind of switch would make a very crude and jerky mouse(it only has on or off) a better idea for a tilt controlled mouse would be the tube with a ball bearing and a strip of resistive material(like a slider pot). that way it moves faster the more you tilt it.
Oct 18, 2011. 5:31 PMJohenix says:
How about this: Take a round plastic box, like a snuff box, put a metal disk on the bottom so that it not quite touches the edges, securing it with an electrical contact screw in the center of the box and the disk. Take a piece of electricaly conductive plastic foam (Anti static foam used for shipping ICs etc.) and cut a strip that fits around the inside wall of the snuff box. Secure the foam with two electrical contact screws, leaving a small gap between the ends of the foam. Drop in a marble sized steel ball bearing and allow it to roll around making contact between the disk and the foam making a tilt sensing pot or resistor.
May 18, 2007. 6:26 PMNyXx says:
I have had some luck creating a very crude and simple in air mouse using a joystick (this one actually has a builtin tilt sensor) and using a software driver which enables you to use a joystick to controll your mouse functions. I guess doing something like this is easier than learning how to program a microcontroller. Though I guess code for this must be easily findable on the net.
Jan 13, 2008. 7:12 AMbman says:
Whats the driver? I've been looking for something like that forever.
Jan 14, 2008. 1:17 AMNyXx says:
look for something called joystick2mouse: http://atzitznet.no-ip.org/Joy2Mouse3/
Jan 14, 2008. 12:29 PMbman says:
thanks
Mar 21, 2007. 9:49 PMhongkongfong says:
why did you make 2 rings in step 4? i only see one being used... maybe i'm not understanding something.
Mar 25, 2008. 7:09 PMdean-101 says:
does this mean the washer will always be hitting one of the other screws or if you tilt it enough will it be out of contact with both screws
Oct 19, 2008. 7:00 PMcasey321b says:
frank didnt quite seem to understand what you were talking about and no as long as you use a washer that is not as wide as the screws are apart it wont touch and even if it would that would mean you did it wrong and they would always touch from then on
Feb 6, 2008. 3:04 AMQwertyuioLP says:
can u do it wirelessly?
Oct 19, 2008. 6:55 PMcasey321b says:
what do you mean by wirelessly?
Oct 19, 2008. 6:54 PMcasey321b says:
doesnt seem like too much work. i dont see what the deal is with the other guys but i was wondering could i do this with cardboard instead of plastic? ill probly stick with plastic but i was planning on using nails instead of screws and just some how fastening them on the other side
Sep 18, 2008. 5:23 PMootsae says:
Seems like a lot work but, no mercury and it looks great.
Sep 15, 2008. 5:34 PMKydoes says:
Sorry but the solution for all this hard work was created long ago. It's called a mercury switch. ;)
Nov 22, 2007. 3:54 PMhondagofast says:
Is that blood or a stain on the table?
Apr 19, 2008. 11:44 AMHardCoreHacker says:
HaHa That means its a stain?
Jan 9, 2008. 6:51 PMbudsiskos says:
what home depot are you shopping at? i cant find plastic any where except from big manufacturers
Jun 27, 2007. 1:06 AMLiquidhypnotic says:
I'm sorry; I think the last step needs a lot more clarification. As I understand it, the center screw is one pole while either outer screw is the outer pole? And then the washer hangs off the central screw a little bit, and so when the thing tilts to either side a certain amount, then the washer hits one of the side screws, and then the current is conducted through the outer screw, the washer, and the central screw. Is this all correct? Ah, I think I get it. That's pretty damn ingenious! ...I do have it right, yeah?
1-40 of 76next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
116
Author:frank26080115(Frank's Projects)
I'm an electrical engineering student at the University of Waterloo.
