Step 6Only 1 Front Derailer
The Rear Axle is linked to the left Rear Wheel through a 1:1 Final Drive set up using 2 standard 18T Freewheel cogs.
Another 18 teeth Freewheel is used on the Rear drive wheel. No Derailer is fitted to ease tire removal during puncture.
Rear brake is only on the Right rear wheel to evenise wear & tear of driving & stopping on opposite tires.
It spins counterclockwise when theres no load applied.
A differential will automatically engage to spin faster when the opposite side experience a heavier load/traction thus improve handling at corners!
Unless you want to incoperate put 2 freewheel at the 2 rear wheels,you can dive 2 wheels at the same time compensate for the turning effect like that of a differential gear assembly without wearing much of the tires!
Tim
You can use to drive 2 wheels but needs more parts to build/fabricate. You will have slightly more pedalling resistance but get better traction in contra.
As our average human power is only about 1/8hp! and to why I use only 1 wheel to drive is to reduce frictional & transmissional losses as well as creating simplicity in design by using parts readiliy available/ cannibalise from existing bicycles.
After simulating driving 1 wheel,I found it is enough to add value so why 2 is my reason to be energy efficient.You can see that the rear brakes is on the opposite side and no brakes on the drive side is to evenise wear & tear of the tires!
I just incoperated a 6 speed cog as an improvement to the rear 18teeth as found it a bit tiring trying to climb a 10degree hill recently.
Ist, I must tell you that Im a Lean person,and applies Lean thinking into design. Simplicity in design identifying minimum resourse to eliminate Waste incoperating Robustness and also choosing parts that is repairable (should it fail at the momment it shouldnt( is part of Lean thinking.
Attached some photos.
God bless,
Tim
