Tin Can Stirling Engine
 by PKM
Featured
How I built a hot air engine almost entirely from junk.  I've wanted to build one of these ever since discovering stirling engines in about 2003.  Spending the weekend making things in Steveastrouk's workshop gave me the opportunity to make the precision parts I'd need, and I knew most of the engine was going to be made of improvised materials, so decided to see if I could make the entire thing out of scrap or unwanted materials.
If you aren't familiar with how Stirling engines work, there are plenty of resources online- the Wikipedia page is a good place to start.
Step 1: Design
The "core" of a gamma stirling engine of this design is a large cylinder that holds the displacer, connected to a smaller power cylinder providing the power strokes.  I decided to follow Darryl Boyd's "walking beam" design, where the power cylinder sticks out of the side of the dis[placer cylinder, because it suited the materials I had and it looks cool  :)
I found that an aluminium drinks can would fit neatly inside a steel soup can, so decided to use that for the displacer on the grounds of being cheap, light and easy to work with. The steel soup can provides a sturdy body for the engine and also meant I could ake the bottom removable to allow maintenance.
I found some decking to use as the base, some 1" x 1/2" pine to use as supports for the moving parts, and a piece of 3/4" aluminium strip to use as the beam.  The engine is a messy combination of metric and imperial units- that's what happens when you use scrap materials!
eyesee says: Jan 10, 2013. 6:11 AM
Piston seal problem
jeveda12 says: Dec 20, 2012. 5:52 PM
can you explain a little more about this engine, like how to build the piston and why there is to pistons.how this works please
PKM (author) in reply to jeveda12Dec 21, 2012. 2:53 AM
Step 3 links to some ways of making pistons- you can make one out of glue, or a balloon, or (the way I did) machining it out of metal. I'm not good enough at machining to write a guide on how to do that, so I skipped over that part.
There is only one piston, which has to be a very close fit in the small cylinder but slide freely, and the displacer inside the engine which needs a small gap around the sides. To understand how the engine works I'd suggest reading the Wikipedia page about them. Briefly, the displacer is there to move air around inside the engine, and the piston is pushed in and out by air pressure.  This explains why the parts need to fit the way they do, but to understand the entire cycle you should read more about Stirling engines- there is plenty of information on the internet about them.
lonely164 says: Sep 12, 2012. 11:56 AM
good
asdasd says: Sep 1, 2012. 7:59 AM
Cool, but I'm not sure is it stirling.
PKM (author) in reply to asdasdSep 1, 2012. 12:02 PM
Well, as I understand it this engine uses the Stirling cycle (heat, expand, cool, contract), so I think it is. What part are you unsure about?
deep92 says: Jan 15, 2012. 4:15 AM
I get that for the power piston to be able to move, it has to be smaller in diameter than the power cylinder, but the thing that i don't understand is that if the piston is smaller than the cylinder won't it cause air leakage??
thanks for ur response! This is the only thing thats bothering me, otherwise i'm really looking forward to making this!!!
PKM (author) in reply to deep92Jan 27, 2012. 3:01 AM
That is the biggest problem with building solid power pistons, they have to move freely but fit very closely. Mine, thanks to a very big lathe, is smaller than the inside of the cylinder by something like a quarter of the thickness of a human hair...!
Unless you can make the cylinder and piston perfectly smooth you are aiming for the best compromise between it being too loose (and leaking air) and too tight (and friction taking power away from the engine).  I believe loose is generally better for a hand-made first engine. How you do this is entirely up to you, there are a number of possible approaches- check out the many other Instructables on stirling engines.
yokozuna says: Nov 24, 2011. 8:44 AM
Nicely done sir, 5 stars.
ravenheart_tinkers says: Apr 26, 2011. 9:42 PM
Very cool little project. Thanks. Oh, and Sterling engines have enormous real world application without any further development. They already work so they aren't just "curiosities". These engines are highly efficient (and they are also typically used with free or very cheap energy sources anyway) and very low maintenance & cheap to operate. Without any further development whatsoever, these engines are already available for purchase from numerous sources, especially relating to electricity producing solar concentrators and co-generation applications where new or existing heating furnaces & incinerators are fitted to also produce electricity. Co-generation engines are not only available for large commercial applications, but also for residential and small commercial applications, requiring as little as 500 degree Celsius to operate. Comparing petroleum diesel engine applications to sterling engine applications is utter nonsense. Diesel has absolutely no application where sterling engines are designed to be used. These applications are specific to producing very cheap electricity, so implying that diesel generators could somehow be used is ridiculous. I strongly suspect the poster makes his living from either petroleum or combustion engines and is making a feeble attempt to misinform. Now to be fair, algae generated diesel may be something to show enormous promise in the relatively near future with some further technological development, but petroleum based diesel is a non-argument. And even having given a nod to algae generated diesel, it doesn't appear that it will be cost effective enough to produce anytime soon to render sterling engines obsolete. Note: Hebinho posted some relevant links above in regards to this argument for anyone who missed them and would like to see just how advanced sterling engine technology already is and what it has to offer.
Raven Destroyer in reply to ravenheart_tinkersNov 10, 2011. 2:06 AM
it's hard to make a sterling really work but when it works it shouldn't stop working
Barfight76 says: Jun 16, 2011. 6:26 AM
Excellent work! I want to build one using clear materials (i.e. glass, pvc, etc.), but I can't seem to find what kind of hot temperatures that are dealt with. The pvc specs I'm looking at have a max temp of around 150 deg F. My question really is, what kind of temperatures are you getting from your hot air portion?
charris7 says: May 29, 2011. 1:54 PM
can someone please explain the power piston and cylinder to me? what do I need, and how do i position it to make it work???
PKM (author) in reply to charris7Jun 1, 2011. 4:53 AM
Someone else has probably explained the cycle more concisely than I have, but in essence:
The displacer pushes the air in the engine to the hot end, where it heats up and expands. This expansion pushes the power piston outwards, because it's the only part of the engine that can move to let the air inside expand. The power piston moving outwards turns the rotating parts around, which moves the displacer and so moves the air inside the engine to the cold end. The air cools down and contracts, and so sucks the power piston back inwards.
The power piston itself needs to be able to move in the cylinder freely, but also to move in the cylinder with a change of air pressure. The simple way to do this is to just glue a cut-out circle of balloon rubber over a hole in the engine, so it will move in and out with changing air pressure. I did it by making a smooth brass tube and a piston to fit very closely in that tube.  That way is more fun and can make a more powerful/efficient engine but needs workshop tools whereas the balloon method might only need a knife and some pliers.  Check out reukpower's instructables for more on how you can build stirling engines without precision engineering tools.
furyy says: Apr 4, 2011. 2:53 AM
That is soo cool!
wiinick says: Mar 23, 2011. 3:34 PM
What is that metal thing holding the cd, i see them in many of these projects and i cant seem to find one, help me.
steve-lane says: Mar 19, 2011. 1:02 PM
you could use one of those sterno cans.
I picked up some at a camping store
tzq33tdq says: Mar 18, 2011. 6:16 PM
i want one!!!
fail says: Mar 17, 2011. 3:01 AM
Ive got 2 soup cans and there is a gap of half a centimetre between the middle can and the outer one, all of the way around. Is that too much?
PKM (author) in reply to failMar 18, 2011. 3:05 AM
No, that sounds about right. The gap should be wide enough to allow air to flow around without restricting it, so less than a millimetre or so would be too close, but not so wide that it creates "dead space" which doesn't contribute to the power cycle. Having a slightly wider gap does give you more leeway if not everything aligns perfectly (which I was glad of!)
Ideally the displacer should be light, so if you can find one an aluminium drinks can might be better than a thicker steel soup can, but I don't see any reason the soup can wouldn't work.
fail in reply to PKMMar 18, 2011. 4:29 AM
Thanks!
I can't seem to find any drink cans around, so I'm going to use these cans instead, now that I know that it should work. I shall inform you on how well it runs.
wiinick says: Mar 15, 2011. 4:37 PM
Video pleeeeaaaassseeeee
Biotele says: Feb 27, 2011. 12:51 PM
video please. Can you calculate power and efficiency?
PKM (author) in reply to BioteleMar 10, 2011. 6:07 AM
I'll post a few more videos when I have time to take them. I'm not sure of the power, but I hooked up the flywheel pulley to a motor running as a generator and it would just about light up one LED :(
I think it was overheating at the time- with better cooling and a more suitable generator I figure I could get perhaps one or two hundred milliwatts out of it.
Efficiency is pretty poor, I think an average candle puts out something like a hundred watts of heat so we are talking about something like 0.1%. Not great!
alexsparrow says: Feb 27, 2011. 2:14 PM
that thing runs hecka fast
PKM (author) in reply to alexsparrowMar 10, 2011. 5:58 AM
The video doesn't show it running that fast- what you don't see is it stalling just after the end of the video because that's about as slowly as it will run :)
That was only running on one candle, though. Heating it with a small cup of meths, it will run at several revolutions per second- it might go faster but I'm afraid to let it run that fast in case something gets damaged in the process. I'll take a video of it running fast and post it in the comments when I have time.
Timofte Andrei says: Mar 10, 2011. 5:00 AM
you should put some oil on joints and on the pistons! you can minimise the friction in this way ;)
PKM (author) in reply to Timofte AndreiMar 10, 2011. 5:55 AM
I did actually consider that, but the piston is machined with such a smooth surface and such a tight fit that oil actually increases the friction. The forces involved are small and the piston has quite a large area, so the drag of the film of oil tends to slow the engine down.
I do oil the crank bearings and the sliding displacer rod- it's possible I hadn't done that when I recorded the video, but it doesn't squeak as much now.
pfred2 says: Feb 25, 2011. 7:29 AM
I did a school report on these when I was in 7th grade back in the 70s. Since then I've always still been a bit intrigued by them. I've seen examples that can run on the warmth of the palm of someone's hand holding them! Yours is neat for different reasons of course.
juanvi in reply to pfred2Feb 27, 2011. 6:42 AM
(removed by author or community request)
Hebinho in reply to juanviFeb 27, 2011. 7:35 AM
Hi juanvi,
just go to YouTube and search for KS90 and you will see some nice examples!
They also start running when the upper surface of the displacer cylinder is being heated by just letting the sun shine on it!
But they are a bit difficult to align and when building one, you have to avoid everthing which could cause some unneeded friction.
pfred2 in reply to HebinhoFeb 27, 2011. 8:13 AM
When I was there they seemed to be rather commonplace items today. Stirling engines are at best a curiosity though.
Vengence in reply to pfred2Feb 27, 2011. 6:33 PM
Wrong. Currently they're more efficient than solar cells. They can be up to 40% efficient(not the type in this instrucable though). The company Stirling Energy Systems Inc. has been contracted to build a solar farm in California...
Hebinho in reply to VengenceFeb 28, 2011. 4:34 AM
First of all we should distinguish between "toy" or "demonstartion" stirling engines and real serious stirling engines! Scottsdale's Sterling Energy Systems Inc. is running the "Suncatcher" which has a mirror dish of 11.5 m diameter and produces 25 kW of eletric power at an efficiency of 31.25 % (world record in 2008), while solar cells rarely are getting beyond 15 %!
Europe has a lot of CHPs (Combined Heat and Power plants) installed, using biomass to generate heat and electrical energy in housing areas, based on stirling engines. Of course these engines by no way can be compared to the ones you will find at instructables.com, but these are real hitech products, running 30,000 hours and more needing only a small amount of maintenance.
There are small CHPs (15 kW heat and 3 kW electrical energy), just take a look at http://ec.europa.eu/environment/life/project/Projects/index.cfm?fuseaction=home.showFile&rep=laymanReport&fil=LIFE99_ENV_D_000452_LAYMAN.pdf
Hungary based FlexEnergy is builing a generator (38 kW output) running on landfill gas (methane) only.
Now you can continue to state "...Stirling engines are at best a curiosity though..."
pfred2 in reply to HebinhoFeb 28, 2011. 6:47 AM
Thank you for allowing me to continue stating the obvious.  A few obscure projects referenced does not make you right. There is likely more steam piston engines still in operation than Stirling engines today.
A 40kW diesel generator isn't newsworthy, its a pallet item.
http://www.google.com/images?um=1&hl=en&safe=off&tbs=isch:1&&sa=X&ei=s7FrTY7PPIO88gaU4LyQCw&ved=0CC8QBSgA&q=40+kW+diesel+generator
About 153,000 results ...
I think we need to distinguish between fantasy and reality but that's just me.
Vengence in reply to pfred2Feb 28, 2011. 6:41 PM
[pfred2: A few obscure projects referenced does not make you right.]
Yes, it most certainly does. It's called proof, and it's not an opinion. You have been proven wrong.
[pfred2: There is likely more steam piston engines still in operation than Stirling engines today.]
Of course there is. Steam is still one of the most efficient and most powerful systems there is. If there wasn't a problem with steam production and storage we'd still be using them in our cars. You're not making a case for yourself. How exactly do you think nuclear power plants work? That's right...steam...
[pfred2: I think we need to distinguish between fantasy and reality but that's just me.]
I guess the sources that Hebinho mentioned are fantasy and not reality? I don't think "we" need to distinquish between fantasy and reality, I think just "you" do.
You may now continue to post opinion...
pfred2 in reply to VengenceFeb 28, 2011. 9:02 PM
You just keep on believing that efficient equals practical. As an example fusion is amazingly efficient, just not very practical. Nuclear power plants do not use pistons except to raise and lower the control rods. But yes turbines are fairly efficient, and practical as well.
No I'm not making a case with you! Because you are an unreasonable individual.
I'm supposed to accept a few sources but it is OK for you to ignore the overwhelming number I present? At this point I really don't care what you think.
Vengence in reply to pfred2Feb 28, 2011. 11:30 PM
[pfred2: As an example fusion is amazingly efficient, just not very practical.]
Fusion isn't even done at a stable level yet. Once fusion reactors are perfected it will be extremely practical and will take the place of current nuclear reactors. You're still wrong in your example.
[I'm supposed to accept a few sources but it is OK for you to ignore the overwhelming number I present?]
Overwhelming number of what? You have produced zero evidence that "stirling engines are at best a curiosity".
pfred2 in reply to VengenceMar 1, 2011. 4:24 AM
Sure it is it, just takes more power to operate than can be gotten from it. If fusion reactor engineering impossibilities are ever overcome I'm sure it'll rain pennies from heaven on that day!
Here are 153,000 examples
That took all of a tenth of a second for our favorite search engine to cough up but you conveniently choose to ignore. Go argue something you've a chance with like extra terrestrials or the Easter Bunny. That ought to be a good one, least you'll have baskets pretty soon as proof!
komodoboyx5 in reply to pfred2Mar 4, 2011. 6:16 PM
you're also ignoring the fact that diesel is a non-renewable resource. The sun will burn on for many, many, many, many, many, many, many more days. In fact, by the time the sun does burn out, we'll have found more suns to juice for energy.
& Don't argue the stupid position of proposing ethanol, that would require energy to make energy, wasting time & power.
pfred2 in reply to komodoboyx5Mar 5, 2011. 8:02 AM
I'm not the one arguing.
Vengence in reply to pfred2Mar 3, 2011. 4:36 AM
[pfred2: Sure it is it, just takes more power to operate than can be gotten from it.]
No, it's not. You're basically saying so in the latter part of your statement. Will you ever stop being wrong(Apparently not)? It's not supposed to take a continual energy feed to keep the reaction going. It's only supposed to take energy to start the reaction, and it should keep going for as long as it's stable. You understand what stable means right? ITER is expected to produce a minimum stable reaction of 480 seconds but could be as much as 1,000 seconds, producing 5(on the low end) to 10(on the high end) times as much energy as was needed to start the reaction.
[pfred2: That took all of a tenth of a second for our favorite search engine to cough up but you conveniently choose to ignore.]
You posted the same exact useless link again? That's proving that stirling engines are a curiosity how?(I'll give you a hint: it's not) With the national average for diesel being $3.716 per gallon and some places as high as $3.964, tell me again which one you think is actually more practical? Do you have to keep paying the sun to receive and convert it's energy? A link to diesel generators proves nothing about stirling engines. You'd have to be delusional to think the diesel generator is more practical.
pfred2 in reply to VengenceMar 3, 2011. 5:05 PM
What vessel besides magnetic do you propose plasma be contained in? It's not like you can put something a million degrees into your coffee cup you know?
You just choose not to see the relationship. They pointed out one example of a 37kW generator I pointed out 153,000 of similar in just one other technology. Now if diesel wasn't more practical then how come there are so many more examples?
SydAndy in reply to pfred2Mar 6, 2011. 6:01 PM
pointing out existing examples means nothing about the future.
By the same example 100 years ago you would be saying coal powered steam engines were the only solution earth ever needs, claiming petrol engines were a fad.
100 years before that, you would be mocking anyone even thinking anything but a horse could move a cart.
You would probably also be saying that since 90% of carts were drawn by horses, that those carrying heavier loads which required bullocks to pull them should be regarded as imaginary?
pfred2 in reply to SydAndyMar 6, 2011. 8:37 PM
Maybe what you say would be true if Stirling engines hadn't been around almost 200 years already.
Hebinho in reply to pfred2Mar 7, 2011. 4:05 AM
And for how long the wheel has been around before becoming ball bearings ....?
pfred2 in reply to HebinhoMar 7, 2011. 7:35 AM
That explains your problem. You have axles in your bearings!
Vengence in reply to pfred2Mar 5, 2011. 5:57 AM
[pfred2: What vessel besides magnetic do you propose plasma be contained in? It's not like you can put something a million degrees into your coffee cup you know?]
It's starting to seem like when you're wrong on one part of a subject you try to bring the attention to a different part, hoping you'll eventually be right about something. Don't change the subject. Where's your proof/argument that current fusion reactors are stable(self sustaining for a significant period of time)? Is this you conceding defeat?
[pfred2: Now if diesel wasn't more practical then how come there are so many more examples?]
How about I answer your question with more questions? If diesel is more practical, why are there more gasoline engines on the road today? Why are hybrids just now being sold when the technology necessary to develope them has been around for at least 30 years?
The reasons are political, not reasons of practicality...
pfred2 in reply to VengenceMar 5, 2011. 8:15 AM
I thought we were talking about generators in the 37kW range and there diesels are more more prevalent than gasoline ones. Though you can get plenty of gasoline generators in that range as well! Stating more facts that defeat a baseless argument is hardly conceding defeat. In court it would be called a preponderance of evidence actually. Though I suppose your only hope is that I am wrong about something eventually. Nice try, better luck next time. Hybrids are being sold now for the simple economic facts that enough fools believe in enough nonsense to shell out enough money for them. Nothing more.
Vengence in reply to VengenceMar 12, 2011. 4:23 AM
Looks like I've decimated this debate. Sorry, couldn't help but rub it in your face. }B^P
pfred2 in reply to VengenceMar 12, 2011. 2:03 PM
If by decimate you mean kill one in ten you over estimate your success. Now if I was your legion commander I'd have you, and all of your cohort annihilated. Sorry, I couldn't help pointing out once again you know nothing.
Vengence in reply to pfred2Mar 13, 2011. 4:50 AM
Translation: "Nu uh".
LMAO
Yep. Every single topic, every argument shot down and decimated. All you can say is nu uh but take an entire paragraph to do so. Sorry, couldn't help pointing out you take so long to say so little.
pfred2 in reply to VengenceMar 13, 2011. 6:41 AM
While you may have been arguing your nonsense all of this time I was just pointing out widely known facts. You're obviously a coward who made up this "Vengence" account merely to attack me being as you've done nothing else with it as all. Another easily discernible FACT! So Vengeance really is mine. Uh huh.
Vengence in reply to pfred2Mar 14, 2011. 12:41 AM
[pfred2: While you may have been arguing your nonsense all of this time I was just pointing out widely known facts.]
Your lack of intelligence is overwhelming. You've been spewing out nothing but opinion, and the only useless fact you did point out helped your argument in no way what so ever. You might as well have pointed out that light bulbs exist. It would have the same relevance.
[pfred2: You're obviously a coward who made up this "Vengence" account merely to attack me being as you've done nothing else with it as all. Another easily discernible FACT!]
Like I said, the idiocy is overwhelming. You still don't seem to know what facts are, and you're still just wrong. Are you ever right about anything in life? The real fact is you can't even do something as simple as count. You do know Sep 24, 2007 comes way before Apr 14, 2009 right? Of course you don't; that was the point I was making.
Decimated.
pfred2 in reply to VengenceMar 14, 2011. 9:48 AM
How this site is formatted I did not notice you had more than 2 comments beyond the ranting you've done in this thread. But viewing them all now I see you're always that way. You must also excuse my difficulty reading white text on a white background. Fact is you're really not worth looking at too closely. The less I know about you the better off I am!
Decimate
to select by lot and kill every tenth person of.
to take a tenth of or from.
Like I said you're being a bit too optimistic. The only point you have is the one on top of your head.
Vengence in reply to pfred2Mar 14, 2011. 11:14 PM
[pfred2: You must also excuse my difficulty reading white text on a white background.]
White on white? Not only can you not count, you don't know your colors. It's white on orange. Is there something wrong with your computer too?
Way to use the obsolete definition of decimate. In fact, I'm sure the word decimate has never been used in that context, only decimatus. The first definition from dictionary.com
1. to destroy a great number or proportion of:
Also from wiktionary.org
The Cambridge Guide to English Usage states that the nonspecific use of this word to mean devastate or severely reduce the numbers of is ‘nowadays the commonest use of the word in both British and American English, and it’s registered without comment in modern dictionaries.’ It also advises against using numbers with the term, as ‘They are redundant where it means “reduce by one tenth,” and where it doesn't they confound the arithmetic.’The 23 occurrences of decimate in the British National Corpus — compare decimates, decimated, and decimating — almost all clearly accord with the nonspecific sense. The only references to the historical sense are two complaints about modern usage and its critics. Neither of these actually uses the term to mean "reduce by one-tenth".
You're seriously never right. That must be frustrating to you.
Even in your definition, that was AFTER the battle was already won. He would kill 10% more people as a lesson to the opponents; which I guess still fits well with what I'm doing now.
Decimated yet again.
pfred2 in reply to VengenceMar 15, 2011. 12:40 PM
PKM (author) in reply to pfred2Mar 15, 2011. 4:08 PM
OK chaps, I think this debate has reached its logical conclusion. Let's keep it on-topic and civil, if you don't mind.
pfred2 in reply to PKMMar 15, 2011. 7:19 PM
Vengence in reply to pfred2Mar 16, 2011. 4:10 AM
You're curious about stirling engines? Here.
http://en.wikipedia.org/wiki/Stirling_engine
It talks about their practical applications in there as well. You might learn something.
pfred2 in reply to VengenceMar 16, 2011. 5:54 AM
I knew all about Stirling engines before you were a twinkle in your mother's eye.
Vengence in reply to pfred2Mar 16, 2011. 6:26 PM
I meant beyond what's in this instructable. You clearly haven't read and don't know any of the information in the link. I understand if that link is too much information for you to comprehend.
Hebinho in reply to pfred2Mar 16, 2011. 6:22 AM
THIS seems really to explain your problem: being of THAT HIGH AGE, it's called "Alzheimer" instead of "knowledge"! ;-)
Vengence in reply to HebinhoMar 16, 2011. 6:31 PM
Yes, that would make him very very old, which makes sense now looking at his avatar picture.
pfred2 in reply to VengenceMar 17, 2011. 4:51 AM
At least I have one.
pfred2 in reply to HebinhoMar 16, 2011. 8:40 AM
So, now you are unmasked! I sort of figured with my amazingly scintillating Sherlockian intellect that "Vengence" [sic] was your abuse account. Rocket science ...
Vengence in reply to pfred2Mar 16, 2011. 6:46 PM
Wow, maybe you're not stupid. Maybe you're just insane. I wouldn't be surprised if you were Vengence and you were arguing with yourself, myself...err ourself, except my persona gets all of the actual intelligence while yours is blocked from access.
SydAndy in reply to VengenceApr 7, 2011. 7:57 AM
LMAO. I prefer the Vengence persona, I think it is far more rational and intelligent.
And normally makes sense when it replies to something, not spouting meaning gibberish which wastes everyone's time.
pfred2 in reply to SydAndyApr 7, 2011. 3:46 PM
Yes you do.
pfred2 in reply to VengenceMar 17, 2011. 4:55 AM
Trollolololo
Hebinho in reply to VengenceMar 16, 2011. 5:39 AM
@pfred2:
I am very curious, how the Diesel generator would be run, when there is no Diesel available (now please don't say "sunflower oil", as this would be too "green" for you, and - depending on the motor's technology - could lead to fast damages)?
There are small companies evolving, already producing series of Striling engine generators which can be run by anything producing heat AND already can be bought: http://www.genoastirling.com/pdf/Specifiche_3Kw_bicilindro.pdf
There are new types of Stirling engines (free piston engines), which even need less maintenance than the "normal" ones (which do NOT need lubrification).
And btw: Philips already had built a series of working Stirling generators back in the 50ies (!), but - one of the most remarkable "features" of man - they abandoned the idea and went the way of the "least resistance".
It is really astonishing, that mankind always starts to think of new technologies only when getting at a point where something - in this case fossile fuels - will no longer be available or - in the case of Japan - secure nuclear technology proves to not be as secure as being planned.
pfred2 in reply to HebinhoMar 16, 2011. 8:33 AM
I can see that you think ad hominem arguments will get you everywhere.
Vengence in reply to pfred2Mar 16, 2011. 6:34 PM
At least ad hominem arguments in some instances are legitimate and relevant to the issue. Contrary to your argumentum ad ignorantiam arguments which are completely irrelevant.
Nevermore.
Hebinho in reply to pfred2Mar 1, 2011. 5:43 AM
@pfred2:
This discussion is getting pretty ridiculous!
We are not discussing about something like "Perendev motors" or "Overunity", we are talking about a kind of technology, which is existent and which is being developed more and more (due to the fact that the so very much easier way to use petrol-based technology will by the best meaning of the words "run out of fuel" in the not so very far future. Would you do a little more research in the internet, you would find, that actual Striling engines have an efficiency (fuel input to mechanical output) which is at least as high as modern Diesel engines (internal combustion).
And concerning your "impressive number" of  Diesel generators: how many of those are really "green", having a particle filter and using an additive like "AdBlue"? Don't tell stories by quantity, switch to quality!
pfred2 in reply to HebinhoMar 1, 2011. 4:45 PM
I never said any of them were green just practical to the point of burying Stirling engines. Which everyone knows are just a curiosity.
Hebinho in reply to pfred2Mar 1, 2011. 5:37 PM
Just another case of practical use of Stirlings:
http://www.mackboring.com/CMFiles/Docs/Product_Brochure.pdf made by http://www.whispergen.com
Btw: When I experimented with battery-operated tubes in 1960,integrated circuits also were just a curiosity. SMD LEDs emitting white light and 1 W of power, nobody had an idea that this will be realized! Or do you really believe that the kind of camera module you will find in modern smart phones (1 sqcm incl. "flash LED" and 3 MP resolution) could have been dreamed of in the early seventies?
For the last decade the rule has been, that technological knowledge at university level has doubled every 5-6 years at an accelerating tendency.
Just wait less than a decade and you will see, what development Stirlings will go through. Or maybe someone really will show the proof of overunity engines .... ;-)
Greetz from Brazil!
pfred2 in reply to HebinhoMar 2, 2011. 6:45 AM
Technologies with merit often develop rapidly as you point out. So I'm sure any time now someone will crack this nut of the Stirling Engine that has been around since 1816. Indeed the world waits with bated breath for the discovery of perpetual motion!
http://en.wikipedia.org/wiki/Perpetual_motion
Too bad they only work if you lubricate them with snake oil. But until such a day they are curiosities at best I'm afraid.
komodoboyx5 in reply to pfred2Mar 4, 2011. 6:23 PM
too bad your diesel generators only work if lubed up in oil, and run on dead ancient plants (which are running out, surprisingly)
pfred2 in reply to komodoboyx5Apr 7, 2011. 3:46 PM
Not in my lifetime they won't.
pfred2 in reply to komodoboyx5Mar 5, 2011. 8:01 AM
Too bad you're wrong on all accounts.
pfred2 in reply to VengenceFeb 27, 2011. 6:36 PM
Ah yes California, the state that is such a shining example of efficient success. Good for Silly Energy Systems ripping off gullible liberals! I'm all for it.
SydAndy in reply to pfred2Mar 1, 2011. 3:34 AM
And here your politics come out. I guess you don't believe in global warming either.
You said above an Overwhelming number? 20 years ago there were far more petrol cars by comparison to today, does that mean they are better technology?
No, and they are worse for the environment. That is why despite the best efforts of the car companies there are more electric/hybrid/more efficient cars today.
What is the combined engine size of your cars?
pfred2 in reply to SydAndyMar 1, 2011. 4:15 AM
Global warming? Didn't your tree hugger buddies send you the memo? Global warming is out today, now you're supposed to say Global Climate Change! I see insufficient proof that human activity is related to any change in the planet's climate. Those politics sound like nothing but hot air to me.
I've heard of no effort made by any car manufacturer to block the development or manufacture of electric or hybrid vehicles. Though many are resistant to fuel economy regulation that would strain their business.
Like many people today I own more trucks, SUV,s and vans than passenger vehicles. I'm down to just one car now. It is a 2.2L it does have 2 dual 45mm Weber sidedrafts on it though if that helps you out any :)
SydAndy in reply to pfred2Mar 6, 2011. 6:12 PM
Yes, climate change is the correct term. Try this little experiment. Get a 10m * 10m * 10m sealed glass box.
Take in your diesel generator, and an electric heater/fan.
All the food you want.
Now stay in there for two weeks. I wonder how long you could last in such a micro-climate. Maybe you will see that we *do* have an impact?
Now in mine I will have translucent solar cells on the roof and lots of trees inside, emulating the planet before man, a little.
Which would you prefer? Which could you survive in!?
How many trucks vans etc do you own!? The biggest engine in any vehicle I have ever owned is 2L.
pfred2 in reply to SydAndyMar 6, 2011. 8:40 PM
If you wish to live in a 10x10 box be my guest I've acres here to keep my fleet of 4 vehicles on. The smallest of which is larger than 2L.
Vengence in reply to pfred2Mar 3, 2011. 4:52 AM
[pfred2: I've heard of no effort made by any car manufacturer to block the development or manufacture of electric or hybrid vehicles.]
You must not have seen the documentary "Who Killed the Electric Car". It's been on the Discovery channel a few times. Basically GM is responsible for NiMH batteries essentially(not formally) being banned from use in electric cars. GM used to own the patent, now Chevron does...
pfred2 in reply to VengenceMar 3, 2011. 5:12 PM
Don't cars use Lithium Ion batteries? I know they're my favorite rechargeable battery technology today. Even it is inadequate for a vehicle though. We'd be better off limping down the road running Stirling engines than electric cars! I guess it is a good thing that they put diesel engines into the better hybrids.
Vengence in reply to pfred2Mar 5, 2011. 5:35 AM
You said "I've heard of no effort made by any car manufacturer to block the develpment or manufacture..." and I was pointing out that it most certainly has happened, making you wrong yet again(and again, and again). How is anything else you said realevent? Do you have ADD, or do you feel like typing any random thing after you're wrong makes you feel right?
pfred2 in reply to VengenceMar 16, 2011. 8:42 AM
Hurber durber dupditty do wa wah wa wah wa wah
SydAndy in reply to pfred2Apr 7, 2011. 7:31 AM
Wow, that is his most intelligent response yet!
SydAndy in reply to VengenceMar 6, 2011. 6:03 PM
Good call, and thanks for coming in with the movie, I have been busy!
Vengence in reply to pfred2Feb 27, 2011. 6:56 PM
There's no info or facts at all in your response. Is that all you got is a dumb opinion as a comeback? How does anything you've said add/prove/disprove anything on the subject? That's one of the most useless posts I've read in a while...
pfred2 in reply to VengenceFeb 27, 2011. 8:26 PM
Fact is satire eludes you.
pfred2 in reply to juanviFeb 27, 2011. 7:17 AM
juanvi in reply to pfred2Feb 28, 2011. 1:40 PM
thanks, I hope I can build one of these (the low temperature difference one)...but for now, I'm building yours ;)
thanks!
komodoboyx5 says: Mar 4, 2011. 6:29 PM
Just realize that this power source it a very viable power source.
After all, it's simplicity provides a very simple source of power and makes it very efficient.
Hobby to you or not, theres great possibilities in this machine.
I'm sure the wheel was just pushed around for giggles and grins before someone realized they could use that thing.
PKM (author) in reply to komodoboyx5Mar 5, 2011. 4:03 AM
It is beautifully simple, yes, but (in this scale) not really efficient or viable.
The temperature a stirling engine runs at determines how much of the heat you put in gets converted to work output- its efficiency.  For a commercial solar-powered engine, that might be 25%, but for the low temperature engines that run from the heat of someone's hand it's below 1%.
The useful output of an engine like this might be enough to run a few LEDs or a radio but it's never going to power your house.  There are more efficient, less junky engines around which can produce useful amounts of power but they need a machine shop to build and a wood stove or large solar dish to power them, not a few candles.
alexsparrow says: Feb 27, 2011. 2:16 PM
try using some silicon caulking instead of the epoxy- let me know how it turns out
Biotele says: Feb 27, 2011. 12:49 PM
harddisks make excellent flywheels.
79spitfire says: Feb 27, 2011. 9:25 AM
That is soo cool!
askjerry says: Feb 27, 2011. 8:31 AM
It doesn't matter how you built it, the details are not important to me. I just like the mix of techno-hillbilly-steampunk that sort of works. It makes this ka-chunk noise that is both annoying and kool at the same time... the kind of thing that gives you great pleasure and annoys the family cat.
Two thumbs up!
Jerry
steveastrouk says: Feb 27, 2011. 7:43 AM
Nice job
rimar2000 says: Feb 25, 2011. 7:16 AM
Very nice Stirling motor!
jam BD says: Feb 25, 2011. 5:52 AM
Interesting approach with an added cross beam. Very good ible.
Eye Poker says: Feb 24, 2011. 9:06 PM
Now just add a fresnel lens and you can generate enough power to take over the world.
Dr Qui says: Feb 24, 2011. 7:09 PM
Oh very nice indeed.  Hats off to you sir (stands back, nods and lights pipe) 5 stars.
Get it entered in the 3rd Epilog Challenge.
I am in the process of gathering parts to built a large sterling something like this to run off my wood stove, I have my second VCR just ready to crack open to see what goodies are inside.
My solenoid beam engine is a practice piece before I attempt to build a flash aluminium sterling.
Can you post any info more info or links to the design as this looks exactly the kind of design i have been looking for, I really like walking beams.
Phil B says: Feb 24, 2011. 6:15 PM
Thank you for a very nice Instructable. Stirling engines are interesting, and I would like to learn more about them. Your Instructable provided some information I have not seen in others on a Stirling engine. You also have some very clever adaptations of common items. I had the thought that layering three or four CDs would probably also give you more mass for the flywheel.
Mudbud says: Feb 24, 2011. 5:30 PM
Wow, definitely one of the nicest Stirling engines on instructables :) Awesome job.
zazenergy says: Feb 24, 2011. 4:34 PM
That's very cool! Thanks for sharing :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
