Tinder Caps - the Bottle Cap Tinder Stash
Introduction: Tinder Caps - the Bottle Cap Tinder Stash
Any fellow pyromaniacs will know that frustrating feeling you have when you want FIRE!!! but have no tinder to kick the thing off, Well this project is simple cheap and requires no tools just some bottle caps, string and your chosen tinder
Step 1: Equipment
For this you will need:
- 2x Bottle Caps
- 1x length of string (around 5 cm)
- 1x a small bundle of tinder ( For this i am using silver birch bark
- 1x small portion of super glue if wanted (not required)
Step 2: Primary Cap Prep
Firstly take the first of your Bottle Caps and mark it with a sharpie on the inside just for later reference.
     Then start pushing the outer circle (the bit that grips the lip of the bottle) inwards this is the fiddly bit because it needs to be able to fit snugly inside the second unaltered (once of the bottle) bottle cap, It should create a friction fit to the second Cap but before you lock the two in place you need to do the next step.
Step 3: Tying Up Loose Ends
     Now take 5cm string, for mine i used 550 paracord but in the photo's it is just regular string, personally i'd go with paracord for its durability .
     Now tie a knot in each end and place both ends next to each other in the bottom of the Marked Bottle Cap on top of which you will place your tinder.
Step 4: Adding the Tinder
      As the title says now we add the tinder, cram as much as you can on top of the cord in the smaller bottle cap and keep cramming until you reach a nice solid lump of tinder.
Step 5: Two Halves Make a Whole
      Now place the bigger unaltered Bottle cap on top of the smaller one trapping the tinder and string inside and leaving you with a nice lanyard to attach it to your keychain or kit.
      Now this might not hold in place if you have made the inner cap too small so this is where the wonders of glue come in, use it sparingly and just 3 spots evenly spread out across the caps in the gaps, you could go all the way round for waterproofing but it might be harder to open so just a thin layer should do it.
     And you're done and ready for fire anywhere and anywhen, Please Vote if you like it, personally i think it's great but i may be a tad biased, Anyway thats all for this instructable, check out my others and remember ALWAYS know where your towel is.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
