3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Timmy Green, my homebuilt Delta Recumbent Trike.
Step 4The Frame
The Frame
                      Design of the frame is from a 20” Mountain bicycle frame extended using a 11/2” diameter pipe and reinforced with ¾” pipes between chain-stay to form a triangle  structure extending to the rear to take vertical and side twisting load when taking a sharp turn.The 3/4" tube between the bottom Triangle is for a Rider's weight exceeding 100kg and can be omitted if Rider is below 100kg.
3 comments
Apr 26, 2010. 5:12 AMkube60 says:
Maybe a stupid question here, but when you say pipe, do you mean like iron water pipe like from home depot or did you use actual tubing? Don't mean to nitpick, just need to know for my build.
Mar 11, 2010. 2:26 PMonrust says:
WOW!  Simple and elegant.  Love your use of material.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Timothy Wooi(Tim's Waterfuel)
Principal Consultant cum Trainer for Lean Management. He graduated from a Technical College majoring in Mechanical Engineering and is also a Certified Kaizen Specialist and a hands on TPM Lean Fac...
more »
