3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Time lapse enclosure for smart phones
  • last photo ←
How to build a weatherproof enclosure for taking time lapse photos using a smart phone.
This enclosure is not 100% waterproof but can reasonably survive rain while protecting your smartphone.  This enclosure was used over a 5 day period including two days of rain and easily kept the camera dry.
Using this enclosure, you can take time lapse videos like this.
Step 1Parts you will need
Parts you will need
1.  Two pieces of plexiglass, each slightly larger than the smartphone
2.  A few scraps of 1" thick wood or plywood
3.  A smartphone with a time lapse application and built in camera
4.  Small tripod
5.  Charger cord for the smartphone
6.  Miscellaneous screws
13 comments
Oct 22, 2010. 2:26 AMRanie-K says:
Nice instructable!
Here's a box I made for my PowerShot for the same purpose:
http://www.wikihow.com/Make-a-Weatherproof-Camera-Box
Oct 28, 2010. 11:24 AMShiftlock says:
Much simpler, and just as functional. I made an even simpler version which basically was nothing more than a ziplock baggie that was taped to a block of wood. If you can prop up the phone/camera, all you really need is a waterproof bag, as long as you make sure it's stretched tight across the lens. I found that some brands aren't clear enough, though.
Oct 29, 2010. 5:52 AMRanie-K says:
Yeah -that works perfectly fine for most camera's but mine has a moving zoom-lens that would freak out if a plastic bag was stretched taught over it.
Oct 29, 2010. 7:31 AMShiftlock says:
You are absolutely right, and that was the only problem I had with the plastic bag solution using my Casio Exilim. My fix was to use double-sided tape to attach the plastic bag to the front-most lens segment, so the zoom lens can move in and out unhindered, and the bag moves along with it. It's not an ideal solution since I have to re-tape the bag to the lens every time, but doing that is still a lot less work than constructing a permanent waterproof housing. Then again, taping your camera onto a ziploc is a less classy, so to each his own. *shrug*
Oct 27, 2010. 1:27 PMrrrmanion says:
really good idea, but i would have made some adaptations
1) add another rectangular section to use as a lens hood, eliminating lens flare.
2) made it so the rain drops on the outer part didn't interfere as much.
3) used a battery to recharge the phone, instead of the generator.
Oct 29, 2010. 3:54 AMrrrmanion says:
yeah, the best thing to do would be to use some strong glass, ad clean that intensely, and certain filters might have been useful, but it's more difficult with that on a phone. my dad's cousin does this sort of thing, only about 50 times more advanced, using a D-SLR, A laptop, an industrial timer, a solar panel and a battery,
this allows him to create a day by day time-lapse of long building projects, these images are emailed to his clients every day, using a 3g adapter, and then they can be used in court cases if there is any delay, these devices can be fitted on rooftops with minimal installation, are protective housing which makes them look not to unlike a speed camera, and it's all quite advanced so cost thousands
Oct 24, 2010. 7:34 PMpuzka says:
Hmm, where are the Koalas? :-)
Oct 25, 2010. 3:11 PMpuzka says:
cool, we have Koalas living on our property.....
Oct 25, 2010. 8:18 AMDiGiTALMADDOG says:
nice project - what app did you use on your iphone -- thinking i will do this ( when i get my old 2g back from my brotherinlaw when he gets a new phone ( soon i hope) ) -- would be nice to have this capture and upload to a website
also the first few days did you eliminate the nighttime sequence of pictures or did you let the phone take pics all night long
thanks for the info
Oct 25, 2010. 12:51 AMchndt2008 says:
Charming! I have been a phone holder
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Krizbleen
