I just realized, this can also double as a pedometer or a shake sensor
See the Hand Motion Controlled R/C Car Instructable
Remove these ads by
Signing UpStep 1Materials and Tools
four #8-32 machine screw nuts
one #10-32 machine screw, 3/4" long
two #10-32 machine screw nuts
a sheet of 1/8" thick TRANSPARENT plastic, lexan or acrylic can be found in home depot
a washer, 5/8" wide on the outside, with a 3/8" hole in the middle
a 1-1/2" doorknob hole saw (it's a special drill bit, see picture)
a 1" forstner drill bit (or flat wood bit but i am not sure if it works)
a drill, drill press is best, and some standard drill bits
metal files, a thin round one and a larger flat one
you could make it more versatile by just using 1 through screw and one bolt that has it's head in the space between the discs. You then would not need to dril additional holes for various switching positions. Just put it in th eright position and tigthen the center screw
http://www.macsimumnews.com/index.php/archive/apple_granted_patent_for_hybrid_low_power_computer_mouse
if somebody can program a microcontroller to out put data like a mouse, i guess it can be done.
