3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tilt activated LED glow cube
I can thank Instructibles for inspiring me to make various LED projects for my family and friends. Now it's time to publish my first instructible on my latest and favorite project so far.
This instructible will show you how to quickly and easily build your own tilt activated color changing light cube!
Step 1What you'll need
What you\
The materials I used are:
1) 3 5mm rgb slow fading LEDs (look on ebay. I found 50 for $12)
2) 1 baseball display box (hobby store, $2.99)
3) clear glass marbles (hobby store $.99)
4) 1 9v battery holder (Radio Shack, $.99)
5) 9v battery clip (Radio Shack approx $3 for 5)
6) 1 sub-mini momentary switch (Radio Shack $1.50)
7) soldering iron
8) glue gun
38 comments
Feb 22, 2011. 7:32 AMSky Woulf says:
Verry Nice!
now if i could wire up a pressure switch it would turn on when ever i set something on it, oh yea; also some sort of randomizer circut and you could have a different color every time you set your glass on it!
Dec 18, 2010. 2:25 PMzcrank says:
To the author, yes "I" was confused. I wanted to see a tilt switch activate the circuit. I didn't get the part of the marbles pushing on the momentary switch to complete the circuit. I see the switch in the 1st picture and it just did not relate. For some reason I can't see videos from Instructables. Thanks for clearing that up. BTW, I asked because I really like this Instructable and wanted very much to make one as a Xmas gift. Very cool and simple, nice!
Dec 18, 2010. 11:10 AMPirondizzle says:
Do you think this could be made with some old Christmas tree lights instead of the LEDs?
Dec 10, 2010. 6:12 AMstall3 says:
Thanks for the resistor link. I want to build this project with a resistor. What resistor part do I need, and where do I put it inline with the LEDs? I can read a million sites with reistor basics, but specific to this build, what do I need specifically? Thank you very much. This is a very cool project. I hope to get my kids involved too.
- s3
Dec 10, 2010. 11:26 AMstall3 says:
Great. Thank you. I really appreciate the resistor color help on that site. I like the diagrams on this site a bit more for us noobies: http://ledcalc.com/
Can anyone find some reasonably priced micro, non-mercury tilt switches that don't ship from overseas? Sometimes waiting for a shipment from China hurts too much.
Thanks again. This cute little build has me hooked now :)
-s3
Dec 10, 2010. 9:45 AMzcrank says:
(removed by author or community request)
Nov 4, 2010. 12:39 AMzcrank says:
Jul 19, 2010. 4:05 AMcrayc says:
I wanted to make a table out of this. Out of plexiglass. Is it possible to make like a bar table. thanks
Jul 19, 2010. 6:15 AMcrayc says:
I have a few problems, i do not know how to solder, not a big issue. Should not be a problem. but programming it would be a problem. http://www.creativenightclubs.com/liquidfloor.htm scroll to the bottom of that. I was hoping to go for something similar to that. Thinking of frosted plexiglass.
Jul 19, 2010. 1:06 PMcrayc says:
hmm, well i was thinking of opening a bar, i will experiment on that floor now. thanks http://www.disco-designer.com/NIGHTCLUB_PLASTIC_FURNITURE_CUBE_TABLES.html they have those cubes there. Those look fairly easy to make and won't cost you an arm and a leg to purchase.
Jun 30, 2010. 9:55 PMgmxx says:
You are running the leds in SERIES. Serial is a data transfer protocol. Anyways, cool project. future upgrade would be to get one of the mercury tilt switches. that way, you're not relying on something as mechanical as that. Frys has them for about a dollar or so. the dollar tree tilt lights should have them as well. I believe that things should require the least amount of mechanical movement, but thats just my opinion.
Jul 1, 2010. 3:56 AMgodofal says:
maybe even better to use a roll-ball tilt switch, since those marbles could crush the container, spilling the mercury, wich isnt a good thing :D and btw, i thought those things weren't being made anymore?
Jul 1, 2010. 3:30 PMgmxx says:
The roll ball type would work as well. Im not sure about availability. i know the frys i frequent has the mercury switch type. YMMV
Jul 4, 2010. 2:34 AMgodofal says:
where i come from, the mercury isnt available at all, becouse it's not enviromental-friendly, should it break...
Jul 4, 2010. 10:40 AMgmxx says:
Yeah... Either way, there are tilt switches available.
Jul 11, 2010. 10:42 PMGakki says:
I bet this would be really cool combined with that holocron cube posted a few years back.
Jul 2, 2010. 1:40 PMRedfrk says:
Cool project! The diodes I got have four pins on the bottom. I am an LED novice, so I'm wondering if someone can explain the four pins to me before I start soldering. thx!
Jul 7, 2010. 10:23 PMgmxx says:
Is it an RGB led? these leds combine all the colors in one package, and allow you to select a color. the 3 leds control the 3 RGB colors and one leg is ground or positive.
Jul 4, 2010. 2:33 AMgodofal says:
it's a superflux LED, where did you get them? just find out where u've gotten em, look up for a datasheet or something... if you cannot find one, just take a 3V coincell, and try different options, in the end ul get the right 2 then.
Jul 8, 2010. 5:34 PMRedfrk says:
hey guys! thanks for the responses. I finally found something that explains what they are. Yes, they are RGB LEDs, but I don't think they glow with all three colors. I got them from Radio shack and they were more expensive than the LED's listed here. Found out that each color the LED produces has it's own anode leg. I ended up finding the right LEDs online. I'm getting a box of 50 for $8. I'm looking forward to putting a bunch of these together as unique gifts.
Jul 9, 2010. 6:01 AMgodofal says:
yeah, ebay rocks, u buy stuff right out of the factory, wich is REALLY cheap, compared to retail sellers... some online shop i used to order from charged €1.20 or so for a regular blue LED, but if u look around on ebay, u can get 1000 of em for 20bucks, making it about $0.05 per LED...
Jul 1, 2010. 7:51 AMzascecs says:
Neat idea! This is really good, but could we also see a video of this in action?
Jul 1, 2010. 1:56 PMzascecs says:
Looking awesome!
Jul 1, 2010. 3:53 AMmario59 says:
Ciao! You've got a NICE, CLEVER & NEAT idea for a gift! I *LOVE* easy things and this is one of them! I wonder where I could buy that box... Where you find it? Also I think the crystal clear marbles do a grat job, but maybe ONLY A FEW of coloured one can add something... Do you have a short video of the working thing? Compliments and CIAO ! ! ! Mario ;-)
Jun 30, 2010. 11:54 PMzack247 says:
kind of reminds me of those water filled pyramids with the little marbles inside. great project!
Jun 30, 2010. 7:49 PMeripe says:
Nice idea. I suppose you could user Christmas lightning too.
Jun 30, 2010. 2:37 PMrichard_redryder says:
Perhaps it is useful to also add resistors, so the LEDs do not burn out at some point
Jun 30, 2010. 3:36 PMrichard_redryder says:
This site explains it: http://led.linear1.org/why-do-i-need-a-resistor-with-an-led/
Jun 30, 2010. 4:26 PMChrysN says:
Ooh pretty!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:asporkable
