Step 5Final test and limitations
Ice melting is boring, so I made sure it was a quick frame rate.
What can you use this for?
Limitations
Ok, so you get what you pay for sometimes. If you went with a manufactured intervalometer, you would get a accurate interval setting. This isn't quite so accurate unless you put a knob on it or something. There is also another slight problem. The camera counts away or a desired length, the "off" time, and then fires off the shutter, the "on" time. It seems that this "on" time can sometimes be too short for the camera to register. Because of this, it sometimes misses pictures. As long as this happens not too often, no big deal I guess. There has to be a solution to this in the circuit that can extend the output pulse, but it's way over my head. I welcome your help on this problem.
Also the buttons don't work while the circuit is on. It would be nice to focus or take extra pictures while the timer is running. Any ideas on that are welcome too.
See herehere
Someone correct me if I am wrong please but I believe the output charges the .1uf cap with an RC time constant of 3.3ms (.1u x 33k=.0033).
So therefore a 200k resistor in place of the 33k would give you the 20ms shutter time. (.020 \ .1u=200k).
This is an excellent write up. I will build this soon. There will be a few addons but the basics of this are very sound.
With very little modification this could be made to focus before shuttering also. Even if you had to go as far as to add a sample and hold circuit, but I think it can be done with minor modifications to the circuit with just capacitors and resistors.
