Introduction: Timmy Green, My Homebuilt Delta Recumbent Trike.
Picture of Timmy Green, My Homebuilt Delta Recumbent Trike.
This is my Green & Lean HPV, (Human powered vehicle)
It is made from a combination of parts available at home right from used computer chair to a kid's outgrown bicycle.
The goal of this project is to promote Green Living in Malaysia to create the awareness of Global Warming caused by excessive noxious emissions and how we can do our part to help the Environment from further depleting through Cycling as one of our mode of Commute.
 This HPV is designed with only 3 gearing system (initially and upgraded accordingly) for leisure Cruising, Hill climbing and  Down-hill riding. Gear ratios were specially selected for a most efficient use of our Human Power, roughly 1/8 of an Horsepower.
Average speed attained with a cadence of 70 is 28km/hr distributing your weight evenly on a sponged seat ergonomically              position for a relaxed ride relieving pressure points on sensitive parts.
Apart from this it can also be used for muscles toning up & burning of Waste cholesterol as you pedal.
Step 1: Lighting
Picture of Lighting
Lighting is supplied through a Solar Charger attached on the front fairing. It charges 2 AA rechargeable alkaline batteries during the day. A six hour exposure to the sun will supply lighting to a 0.5Watt high Intensity LED front light and a rear LED light for 10hrs continuous use.
Step 2: Brakes
Picture of Brakes
Brakes are Front: Hydraulic disc on Suspension Front Fork and Rear: Simple Y pull for simplicity.
Step 3: Steering
Picture of Steering
Steering is positioned at an ergonomic location turning like a normal bike without a Tiller effect swaying the handlebars. This is accomplished using timing gears and linking them using chain with a chain tensioner.
Step 4: The Frame
Picture of The Frame
                      Design of the frame is from a 20” Mountain bicycle frame extended using a 11/2” diameter pipe and reinforced with ¾” pipes between chain-stay to form a triangle  structure extending to the rear to take vertical and side twisting load when taking a sharp turn.The 3/4" tube between the bottom Triangle is for a Rider's weight exceeding 100kg and can be omitted if Rider is below 100kg.
Step 5: A 20” Front Wheel Combined With 2 Sets of 26” Wheel
Picture of A 20” Front Wheel Combined With 2 Sets of 26” Wheel
             A 20” front wheel combined with 2 sets of 26” wheel for the rear is decided to have a low front and a 7” ground clearance from seat creating a low Crank position for ease of going up & down.
Step 6: Only 1 Front Derailer
Picture of Only 1 Front Derailer
Only 1 Front Derailer is used for gear shifting on the front triple Chain ring with standard 24,36 & 44 teeth driving a standard 18 teeth Freewheel cog. A Rear Derailer is used midway to act as a Chain Tensioner.
The Rear Axle is linked to the left Rear Wheel through a 1:1 Final Drive set up using 2 standard 18T Freewheel cogs.
Another 18 teeth Freewheel is used on the Rear drive wheel. No Derailer is fitted to ease tire removal during puncture.
Rear brake is only on the Right rear wheel to evenise wear & tear of driving & stopping on opposite tires.
Step 7: How to Build the Drive Shaft
Picture of How to Build the Drive Shaft
Take a look at a good quality Steel rear wheel hub.
Get 2 units of those and cut it at somewhere in the middle.
Get a a thick tube /pipe of similar diameter with the Outer diameter of the hub.
Mine was about 5/8" diameter and 12" in length.
Weld this tube extending the middle of 2 precut hubs .Ensure that it is cylindrical as possible.
(Note: Ensure that the threaded portion of the hub is used to screw in a Freewheel later).
Next Extend the Inner threaded shaft with similar diameter steel rod leaving 3/4" extending the outer hub race.
Put back all the bearings and tighten the hub cone to only move freely!
You have now extended a Hub cone assembly without affecting the fit & function.
Step 8: Seat Position
Picture of Seat Position
 Seat Position is premeasured and decided during frame length development to cater for a kid and an adult. It is made adjustable within this range.
Step 9:
Picture of
A Givi 45 liters trunk box is fitted at the rear for luggage. A space of 12” from the back seat to the box is reserve for placement of batteries to convert it to a EV (Electrical Vehicle) should there be a need!
Step 10: Finally My Completed HPV, Timmy Green!
Picture of Finally My Completed HPV, Timmy Green!
Finally my Completed HPV, Timmy Green! A green human powered Vehicle with a low Center of gravity capable of 45km/hr on a level terrain.
Design & build by a Malaysian for Malaysia! Malaysia Bolih!
Im planning to cycle from Kedah to Johor covering 800kms from North to South in 10days to promote Green if I can get enough Sponsers.
My goal is to create awareness of Global Warming in Malaysia and to be the 1st Malaysian to cycle a homemade Recumbent promoting Green Living through Cycling as one of our commute to reduce Carbon Footprints!.
Step 11: Timothy Wooi, 20C,Taman Bahagia,06000,Jitra, Kedah, Malaysia. Emai: Timothywooi2@gmail.com Hp (Malaysia) 019 4514007
Picture of Timothy Wooi, 20C,Taman Bahagia,06000,Jitra, Kedah, Malaysia. Emai: Timothywooi2@gmail.com Hp (Malaysia) 019 4514007
From the desk of Timothy Wooi, 20C,Taman Bahagia,06000,Jitra, Kedah, Malaysia.
Facebook: http:// facebook.com/timothywooi
Email: timothywooi2@gmail.com  (old email: timothywooi@gmail.com)
 Timothy Wooi a Certified hands on TPM Lean Facilitator / Kaizen Specialist with 28 years of          working experience is also a DIY handyman who loves outdoor activities & adopt Green living.          He builds most of his stuff by recycling idle resources to eliminate waste and help conserve the environment He develops Tim’s Waterfuel, a HHO generator that suppliments gasoline usage in automobiles whilst producing cleaner emission towards a greener environment.
Step 12:
savageeuge (author)2014-12-18
Where did you get the seat and springs from?
Stumanchu (author)2014-04-30
beautiful
fluteguy (author)2013-09-18
Super design!!!
What seat did you use?
Thanks
Kristo_ (author)2013-08-24
Hello mister Timothy Wooi,
As I live in the most traffic jammed european city and as I'm also thinking about a more sustainable way of moving , some friend and I want start to work over a project of covered tricycle with electric assistance (because of the climate). In looking for some interesting ideas, I have been blowed away to discover your creation.
That's really amazing ! Congratulation !
Can you send me some information about this? I'm curious to know how much it has cost to you to build this? And how long? What are the size and the weight of your trike? You talked about a triple system of gear. Can you explain it to me? And finally, do you produce this trike and plan to sell it in Europe or only in Malaysia?
I'm really happy to discover your work and wish you the best for your project.
Kind regards
Kristo
loafers (author)2012-06-10
Wow, this is truly well done. I've got a bunch of great old bikes under the house from when my brothers and I were growing up, they're just collecting dust these days. *chop here, weld there* I have an idea.. Thankyou very much Timmy for the idea and the steps, your trike looks much better than most $2500 Recumbent Trikes I see, and being home built, it's just even better! Good Job Mate, Worth 5 Stars
jerropa (author)2011-09-08
very inspiring
alexwelton (author)2010-06-01
how long did it take to make your homebuilt delta recumbent trike?
Timothy Wooi (author)alexwelton2011-08-22
I took me about 2 weeks from design to spray paint.
erice1984 (author)2010-03-11
Where did you get this HHO kit from?
Timothy Wooi (author)erice19842010-03-11
I build it from my workshop using material available from hardware shop.
It is retailed at RM470  per kit in Malaysia.
Cheers,
Timi
sterlingss (author)Timothy Wooi2010-03-12
hi would like a link or some info thanks a ton
Timothy Wooi (author)sterlingss2011-06-01
Please og on to https://www.facebook.com/Tim's Waterfuel
letsgoharry (author)2010-03-11
Hi Timmy
I drive around North-, Central- and South- America
About:
"if I can get enough Sponsers"
make it like I make
But a sign on your Trike, where you write on it what you make and where you go and following sentence:
SUPPORT
$ 1 for 1 Mile
Belief me it works... not much but just enough what I need for Food etc.
Or make a (Free) Website and there you make the same
Look my Website:
http://letsgo-harry.weebly.com/
I whist you good luck on your journey
GOD bless You
Harry
Timothy Wooi (author)letsgoharry2010-03-12
Hi Harry,
TQ so much for your advice especially on getting sponsers.
I will follow your advice to put up a sinage what you make and where you go and following sentence: SUPPORT $1 for 1 Mile.
Still do not understand on what you make means here.
Im not good on the free web thing and will proceed with the sinage 1st.
Many tks,
Tim
letsgoharry (author)Timothy Wooi2011-05-29
Hello Timothy
I start in 2 days ( 1. jun 2011) my Velomobile-Expediton around the world. See my Facebook where I have a lot photos of the preparation for my LEIBA classic "Explore" Velomobile. And on my Website, where you see the aproxomatly "Route"
God bless you
Harry
Ps
To YOU Reader
Add me as friend in Facebook, you are wellcome
facebook.com/letsgoharry
MaximusPsychosis (author)2011-05-20
This is something I've been looking to do, but i want it to go to both the rear wheels; using the gear cassette onto the jack shaft, then chain it to both rear wheels, using the rear wheels freewheel as its own differential (go left, left wheel gets all power, while the right goes faster, and freewheels, and vise versa)..
on the other hand, do you notice the right wheel dragging when accelerating or turning?
ANDY! (author)2010-11-04
sweeeeeeet.
tweakinreaper (author)2010-10-22
what about adding an electric motor and some batteries to the wheel thats not foot driven? i thought adding a wheel with multiple size sprockets like from a multi-speed bike to be able to change your ratio based on weight of rider/load weight/ incline grades. with that wheel and slots to adjust alignment of motor. unless you can use the gearing system from another bike to change gears on the fly but i would be worried about chain alignment. be great trike.....wish i had acess to a welder.....one day......one day
zcshiner (author)2010-10-18
How did you paint this? It it power coated or just spraypaint?
mrlunna13 (author)2010-06-03
SWEET TRIKE!!! That's a very nice recumbent trike! I have a "Brike" recumbent trike that I kinda steampunked. But this trike is a killer! Great job.
Mr. Lunna Xlll
Timothy Wooi (author)mrlunna132010-10-08
Hi Mrlunna13,Many tks for your proactive encouragement.This bike is built around 3 bikes that was idling as my kids grew up!
Tks, wooitimothy@gmail.com
abadfart (author)2010-09-10
nice im more of a tadpole guy
Timothy Wooi (author)2010-08-04
Anyone wants to upgrade a shotr reach Caliper racing type brakes! Need to use smaller wheels on standard fork? Attached my modificatiobn. facebook.com/album.php?aid=2072880&id=1157253986&l=033c1b2dda
https://www.facebook.com/photo.php?pid=31657948&l=d9f98ede45&id=1157253986
its amazing
RayKenn (author)2010-05-25
Congratulations on this excellent work!  Thanks for sharing it.
Timothy Wooi (author)RayKenn2010-05-25
You are most welcome.
Now collecting dimensions to post my 2nd Instructable,Tim's 2 to 3 Wheel Conversion kit to enable Everyone to Cycle right from Special kids to adult with ballabnce problem.
Email me timothywooi@gmail.com for pictures of prototype.
kube60 (author)2010-04-26
Maybe a stupid question here, but when you say pipe, do you mean like iron water pipe like from home depot or did you use actual tubing? Don't mean to nitpick, just need to know for my build.
krelyea (author)2010-04-09
 Timmy, an excellent trike, has given me solutions to the problems I encurred trying to build my own.  But I have one question,  Where did you get or did you manufacture the fairing?
Once again, thanks for the ideas and thanks for going and keeping green.
Timothy Wooi (author)krelyea2010-04-09
Hi Krelyea,
Tks for your proactive comment.
In building this trike,recycle is my my focus,thus all parts and materials are taken from idle materials unless I need a specific shape/design which I need to custome make.
The fairing is taken from a stock Suzuki 100cc Scooter which cost about  Rm 50( USD13) new. Take a look at front fairing from a motorbike shop and work around that5 to suit.
Neccessity is the Mother of Inventions!
Creativity is the Father of Solutions!-Timothy Wooi
la3bna (author)2010-03-11
Can you make an instructable for the HHO kit ?
It would be really nice
leepinlarr (author)la3bna2010-03-20
 I got real good plans from www.smacksboosters.com
good instructions with details
Timothy Wooi (author)la3bna2010-03-13
Dont worry buddy,
I will do my best to find time to write an instructable on how you can build a HHO generator using available materials at local hardware shops.Its basically a grade 316 S/Steel Spiral design HHO generator that Im trading to finance my Green projects..
All these materials were specially selected from local hardware around the globe to be user available!
Im still struggling between prototyping green gadgets,building bicycles,planning community work helping to build toilets in the interior and also trying to get sponsers to finance my ride to promote Green.
Cheers,
Tim
Timothy Wooi (author)la3bna2010-03-12
Hi,
Yes but later as now working on a Wind/Solar Generator to power my Computer.
Just posted a copy & paste instruction on a hho.
Tried copied the write up but the pictures did not copied somehow.
Cheers,
Tim
dwrenne (author)2010-03-11
Nice job. Using a front derailer is a sweet innovation and using the rear derailer just for tensioning is clever. Any reasons why you didn't decide to drive both rear wheels.
The Wapusk (author)dwrenne2010-03-11
The issue with supplying power to both rear wheels is there is no easy/inexpensive  way to construct a differential.  Without which both wheels would move at the same speed as each other reguardless of what was required of them.  When cornering the outside wheel would need to spin faster then the inside wheel, as it travels a larger diameter curve, and would scrub on the ground acting as a passive brake.
tarala (author)The Wapusk2010-03-14
very good instuctable... and wapusk, now i know what the diff in the car does... i am going to tell everyone!
Timothy Wooi (author)tarala2010-03-14
When you go to a hobbyist shop , just take a look at a moderately high end scale model of a remote control  buggy or 4WD .Spin the right rear wheel clockwise and look at the rotation of left rear wheel.
It spins counterclockwise when theres no load applied.
A differential will automatically engage to spin faster when the opposite side experience a heavier load/traction thus improve handling at corners!
static (author)The Wapusk2010-03-12
 There is a simple inexpensive way to drive two wheels that lets the wheel with the least traction, freewheel while slightly in a turn turning. A ratcheting drive cog is employed at each wheel
Timothy Wooi (author)The Wapusk2010-03-11
Tks for the englightenment to why only 1 drive is used.
Unless you want to incoperate put 2 freewheel at the 2 rear wheels,you can dive 2 wheels at the same time compensate for the turning effect like that of a differential gear assembly without wearing much of the tires!
Tim
Timothy Wooi (author)dwrenne2010-03-11
Hi Dwrenne,
You can use to drive 2 wheels but needs more parts to build/fabricate. You will have slightly more pedalling resistance but get better traction in contra.
As our average human power is only about 1/8hp! and to why I use only 1 wheel to drive is to reduce frictional & transmissional losses  as well as creating simplicity in design by using parts readiliy available/ cannibalise from existing bicycles.
After simulating driving 1 wheel,I found it is enough to add value so why 2 is my reason to be energy efficient.You can see that the rear brakes is on the opposite side and no brakes on the drive side is to evenise wear & tear of the tires!
I just incoperated a 6 speed cog as an improvement to the rear 18teeth as found it a bit tiring trying to climb a 10degree hill recently.
Ist, I must tell you that Im a Lean person,and applies Lean thinking into design.  Simplicity in design identifying minimum resourse to eliminate Waste incoperating Robustness and also choosing parts that is repairable (should it fail at the momment it shouldnt( is part of Lean thinking.
Attached some photos.
God bless,
Tim
hot-fresh-rider (author)2010-03-13
you're a great man Tim, better than me because I gave up with HHO project after becoming bored with it, plus all the measurements were in inches and material availability seems better in USA (i'm UK) anyway while fuel savings are nobel I can't help but feel the "carbon" movement has been hijacked. for me I just want cheap energy for everybody without some "carbon saving" being attached. If we go down the "cap and trade" route for carbon then everybody will have an allowence and this leads to further micro-management. carbon "off setting" is the biggest green scam going today.
look into the pro's and con's of "cap and trade" to see where the carbon movement is going. carbon is nessecary for life! only the crettins managing carbon trusts and exchanges are just creating the next bubble, which ultimately will need bailing out, like banks only worse because the human cost will be uninmagionable.
Dont worry buddy,
Cheers,
Tim
metqa (author)2010-03-11
Wow, Nice Bike. Too bad there are no instructions on how to actually build such a Awesomly cool ride. Guess I'll go check out the other instructables.  They don't look nearly as cool but I might at least learn how to make my own.
Cheers, and thanks for helping the planet.
Timothy Wooi (author)metqa2010-03-11
Hi metqa,
Im sorry I did not put in the details as this is my 1st Instructable write up and thought that people who visited this website have already basic knowledge of DIY and are able to take off from pictures attached.
Part of my job also to encourage Creative Thinking for change for the better & Creativity in design tweeking here and there to build things to suite their personal taste.
Im so sorry I have misuse this site.
Thousand appologies,
Tim
Neccesity is the mother of Inventions
metqa (author)Timothy Wooi2010-03-12
Your first instructable? Well I have to say the best thing is you have lots of pictures and that is ALWAYS great.
I don't think you 'misused' the site, at all! :P, It's just that most expect some details of the process. Of course those who fix or repair bikes will have the advantage, but For the rest of us, or for me at least, I find I can often be creative in the process if I know what to do, but if I'm duplicating I try to be exact to get the same results the first time since I don't really know how it was done.
Maybe you could make another instructable with some details of the tools and supplies you chose and why you chose them, and such. Is welding involved? Do I need special tools or just a regular tool box? Did you buy all new supplies or recycle?  I really DO think your bike looks cool,
noel0leon (author)2010-03-11
Very clever frame, I see you used front forks to mount the rear tyres on. Would it be possible (while the frame is being constructed) to angle the forks to give the rear wheels some camber?
Or maybe even make them adjustable during riding?
Timothy Wooi (author)noel0leon2010-03-11
Yes,you can do that as an improvement to this basic design.
I use front fork in view of only Simplicity,Availability and recyclebility of materials utilising their metal properties to givesome minor flexes here & there within the acceptable limits.
Mine was set at negative 1deg before application of load and goes to 0 deg or nominal when simulated with an80kg load.
During cornering I have ome flexes giving me a plus minus 1deg both side which as I only hold down the inner fork arm.
This was adequate on most of the road & terrain I cycle!
Timothy Wooi (author)2010-03-11
Tks Buddy,
Going Green starts from Reduce,reuse & finally Recycle !
God bless,
Tim
Eromanga (author)2010-03-11
Sweet looking ride. Thanks for sharing.
About This Instructable
80,281views
281favorites
License:
Bio: Principal Consultant cum Trainer for Lean Management. He graduated from a Technical College majoring in Mechanical Engineering and is also a Certified Kaizen Specialist and ... More »
More by Timothy Wooi:Green Home built Scrambler from a Yamaha Y100 - KTimHAHow to fix 'Press Shutter Release Button Again' error on a Nikon DSLR.Tim's 5W Solar Charge,12VDC 4.5AH Portable Power Supply.
Add instructable to:
