Tin Can Candle Powered Carousel
 by masynmachien
Contest WinnerFeatured
This Instructable describes a simple way to make candle powered carousel out of a tin can.
The last “Crea” workshop at Leefschool Klavertje Vier had a Christmas theme. It was a workshop with a series of smaller projects. I was to do something with tin cans and candles. Wanting to give it a “masynmachien” twist I came up with this simple candle....
Cutting the “turbine” proved to hard for the children expected at the workshop (mainly 6 to 9 year olds) so I ended up doing a lot of the work in preparation. Keeping it simple was still important, as I had about 20 to make. The kids had still plenty to do making the base and decorating the sides with holes.
UPDATE: I did another workshop with a small group of four girls aged 10 to 13, and apart from sharpening the bearing tip, they managed to do it al by themselves (with guidance).
I included some do’s and don’ts in this Ible. A VERY important one is to keep a large enough gap between the top of the candles and the bottom edge of the can (at least 2.5 cm). When it is not large enough the candle wax can get overheated and start burning all over of the surface, not only at the wick (Yes, I learned from experience). At that stage you can no longer blow out the candle and you risk spilling burning liquid wax.
Of course, never leave candles burning unattended, especially in a self-made construction. Also be very careful with tools and the sharp edges cut in to the can and with hot surfaces. Obviously I can not accept any liability.
If you like this Ible, please give it your vote.
Step 1: Material and Tools
Materials:
- A tin can at least 10 cm diameter. You also need it to have some height to have it hang in balance easily.
- A long nail or steel rod at least 4cm longer than the height of the can + the thickness of the base. With a 2cm thick base and a 12 cm high can I used a 6.5 x 180 mm nail.
- A base plate capable of carrying three theelight candles. I used an OSB triangle with 10cm sides. You should be able to make hole in it, tightly fitting the nail or rod. Casting the nail into a plaster base could be a good alternative, as it completely non flammable.
- 3 theelight candles. It works with 2 also, sometimes. 3 makes it more sure.
Tools:
- A can opener.
- An old wood chisel about 3cm wide and a mallet (not shown) to use with it. Do not use your good chisel on metal (as that is what is done in this project).
- A Phillips screwdriver.
- A file (not shown) to make the tip of the nail or rod very sharp, as it has to serve as a bearing. Using a nail saves work, but it needs to be really sharp, so you will need a file. I used a power file (a small belt sanding machine), but then I had over 20 to do.
- To make the nail or rod fit in the base you will need drill bits of the same diameter as the rod and in case of a nail also of its head.
- Some more drill bits and a columnar drill to make the decorative holes.
- Safety glasses.
- Some sanding paper (not shown).
- Some scrap wood and screws to make a drilling support.
- A sturdy work surface, capable of sustaining a blow. I used cork flooring panel, but any scrap wood panel should do.
- Some measuring gear, a pencil and a permanent marker.
Optional auxiliaries:
- A long-neck candle lighter instead of matches (an ordinary lighter tends to burn your fingers when lighting candles).
- Some silicone glue.
- A tiny amount of grease on the bearing can improve the working. Any lubricant that is somewhat heat resistant should do.
- Solvent like nail polish remover and cloth (both not shown) to remove permanent marker drawings.
susanrm says: Dec 18, 2011. 8:20 PM
Nice work! And great minds think alike...!
masynmachien (author) in reply to susanrmDec 19, 2011. 8:43 AM
Yes indeed, yours is more elaborate and very beautiful.
susanrm in reply to masynmachienJan 6, 2012. 7:55 PM
Congrats on making it as a finalist!
susanrm in reply to masynmachienDec 19, 2011. 12:25 PM
Thank you... And yours is sturdier! :-)
crob09 says: Dec 25, 2011. 8:31 AM
Sweet! I think I will make one and add it to the thermal section of my website hgttp://www.aboutsteam.com
masynmachien (author) in reply to crob09Dec 25, 2011. 9:28 AM
Thanks!
Interesting project, your site.
If you are into steam, you might also like this super simple steamboat of mine.
pop88 says: Dec 24, 2011. 11:36 AM
Very very good
Thank you
mproveaux says: Dec 22, 2011. 10:39 PM
Awesome! Truly awesome. Wish you were my teacher in grade school. I found a recipe for making Gel Fuel for my fake arse fireplace. Found a new use for it I think. I'll try it out and post a pic if I can. (blushing)
masynmachien (author) in reply to mproveauxDec 24, 2011. 1:18 AM
Thanks, I'm flattered.
wobbler says: Dec 22, 2011. 3:42 PM
Great Instructible! Love the effect. Maybe for an adult version, to make the pivot bearing with less friction, you could fix a needle to the nail tip instead using either wire to bind it on or epoxy resin glue.
masynmachien (author) in reply to wobblerDec 23, 2011. 10:12 AM
Great idea. In theory a well sharpened nail point should give a similar contact surface as a needle. But in practice the ready made needle point will easily give the better solution.
Loosing weight by making a lot of holes ore larger openings would also help lowering friction. See the one from susanrm.
susanrm says: Dec 22, 2011. 8:37 AM
Congrats on being featured in the newsletter! :-)
masynmachien (author) in reply to susanrmDec 23, 2011. 10:03 AM
thanks
peterbryenton says: Dec 22, 2011. 7:19 AM
For those without access to many workshop tools, there's a trick for punching holes in the sides of cans without deforming the cylindrical shape.
Fill the can(s) with water. Freeze until solid. Punch the holes through the metal against the supporting block of ice. Thaw, then discard contents.
masynmachien (author) in reply to peterbryentonDec 23, 2011. 10:02 AM
Thanks for the tip.
In some cases the expansion of the ice might damage the can. But as tin cans are pretty strong, it will probably work in most cases.
Sparkyrob says: Dec 23, 2011. 5:55 AM
Good one. I am going to have to do this. Thanks for posting!
EnergyHandyman says: Dec 22, 2011. 3:52 PM
Love it! Nice use of materials and tools.
I may make one.
Alec Eiffel says: Dec 22, 2011. 9:59 AM
I think I know what I'm getting my Mom for Christmas!
Great 'ible!
ynze says: Dec 18, 2011. 12:45 PM
Clever! These kind of lamps are pretty expensive in stores! Would it work with a lightbulb instead of candles?
Y.
masynmachien (author) in reply to ynzeDec 20, 2011. 2:56 AM
It is worth a try. You need enough hot air though, with the primitive bearing and the rather heavy tin can used.
masynmachien (author) in reply to masynmachienDec 22, 2011. 7:15 AM
Loo, you can check out the one from Mr. Sanchez, with a lightbulb!
masynmachien (author) in reply to ynzeDec 19, 2011. 8:46 AM
(removed by author or community request)
susanrm in reply to masynmachienDec 19, 2011. 7:03 PM
Uh oh, looks like the comments bug struck again. You may want to retype your comment. Sometimes the site repeats the same comment you wrote before.
Mr.Sanchez says: Dec 22, 2011. 6:25 AM
Nice ...that reminds me my lamp
masynmachien (author) in reply to Mr.SanchezDec 22, 2011. 7:13 AM
Yours is very nice to. Great to see one with a with a lamp!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
