loading
loading
Picture of Tin Can Candle Powered Carousel
This Instructable describes a simple way to make candle powered carousel out of a tin can.
The last “Crea” workshop at Leefschool Klavertje Vier had a Christmas theme. It was a workshop with a series of smaller projects. I was to do something with tin cans and candles. Wanting to give it a “masynmachien” twist I came up with this simple candle....
Cutting the “turbine” proved to hard for the children expected at the workshop (mainly 6 to 9 year olds) so I ended up doing a lot of the work in preparation. Keeping it simple was still important, as I had about 20 to make. The kids had still plenty to do making the base and decorating the sides with holes.
UPDATE: I did another workshop with a small group of four girls aged 10 to 13, and apart from sharpening the bearing tip, they managed to do it al by themselves (with guidance).
I included some do’s and don’ts in this Ible. A VERY important one is to keep a large enough gap between the top of the candles and the bottom edge of the can (at least 2.5 cm). When it is not large enough the candle wax can get overheated and start burning all over of the surface, not only at the wick (Yes, I learned from experience). At that stage you can no longer blow out the candle and you risk spilling burning liquid wax.
Of course, never leave candles burning unattended, especially in a self-made construction. Also be very careful with tools and the sharp edges cut in to the can and with hot surfaces. Obviously I can not accept any liability.
If you like this Ible, please give it your vote.
I have a question for you. Have been wanting to try to make something out of cans for a while now, and I think you have just inspired a whole lot, but is there any way of getting rid of the sharp edges? Thanks a lot
That is a though one.
For the holes, you can file down the burrs.
For the vanes, in theory you could bend over the edges and flatten them, but that would be quite hard.
In this project the sharp edges and burrs are all aiming inwards, so they do not pose a problem for normal use.
susanrm3 years ago
Nice work! And great minds think alike...!
masynmachien (author)  susanrm3 years ago
Yes indeed, yours is more elaborate and very beautiful.
Congrats on making it as a finalist!
Thank you... And yours is sturdier! :-)
crob093 years ago
Sweet! I think I will make one and add it to the thermal section of my website hgttp://www.aboutsteam.com
masynmachien (author)  crob093 years ago
Thanks!
Interesting project, your site.
If you are into steam, you might also like this super simple steamboat of mine.
pop883 years ago
Very very good
Thank you
mproveaux3 years ago
Awesome! Truly awesome. Wish you were my teacher in grade school. I found a recipe for making Gel Fuel for my fake arse fireplace. Found a new use for it I think. I'll try it out and post a pic if I can. (blushing)
masynmachien (author)  mproveaux3 years ago
Thanks, I'm flattered.
wobbler3 years ago
Great Instructible! Love the effect. Maybe for an adult version, to make the pivot bearing with less friction, you could fix a needle to the nail tip instead using either wire to bind it on or epoxy resin glue.
masynmachien (author)  wobbler3 years ago
Great idea. In theory a well sharpened nail point should give a similar contact surface as a needle. But in practice the ready made needle point will easily give the better solution.
Loosing weight by making a lot of holes ore larger openings would also help lowering friction. See the one from susanrm.
susanrm3 years ago
Congrats on being featured in the newsletter! :-)
thanks
For those without access to many workshop tools, there's a trick for punching holes in the sides of cans without deforming the cylindrical shape.
Fill the can(s) with water. Freeze until solid. Punch the holes through the metal against the supporting block of ice. Thaw, then discard contents.
masynmachien (author)  peterbryenton3 years ago
Thanks for the tip.
In some cases the expansion of the ice might damage the can. But as tin cans are pretty strong, it will probably work in most cases.
Sparkyrob3 years ago
Good one. I am going to have to do this. Thanks for posting!
Love it! Nice use of materials and tools.
I may make one.
Alec Eiffel3 years ago
I think I know what I'm getting my Mom for Christmas!
Great 'ible!
ynze3 years ago
Clever! These kind of lamps are pretty expensive in stores! Would it work with a lightbulb instead of candles?
Y.
masynmachien (author)  ynze3 years ago
It is worth a try. You need enough hot air though, with the primitive bearing and the rather heavy tin can used.
masynmachien (author)  masynmachien3 years ago
Loo, you can check out the one from Mr. Sanchez, with a lightbulb!
(removed by author or community request)
Uh oh, looks like the comments bug struck again. You may want to retype your comment. Sometimes the site repeats the same comment you wrote before.
Mr.Sanchez3 years ago
Nice ...that reminds me my lamp
masynmachien (author)  Mr.Sanchez3 years ago
Yours is very nice to. Great to see one with a with a lamp!
