3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tilt Sensor Tutorial
What is a tilt sensor?
Tilt sensors allow you to detect orientation or inclination. They are small, inexpensive, low-power and easy-to-use. If used properly, they will not wear out. Their simplicity makes them popular for toys, gadgets and appliances. Sometimes they are referred to as "mercury switches", "tilt switches" or "rolling ball sensors" for obvious reasons.
They are usually made by a cavity of some sort (cylindrical is popular, although not always) and a conductive free mass inside, such as a blob of mercury or rolling ball. One end of the cavity has two conductive elements (poles). When the sensor is oriented so that that end is downwards, the mass rolls onto the poles and shorts them, acting as a switch throw.
Tilt switches used to be made exclusively of mercury, but are rarer now since they are recognized as being extremely toxic. The benefits of mercury is that the blob is dense enough that it doesn't bounce and so the switch isn't susceptible to vibrations. On the other hand, ball-type sensors are easy to make, wont shatter, and pose no risk of pollution.
While not as precise or flexible as a full accelerometer, tilt switches can detect motion or orientation simply. Another benefit to them is that the big ones can switch power on their own. Accelerometers, on the other hand, output digital or analog voltage that must then be analyzed with extra circuitry.
Basic Stats
These stats are for the tilt sensor in the Adafruit shop which is very much like the 107-2006-EV. Nearly all will have slightly different sizes & specifications, although they all pretty much work the same. If there's a datasheet, you'll want to refer to it
  • Size: Cylindrical, 4mm (0.16") diameter & 12mm (0.45") long.
  • Price: $2.00 at the Adafruit shop
  • Sensitivity range: > +-15 degrees
  • Lifetime: 50,000+ cycles (switches)
  • Power supply: Up to 24V, switching less than 5mA
  • Datasheet
Step 1Testing your tilt
Testing your tilt
Testing your sensor is simple. Put your multimeter into continuity-test mode and touch the probes to the two leads. Then tilt to determine the angle at which the switch opens and closes.
13 comments
Jan 16, 2011. 10:46 AMVick Jr says:
Can this internal pull-up resistor trick be used for other sensors, such as the PIR motion sensor?
Dec 5, 2010. 9:21 PMthedod says:
Me again. Tried the internal pul-up resistor trick (on a freeduino) and it didn't work :(
I wonder: does it work on specific Arduini?
Nov 30, 2010. 11:35 AMthedod says:
Thanks. Especially for the tip about the internal pull-up resistor.
Off topic: the wave shield video is brilliant.
Jul 7, 2010. 7:39 AMduxes says:
Any one has got idea about mechanical tilt sensor which can be used in outdoor?? I need some info for my antenna tilt sensor project.. plz help me....
Feb 22, 2010. 6:33 PMgolddigger1559 says:
 i would like a detailed wiring diagram for that remote conversersion please **eyes real big**
Nov 10, 2009. 7:52 AMlibertyshouts says:
Awesome i want that modded controller
Jul 6, 2009. 4:59 PMReCreate says:
How do you make that diagram in the last step? Is it a vector?
Jul 7, 2009. 1:56 PMgatonero says:
Have a look at fritzing
Jul 7, 2009. 2:05 PMReCreate says:
Ah Now I get it!
Jul 6, 2009. 4:14 PMwestfw says:
Any ideas why are there TWO balls in the sensor?
Jul 6, 2009. 4:58 PMReCreate says:
Yeah, Why?
Jul 6, 2009. 6:24 PMSpiff73 says:
Failsafe? If one gets stuck, the weight of the other will move it?
Jul 6, 2009. 6:26 PMReCreate says:
Perhaps?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
234
Author:adafruit(Adafruit Industries)
All-original DIY electronics kits - Adafruit Industries is a New York City based company that sells kits and parts for original, open source hardware electronics projects featured on www.adafruit.com ...
more »
