3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tin Can Sterno Stove
  • C:\Documents and Settings\Jimmy And Jason\Desktop\Instructables\step8-2.JPG
  • C:\Documents and Settings\Jimmy And Jason\Desktop\Instructables\step8-3.JPG
This is a soup can that I turned into a stove to use with the well known sterno gel fuel. It will heat up soup, tea, ravioli, hot chocolate, and a lot of those other canned/liquid goods. It can be used indoor and outdoor safely. This is my second instructable/ my dads first.
Step 1Materials And Tools
Materials And Tools
  • C:\Documents and Settings\Jimmy And Jason\Desktop\Instructables\step1-1.JPG
  • C:\Documents and Settings\Jimmy And Jason\Desktop\Instructables\step1-2.JPG
You will need as follows:
-Can Openers (both like in the picture)
-Knife
-Screw
-Screw Drivers (one for the screw, and one for enlarging the holes)
-Pliers
-Large Can Of Soup
-Container That Can Fit All The Soup
-Sterno
-Coat Hanger
20 comments
Apr 4, 2012. 6:08 PMTim Temple says:
To have full, one-way flow through a round hole, the minimum height above it would be 1/4 the minimum diameter of the hole. To allow for two-way flow (when using a Sterno can) the minimum height would be 1/2 the diameter of the hole.
Since the coffee can would be too hot to handle, toss the can lid in and poke it into place with the coat hanger. The fire will go out. Ten minutes later, you can take it all apart.
Sep 20, 2007. 6:35 AMchuckr44 says:
Holy crap! I just made one of these 2 weeks ago with the same design: coffee can with 2 thick wires at the top to hold the pan/cup. Except mine is wood powered and works great. I will test it camping in later October. For the wires I used 2 very long pegboard pegs (metal of course). It boiled 10 oz of water in less than 7 minutes. And you don't have to carry fuel if you use wood. (Unless you are in a wood free place like the desert.)
Nov 16, 2007. 7:51 PMflove101 says:
I think wood powered stoves are great (enough isn't said about the ambiance of fire), but I know that I am not proficient at lighting them with anything but tinder dry wood, something that is in short supply after anything more than light rain. and to carry lighter fluid to me defeats the purpose of carrying a wood stove.
Nov 4, 2010. 4:49 AMKittyF says:
search Lint vasaline Fire starter. I saw that guy from Man, woman in the wild had some vasaline lint or vasaline and cotton balls in a foil packet and he used it to light the fire.
Nov 4, 2011. 10:51 AMmkslocomb says:
Or look for Char Cloth (very easy to make) and some sort of spark maker. My blacksmith friend provided flint and steel (an old file).
Oct 14, 2011. 7:22 AMDanYHKim says:
You might consider making a wire basket to lower the Sterno can into the stove, so your stove doesn't have to have the bottom removed. You can then light the Sterno and lower it into the can. Dunno if this is of any advantage, but it's another approach.
Thanks for the instructible. Last year we had a 3-day winter power outage, and I used Sterno to heat water. A small stove like this would have been handy.
Aug 30, 2011. 3:21 PMjshockley1 says:
Recommend adding some sort of insulated handle, maybe to the fork- that way you can't remove the can't and snuff the sterno when you're done.
Dec 16, 2009. 12:24 PMJohnny Bot says:
Hey,  You can use almost any size can and custom fit it to your situation, and if you have a Handy Dandy P38 handy it will make it just like making a C-Rat stove, with out the triox tabs
Dec 8, 2009. 9:52 PMwolfen31 says:
It works pretty well.
Sep 22, 2007. 8:37 PMxboxteen01 says:
this is probably a dumb question, but if you were to burn wood in this kind of stove, would you need to cut a side door for the addition of fire wood or would you need to just slide the wood down the sides, in between the cup and stove wall.
Oct 25, 2009. 6:11 PMjunits15 says:
Are you really an egale scout?  or is that just your picure?
Oct 25, 2009. 7:19 PMxboxteen01 says:
im an eagle scout with 1 bronze palm. class of 06
Oct 26, 2009. 3:18 PMjunits15 says:
Thats awsome!
I hope that one day I can become an egale, right now im just a star scout though.
Oct 12, 2008. 3:33 PMHeWantsRevenge says:
absolutely rite
Feb 15, 2008. 9:25 AMtippymcstagger says:
I agree with the larger can for wood. Even small sizes of coffee cans seem too small.
Oct 15, 2008. 12:07 PMChaseReno says:
As far as a survival type stove...we use small cans because they can be easily packed into your day pack. We put survival type stuff in the can as well...tea, broth, hook and line, matches etc. We put a small salsa or mushroom can inside the larger for our drinking cup (we use the skewer method just as you do to keep the can up off the flames). We also use wood to fire them. You can pick small sticks up as you walk along. In case of no dry tinder pack along a few tea light candles. We've roasted marshmallows over tea light candles. Not really a survival skill, but hey, who doesn't like roasted marshmallows?
Sep 19, 2007. 8:10 AMfungus amungus says:
Nice and simple. Good job.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:gamer
