Introduction: 'Time to Get Out of Your Chair' Alarm
This is a device that warns and sets off an alarm when you've been sitting on your chair for too long, reminding you to get off of your @$$ and get some exercise! It's the Pomodoro Clock of Chairs, one chair to rule them all!
Working as a software developer as a day job means I am almost always glued to a chair. Many older people suffer from back problems due to the nature of the job. I have created a mechanism that may circumvent this problem by detecting how long you've been sitting on a chair and sounding an alarm if you have been there for too long!
Step 1: BoM
* Photosensor
* 10kΩ Resistor
* Jumper Cables
* Arduino
Tools:
* Soldering Iron
Step 2: Solder
Since I wanted to go breadboard-less we'd need to solder the resistor onto one of the pins of the photosensor (call this pin 1) since the photosensor will use a voltage divider to relay input signals to the Arduino.
Step 3: Connections
Follow the table below for the connections between the I/Os and the
| I/O | I/O pin | Arduino Pin |
| Photosensor | 1 | A0 |
| Photosensor | 2 | GND** |
| Buzzer* | 1 | 9 |
| Buzzer* | 2 | GND** |
* Order of pins do not matter for the buzzer
** The Arduino board has at least 3 GND pins
Step 4: Code
* 'Get out of your chair alarm!' * By TechMartian *
/cosntants for the pins where sensors are plugged into. const int sensorPin = 0; const int buzzPin = 9;
unsigned long minute1; float time1;
//Set up some global variables for the light level an initial value. int bright; // initial value int lightVal; // light reading
void setup()
// We'll set up the LED pin to be an output.
bright = 900;
//we will take a single reading from the light sensor and store it in the lightCal //variable. This will give us a prelinary value to compare against in the loop
}void loop()
{lightVal = analogRead(sensorPin); // read the current light levels
//if lightVal is less than our initial reading withing a threshold then it is dark.
if(lightVal < bright)
// reset the timer, person began to sit down
minute1 = minute();
} else // otherwise it's bright
hour1 = -1;
minute1 = -1;
unsigned long minute = minute();
if (abs(60 - minute + minute1 )>20){
// time to stand up
while (lightVal < bright) { // still sitting
tone (buzzPin, 1000, 100);
delay (100);
noTone(buzzPin); }
Step 5: Setup
Place the photosensor at the back of the char where you won't sit on it, but will be blocked off of the light when you sit down.
Step 6: Enjoy!
Enjoy your lengthened and healthier lifestyle!
Live long and Prosper!
