Introduction: Tin Can Lamp
Hello, folks.
In this instructable I would like to present to you my take on the "tin can lamp". For quite some time I wanted to do something with an empty can that was sitting around, and since I am a great deal into all-things- lamps, I decided to give it a try.
For this instructable you need some basic materials:
tin can
a piece of wood ( 1.5 by 1.5 cm, 1.5 meters long)
toggle switch
plug
electric cord
2 bolts, 2 nuts
light bulb
light socket
Lets find more in step 1.
tin can
toggle switch
plug
electric cord
2 bolts, 2 nuts
light bulb
light socket
Step 1: Tools and Meterials.
tin can
toggle switch
plug
electric cord
2 bolts, 2 nuts
4 screws
light bulb
light socket
Wood glue
Varnish
Spray
TOOLS:
drill
drill bits
saw
sand paper
screwdriver
ruler
tin can
toggle switch
plug
electric cord
2 bolts, 2 nuts
4 screws
light bulb
light socket
Wood glue
Varnish
Spray
TOOLS:
drill
drill bits
saw
sand paper
screwdriver
ruler
Step 2: Measure and Cut the Wood, Spray the Tin.
For the sides of the frame cut two pieces of wood, both 30 cm. long. For the top, middle and bottom of the frame cut 3 pieces, 9 cm. long. Cover the tin can with several layers of spray paint, until you are satisfied with the way it looks.
Step 3: Glue the Frame and Feed the Electrial Cord Through the Frame.
Use your wood glue to glue the pieces together and then feed the electrical cord through the frame.
Step 4: Prepare the Nuts.
I wanted to cover the nuts in wood so the the lamp could achieve a better overall look. What I did was to take the nut and put it in a piece of wood and use that to tighten the bolt that keeps the tin in place.
Step 5: Connecting the Buld Socket and Attaching the Switch.
For this part you will need:
light bulb (GU 10)
2 screws
a piece of wood
switch.
Check the pictures for further instructions.
light bulb (GU 10)
2 screws
a piece of wood
switch.
Step 6: Installing the Can.
Get the bolts and the nuts and put the can in place, tighten the nuts and you are done.
Step 7: It's Time for the Unveiling.
I have to say that I am delighted with how this turned out.
It is functional, good-looking, energy-saving... I love it :)
