3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Time lapse movies
Time lapse movies
Connect a camera to your computer and install some free software to generate cool effects from scenes around you. Ordinary events become fascinating as their time gets speeded up. For example, this sunrise:
Step 1The hardware
The hardware
You will need:
1. A computer
2. A Camera
Allow me to elaborate. You are reading this on a computer, so you are evidently in possession of item no.1. Item 2 requires explaining further. I do not mean those black light tight boxes with a lens at one end and film at the other end, I mean one of those light tight boxes with a lens at one end and a CMOS or CCD sensor at the other, which can be connected to your computer, whereby you can see the images on your computer screen.
Allow me to interpret the bit of verbiage above. You need either a webcam or a video camera and a capture card.
If you have a webcam on a USB port, you are limited by the length of your USB cable. You will have to carry your computer around, or bring your project to your computer.
If you try for the video camera and capture card solution, this gives you more freedom as the video cable between the camera and the capture card can be any reasonable length up to a few tens of meters.
Yet another solution is a digital still camera with a memory card inside it, and no cable at all between the camera and computer, but right now I shall not go up that, high quality and resolution (and cost!) route.
People who know loads will tell you that by this route, you are limited to fairly low quality movies, below 320x240 or so. That is okay. You can amuse yourself and your more easily amused friends with movies of fairly low resolution.
You have to remember that movies of high resolution need more expensive equipment to make, take up more space on your hard disk, and take up more bandwidth when you try to share them with your friends.
I'm trying to keep things simple and cheap.
That big round thing is a USB Webcam, and the other two are CMOS video cameras. I have used upto 25 meters of four conductor ribbon cable (ground, +12V, video and spare) between camera and capture card with no ill effects.
13 comments
Mar 11, 2008. 4:20 PMGorillazMiko says:
Cool. I've always wanted to do time lapse, seems very hard though...
Jun 29, 2008. 12:14 PMmaslo says:
Hi, I made a small app for capturing images from a USB webcam and putting them together into a video. All you basically need is a webcam and that application. Check it out: Perios, the time lapse lover's tool
Note: since I am not a professional programmer, there are some bugs in Perios which you may encounter. But for me and many other people it workes fine :) Anyway, I am planning to spend some time fixing the bugs on these holiday.
Sep 3, 2011. 1:34 PMjw. says:
Hi Maslo, Thanks for the software... I have not tried it out, but looks very promising...
Oct 13, 2010. 4:16 AMjekan777 says:
Jun 5, 2009. 6:23 PMemdarcher says:
do you have to use windows? or can you use mac os x? because I only have mac os x
Mar 11, 2008. 4:56 PMphant0m_sp00f3ra says:
Dude Your Pc Rocks, u just took apart the case?
Dec 31, 2008. 7:18 PMcateddy says:
Nice instructable. After reading through your instructable I thought that I would try my luck. I just did the camera and put a link to your instructable for the software. http://www.instructables.com/id/Camera_for_time_lapse_pictures_made_easy/
I spent 2 days putting it together out of junk that I had lying around. Chuck
Mar 12, 2008. 7:36 AMsideways says:
I think leaving things out looks cool. My house is super dusty and the airflow concentrates the dust inside the case. I could keep it cleaner by just leaving everything out. Right now I have swiffers taped over the front bezel to trap some of the dust. It looks like crap, heehee.
Dec 31, 2008. 7:12 PMcateddy says:
Hello Sideways. You might want to check one of my instructables. I got a couple for removing dust. Here is a link to one of them. http://www.instructables.com/id/20x20_fan_with_air_filter/
Jun 25, 2008. 9:16 AMseej says:
great work! If you get something you feel is exceptional, submit it to the timelapse film festival in NYC. www.t-minus.org (full disclosure: I organize this) seej
Mar 10, 2008. 12:03 AMmunchman says:
Like it. BTW y doesn't your pc have a case?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
70
Author:neelandan
Employed as an Engineer in Electronics. Interested in building small circuits around tiny chips (the electronic kind).
