This Project is primarily design for charging communication equipment & gadgets like Laptops,Hand phones, GPS, LED lights while doing mission work in remote area without Grid Electricity Supply.
The capacity of the Power Supply is sized for above personal equipment with portability,availability of material,cost effectiveness & flexibility in mind. 5 Watts Solar panel pumping out 17 Volts was targeted so as not to overcharge Internal 4.5 AH Lithium Ions batteries with only blocking diodes to maintain Simplicity.
From the desk of :
Timothy Wooi ,
20C, Taman Bahagia,
06000, Jitra, Kedah,
Malaysia.
email:timothywooi2@gmail.com
http://facebook.com/timothywooi
Please bear in mind that incoperation of this Circuit will lower Charging Efficiency as for the Panels to charge, you need more than 15V to biase the Regulator. Below that threshold, it will not conduct thus Charge.
As for me ,I personally do not us it as mine charges as long as I have more than 13.5 Volts at Panels giving 12.7 V at Batteries terminals.
( as the Diode drop off another 0.7Volts)
Lean is all about using minimum resourses to add value to meet your requirement tapping on law of Nature & Equilibrium to acheive that Goal.
http://www.elektromodely.sk/A123/APR18650M1_2007-05.pdf
Great project!
Li-Ions are supposed to be charged only with a current-limited constant voltage source - a solar panel with a blocking diode and nothing else is anything but that. Such a simple charging mechanism will result in either dangerous overvoltage/overcharging of the batteries, or if the blocking diode always keeps the battery below maximum charge voltage, significant undercharging of the batteries.
All you would have to do is use protected batteries. You can also buy the circuit for $1.25 per batt. Saves a whole lot of worry and has hi and low protection so you don't drain them too far. Drain them too far and you just made a very expensive paper weight.
I like this idea!
Windy
Maximum sun shown about 16volts but after putting a blocking diode IN4001 it dropped by 0.7volts bringing it over an average of about 13-15Volts on a hot sun. I used 4 cells in parallel to get about 480mA's which is just nice to full charge my 4.5AH Lithium Ion cells over 7 hrs of Sun.No electronics involved as I strongly believe in simplicity in design with minimum components for minimum breakdown.! Facebook.com/ Timothy Wooi or Tim's Waterfuel
Use only 10 units of the 1.2V Nihm,that will give you 12volts.
This is the siplest way you can Suncharge your 3000mA Batteries for a 12V battery pack.
You will need about 38 hrs of sun Exposure to full charge the 3000mA Capacity Batteries.Thats about 5 days! asumming Sunlight is about 7hrs per day.! day charge will give you about 20% charge on the Batteries. Tim
The camera needs 50ma. The solar panel is 125ma, so for about 7-9 hours the batteries will be charged at 50 - 75ma. They will eventually drain so I have to either give them more juice or turn off the camera like once a week. But it's an experiment.
I would like to see your cuircit to. The charging cuircuit I use is a slew of 2 op amps and 3 transisters
***http://fadisel.es/solar-fadisol/reguladores-solares/reguladores-de-carga-de-baterias-fadisol-c-0190_R_366_1327.aspx*** fits inside the grey conexions box
(sorry Spain page) 25.70 Euros(= $37). Picture shows (nearly half-done) my system 1.5v each cell (12 plus 12 cells = 17v & 0.6 Amps) designed to charge batteries as the one you use. (12v 7Ah). with a single diode 1N4007 to protect the regulator.
All working 100% tested all over two years. (Why I do not have more pictures?)
