Introduction: Timber Workbench
Welcome to the Manliest Workbench Build Ever!
Step 1: Locate Wood and Begin Cutting
Using an Alaskan Chainsaw mill, we built a jig to assist with the first cut, to remove the top rounded part of the log. I wanted planks and legs for the workbench that were way bigger than anything you could get at Lowes or Home Depot.
The poor mans saw mill is adjustable, so for the second cut, we dropped the depth to 8".
Step 2: Making Legs
Initial length of the legs was 48".
Step 3: Planks
I first used a belt sander on the planks to get rid of the chainsaw cut marks, but then decided I wanted a more 'rough' look so I sandblasted the top surface. The sand will blast out the softer wood and leave the grain, which is harder and more resistant to the sand.
Step 4: Back Board
Used the router again and routed in two parallel recessions for the two power strips I bought.
The power strips required some modification because the pre-wired plug came out the end and I needed it to come out the back of the strip... But that's Another Instructable!
Step 5: Bench Top Assembly
There might have been an easier way to join the two planks, but I used a 1/2" spade bit (12" length attached to a 12" bit extension) to bore horizontally through the planks, starting from the rear. I intentionally stopped approximately 4" from the front of the front plank. Working with the planks upside down, I approximated the location of where the bore hole was, and used a router to create a 2"x2" hole. That connected to the drilled tunnel.
I unfortunately didn't take any pictures of this part of the assembly, but I used 4 pieces of 3/8" all-thread, about 18-20" in length, placing two fender washers and a nut on the all-thread in the routed hole. After drilling out matching holes in the backboard, it was placed on the all-thread and secured with two fender washers and a nut. One person can hold one of the nuts with a wrench, and the other can use a ratchet to tighten the rear nut, drawing the two planks and the backboard together. The all-thread were spaced out about every 24 inches along the length of the bench.
After assembling the work surface, it took an extra few hands to safely help me flip the work surface. Then using sawhorses and more help, assembled the legs in position for a mock-up. I decided the 48" legs were way too high, so I trimmed them down to 40" with the chainsaw.
Step 6: Final Assembly
With the bench moved back I to the garage, the legs were added with it in its final position. 2 7/8" HeadLok screws were used to affix sturdy right angle braces to two adjacent sides of each leg.
Chrome diamond plated power strips fit in pretty nice.
Also added another black pipe feature, this holds the shop towels.
Step 7: Shore It Up
You can see from this picture of the underside, there were some gaps. I don't own the precision saw equipment that can handle the size of this timber, so a chainsaw had to do. There was a little bit of a wobble and I wanted the bench to have a more Industrial look so I braced the rear legs to the underside of the bench with 2" black pipe bought down at the plumbing store. What you see are: a 12" section of pipe, connected at each end by a 45 degree ell and a floor flange.
On the front I decided to get fancy. I designed a swivel stool that hangs from the underside of the bench, and is connected to the leg at a right angle. The wooden bench seats were pre-fab you can pick up at Lowes.
Finally, added the foot rail across the front. It's set out further from the bench on the right. Due to the curve of the log, the right front leg started further back in.
Step 8: Final Touches
At the end, I still had to use a few shims to stop the wobble. Also, due to the drawn out nature of this project (8 mos) one of the bench planks warped a bit, making the work surface a little unlevel. This is my first project with non-Lowes acquired wood so there's some more learning to do. Perhaps the wood would not have warped if I would have built the entire bench immediately, or dried it in a kiln. (Read that Instructable).
Also, I treated the wood with some stuff called Bora-Care, which kills any critters in there. There were definitely some pine beetles because I found larvae several times after discovering sawdust underneath one of their bore-out holes. The worm holes add a nice touch though.
Not sure what's up next for the bench. I'm thinking about distressing it with chains, files, ball peen hammer and the like. Then distressing it with motor oil in some spots or different shades of stain... Lots of methods out there that I've been reading about.
Thanks for checking it out!
