Tinkertrons: Make Artificial Neurons for Robots
23,020
127
17
Published
Introduction: Tinkertrons: Make Artificial Neurons for Robots
About: I believe that the purpose of life is to learn how to do our best and not give in to the weaker way.
Tinkertrons are an attempt to make a cross between a circuit board and a bread board--a kind of universal circuit. These plug and play circuits are designed to be easily assembled and interfaced like tinker toys. They are designed to be easy to rearrange and interconnect. Any Tinkertron can communicate with any other Tinkertron in several ways and the interface allows for parallel processing.
The goal is to create a crude approximation of living neurons and to discover a neural network that is more effective than standard circuits and the standard programming used to control robots.
Pic 2 shows the first real world test of a soft robot arm that is controlled by robot neurons. To see a video and instructable on the robot you can go here: https://www.instructables.com/id/Soft-Robots-Make-An-Artificial-Muscle-Arm-And-Gri/
Step 1: Tinkertron Neural Network
Step 1 pic shows a diagram of the Tinkertron neural network. The illustration was made using an excellent free program called Scheme-It. Available from Digi-Key: http://www.digikey.com/schemeit
The Tinkertron schematics were also made with this program.
Robot Neurons
Robot neurons can communicate with each other by serial or I2C protocols. They each have infrared LED's which can signal their status to the programmer or to other neurons with receivers. They also have any available input/output pins connected to header sockets which can be used to directly connect to any other neurons with 24 gauge wire.
Types of Neurons
At this point there are three main types of Tinkertron neurons:
1. Sensor neurons that interface with different sensors such as switches, compasses, infrared sensors, etc.
2. Master neurons that poll sensors, decide on responses and tell the actuator neurons what sequences of outputs to activate.
3. Activator neurons are all different. Each is designed to activate a stepper motor, regular motor, servo, LED's, or other device. They receive serial commands and do whatever the master neurons tell them to.
Additional Circuits
Each neuron has four header sockets at a diagonal that are used to program the Picaxe processors. Additional circuits such as memory, display, infrared receivers, or others, can be attached here.
Step 2: How They Work
Research into neurons has gone on for decades and so far no one as been able to reverse engineer the circuit of a neuron. No one knows exactly how neurons communicate with each other or how the neural networks in living things work. There are an abundance of theories and prototypes, but no one has a working model that works as well as real neurons.
Another way to research it, is to try and emulate as many of the known qualities of neurons and use existing micro-controllers to try and discover neural networks that work in the real world. That is what I am attempting.
Tinkertrons are designed to be easily connected and reconfigured in any combination to create refined circuits that roughly emulate animal neurons. When connected together, they transfer power and two lines of serial communication through the header sockets on four sides and top and bottom. They also each have infrared transmitters that allow them to communicate with the outside world or any neuron in the local vicinity. A visible Led also communicates that there is power and that the micro-controller and program loop is working.
Picaxe micro-controllers were chosen for the robot neurons because they are small, inexpensive, and easy to program. They also require a bare minimum of additional parts to be fully functional.
This instructable is mainly about the architecture of Tinkertrons and the robot neural network. After I build a robot that is controlled by Tinkertrons, I will try and publish the working code for it.
Step 3: Materials
.1" Machined pin sockets and headers from Mouser: http://www.mouser.com/
Picaxe micro-controllers from Phanderson: http://www.phanderson.com/picaxe/
The best price in the US for Picaxe
Resistors,diodes, and LED's and 30 gauge magnet wire from Mouser: http://www.mouser.com/
SOLDER-ABLE PERF BOARD, LINE PATTERN from Allelectronics: http://www.allelectronics.com/make-a-store/item/ECS-4/SOLDERABLE-PERF-BOARD-LINE-PATTERN/1.html
Step 4: Sensor Neurons for Robots
Sensor Neurons are designed to interface with different sensors such as switches, compasses, infrared sensors, etc. They work by constantly checking a sensor or sensors and recording the sensor value in a variable. When it receives a serial or other command from the master controller, the sensor neuron gives the value to the master.
I used fiberglass perf board with a pre-etched line pattern to make quick permanent circuit boards. Details on this method can be found here: https://www.instructables.com/id/Picaxe-Projects-1-Making-Fast-Printed-Circuit-Mo/
Step 5: Sensor Neuron Schematic
The schematic was quickly made using a free, very easy to use program called Scheme-It. Available from Digi-Key: http://www.digikey.com/schemeit
Its only drawback is that you have to be online to load it or save a file.
Step 6: Master Neurons for Robots
Master neurons poll all of the sensor neurons, determine the importance of what is sensed and then decide on responses. They then tell the actuator neurons what sequences of outputs to activate.
Master Neuron Code
The actual code of a master neuron depends on the robot  that is being controlled. My first real world use is using tinkertrons to control an air muscle robot controller. For details on how to make the controller, see here: https://www.instructables.com/id/Air-Muscles-Make-an-Artificial-Muscle-Robot-Contr/
Here is the code used in the master neuron of the air muscle robot controller that controls two activator neurons:
'20m2 master neuron
b1=1
pause 100
serout c.0,t4800,(1,11)  'open intake
pause 40
pause 40
serout c.1,t2400,(170,9,$0C,127) 'clock m1 24-127, 84-2/3 speed
pause 100
loop1:
low c.7
'    debug b1
irin [1000,loop1],b.5, b6
if b6 = 0 then send1 'button1=0
if b6 = 1 then send2
if b6 = 2 then send3
if b6 = 3 then send4
if b6 = 4 then send5
if b6 = 5 then send6
if b6 = 6 then send7
if b6 = 7 then send8
if b6 = 8 then send9
if b6 = 9 then send10
if b6 = 59 then send11  '(-)
if b6 = 11 then send12  'enter
if b6 = 14 then send13  'guide
if b6 = 21 then send14  'power
if b6 = 16 then send16   'ch+
if b6 = 17 then send17   'ch-
if b6 = 116 then send116  'back
if b6 = 117 then send117  'forw
if b6 = 52 then send52   'left
if b6 = 51 then send51   'right
if b6 = 18 then seq1     'arm down
if b6 = 19 then seq1rev     'reverse arm down
goto loop1
send1:
'serout c.0,t4800,(1,13) 'guide
'pause 40
serout c.0,t4800,(1,1) 'send 1 byte with 1, as qualifier
pause 40
goto loop1
send2:
serout c.0,t4800,(1,2)
pause 40
goto loop1
send3:
serout c.0,t4800,(1,3)
pause 40
goto loop1
send4:
serout c.0,t4800,(1,4)
pause 40
goto loop1
send5:
serout c.0,t4800,(1,5)
pause 40
goto loop1
send6:
serout c.0,t4800,(1,6)
pause 40
goto loop1
send7:
serout c.0,t4800,(1,7)
pause 40
goto loop1
send8:
serout c.0,t4800,(1,8)
pause 40
goto loop1
send9:
serout c.0,t4800,(1,9)
pause 40
goto loop1
send10:
serout c.0,t4800,(1,10)
pause 40
goto loop1
send11:   '(-)
pause 40
goto loop1
send12:   'enter
serout c.0,t4800,(1,12)
pause 40
goto loop1
send13:   'guide
pause 40
goto loop1
send14:   'power send 21
serout c.0,t4800,(1,21) 'send 21
pause 40
goto loop1
send16:   '
serout c.0,t4800,(1,16)
pause 40
goto loop1
send17:   '
serout c.0,t4800,(1,17)
pause 40
goto loop1
send116:   '
serout c.0,t4800,(1,116)
pause 40
goto loop1
send117:   '
serout c.0,t4800,(1,117)
pause 40
goto loop1
send52:   '
serout c.0,t4800,(1,52)
pause 40
goto loop1
send51:   '
serout c.0,t4800,(1,51)
pause 40
goto loop1
seq1:   '
serout c.0,t4800,(1,18)
pause 40
goto loop1
seq1rev:   '
serout c.0,t4800,(1,19)
pause 40
goto loop1
Step 7: Master Neuron Schematic
A 20M2 or 20X2 Picaxe micro-controller is used for the master neuron.
Step 8: Actuator Neurons for Robots
Actuator Neurons receive serial communication or direct pin communication from the master neurons. They then directly activate motor, servos, LED's or other actuators or displays. Or, they can also control motor drivers, servo drivers, or other driver circuits.
They can vary in size and shape depending on the circuitry required.
The actual code of an actuator neuron depends on the robot  that is being controlled. My first real world use is using tinkertrons to control an air muscle robot controller. For details on how to make the controller, see here: https://www.instructables.com/id/Air-Muscles-Make-an-Artificial-Muscle-Robot-Contr/
Here is the code used in the two activator neurons of the air muscle robot controller that controls 11 air muscles. They are parallel processing:
'18x activator neuron one
low 1
low 2
low 3
low 7
low 6
low 5
low 4
loop1:
'serin 0,t4800, b1
serin 0,t4800,(1),b1 'receive 1 byte after receiving 1
pause 30
'debug b1
if b1 = 1 then act1
if b1 = 2 then act2
if b1 = 3 then act3
if b1 = 4 then act4
if b1 = 5 then act5
if b1 = 6 then act6
if b1 = 7 then act7
if b1 = 16 then pressurev1v2
if b1 = 17 then vacv1v2
if b1 = 116 then back
if b1 = 117 then forw
if b1 = 52 then left
if b1 = 51 then right
if b1 = 18 then seq1 'arm down
if b1 = 19 then seq1rev 'reverse arm down
goto loop1
act1:     'v1
high 1
pause 20
low 1
goto loop1
act2:    'v2
high 2
pause 20
low 2
goto loop1
act3:
high 3
pause 20
low 3
goto loop1
act4:
high 7
pause 20
low 7
goto loop1
act5:
high 6
pause 20
low 6
goto loop1
act6:
high 5
pause 20
low 5
goto loop1
act7:
high 4
pause 20
low 4
goto loop1
pressurev1v2:    'ch+
high 1     'v1 arm down
high 2      'v2
pause 800
low 1
pause 1500
low 2
high 1
high 2
pause 700
low 1
low 2
pause 60
high 4      'v7
pause 1440
low 4
pause 20
'goto loop1
pause 1600  'close gripper
high 1   'v1 up arm
high 2   'v2
pause 2200
low 1
low 2
            'arm left
high 5     'v6
pause 1200
low 5
            'arm down
high 1   'v1
high 2   'v2
pause 800
low 1
low 2
goto loop1
vacv1v2:   'vac   ch-
pause 3000
high 1   'v1  vac valves
high 2   'v2
high 6   'v5
high 5   'v6
high 3
high 7
pause 3500
low 1
low 2
low 6
low 5
low 3
low 7
pause 20
high 4   'v7
pause 3000
low 4
high 1    'release vac inline
high 2
high 4
high 6
high 5
pause 2000
low 1
low 2
low 4
low 6
low 5
high 3
high 7
pause 1000
low 3
low 7
goto loop1
back:
high 1
pause 2000
low 1
goto loop1
forw:
high 3
high 4
pause 1000
low 3
low 4
goto loop1
left:
high 1
high 3
pause 20
low 1
low 3
goto loop1
right:
high 2
high 4
pause 20
low 2
low 4
goto loop1
seq1:
      'close gripper
pause 1600
goto loop1
seq1rev:  ' open gripper
pause 3000
goto loop1
'18x activator neuron two
low 1
low 2
low 3
low 7
low 6
low 5
low 4
loop1:
'serin 0,t4800, b1
pause 30
'debug b1
if b1 = 1 then act13
if b1 = 2 then act13
if b1 = 3 then act13
if b1 = 4 then act13
if b1 = 5 then act13
if b1 = 6 then act13
if b1 = 7 then act13
if b1 = 8 then act8
if b1 = 9 then act9
if b1 = 10 then act10
if b1 = 11 then act11
if b1 = 12 then act12
if b1 = 13 then act13
if b1 = 14 then act14
      if b1 = 116 then g1000
if b1 = 117 then g1000
if b1 = 52 then act13
if b1 = 51 then act13
      if b1 = 21 then powervac5
goto loop1
act8:
high 1
high 5
pause 20
low 1
low 5
goto loop1
act9:
high 2
high 5
pause 20
low 2
low 5
goto loop1
act10:
high 3
high 5
pause 20
low 3
low 5
goto loop1
act11:  'v11 intake
high 7
goto loop1
act12:
high 6
high 5
pause 20
low 6
low 5
goto loop1
act13:
high 5
pause 20
low 5
goto loop1
act14:   'stop
high 4
pause 5000
low 4
goto loop1
powervac5:   'power vac 5 sec
low 7     'up arm    intake off
high 6
pause 5000
high 7
low 6
goto loop1
pressurev1v2:     'ch+
high 5     'arm down
pause 3160
high 1     'v8
pause 1200
low 1
pause 200
'goto loop1
high 2    'close gripper
pause 1000
low 2
high 3     'grip
pause 600
low 3
low 5
high 6    'vac in
high 1  'v8
pause 20
low 1
pause 2200    '2800
high 7
low 6
low 1
         'arm left
low 7     'intake off
high 6    'vac in
high 1  'v8
pause 1200
high 7
low 6
low 1
       'arm down
high 5  'press
pause 800
low 5
goto loop1
vacv1v2:    'ch-
low 7     'intake off
high 6    'vac in
high 2   'open gripper
pause 1500
high 3   'grip
pause 1500
high 1  'v8
pause 3520
pause 3000
low 6
high 7
low 1
high 4   'release vac inline
high 2
high 3
high 1
pause 2000
low 4
low 2
low 3
low 1
pause 1000
goto loop1
g1000:
low 7
high 6
pause 2000
high 7
low 6
goto loop1
seq1:
high 5
pause 1500
low 2
high 3     'grip
pause 600
low 3
low 5
goto loop1
seq1rev:
          'open gripper
low 7     'intake off
high 6    'vac in
pause 1500
high 3   'grip
pause 1500
low 2
low 3
high 7
low 6
goto loop1
Step 9: Other Possibilities
Circuits That Fit Curved Surfaces
The step 8 pic shows how 24 gauge wires can be used to join Tinkertrons so that they can fill odd volumes or curved surfaces.
Making Smaller Neurons
Much smaller neurons can be created using surface mount technology. I built these in a larger size to make them faster and easier to make. I can also more easily redesign the circuits as I experiment with them.
Robot Challenge
Finalist in the
Robot Challenge
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    17 Comments
    Just do the same with the code. Inputs are rated Good, Bad or Dont' care. If input A is good, do this if bad do something else. Each module will rate the input signal an make decisions based on them .Will get us closer to an autonomous robot.
    Hi love the idea could you put up a schematic of the actuator
    Regards
    Peter
    Hi sorry Ive just found the schematics
    Regards
    Peter
    Would like to make a couple of these at some point,awesome idea and easy to follow designs.
    Amazing concept, do you have a schematic for the actuator neuron? It seems like those are two 18x picaxes on there.
    If it was air conditioning or plumbing i could do it but these schematics scare me lol
    replace valves with transistors, little diameter pipes with resistors and surge tanks with capacitors, and you're half way there :)
    Hmm... If one was to build enough of these to be able to teach the robot to build more... assuming it had enough resources, I wonder how long it would take for it to either A) reach the functional capacity this design can support (likely due to attenuation from the wires), or B) gain sentience.
    Interesting question. And how long until terminator?
    Or, more disturbingly, Replicators...
    Yes, but which would be more disturbing, Pegasus Replicators or Milky Way Replicators? In any case, so long as we 1, leave out all agression programming (meaning don't try to make them weapons) and 2, don't piss off the AI they view as "mom", I think we'll be ok.
    Realistically speaking using an AI program to have conversations combined with a humanoid robot such as the ASIMO is possible. However there are complications with the 'sentience' part.
    Using a few instructables from this site and innovative thinking it is possible to use human motion fed into AI program to a humanoid robot and mimic the movements to become its own. this theoretically can help get a robot standing again if it falls over or prevent it from falling in the first place.
    this is a good link for the idea of moving and mimic. all you have to do is wear a suit with movment and flex sensors
    http://www.youtube.com/watch?v=BQw1tsgrJOs
    if you use the neurons from this instructable and replicate muscles from
    https://www.instructables.com/id/How-to-make-air-muscles!/
    it entirely possible to make a human like arm too mimic human movment. however compressed air could be a difficulty it could be converted to using distilled water and a pumps.
    using
    https://www.instructables.com/id/Conductive-Rubber-Make-Touch-Sensitive-Robot-Skin/
    you can create synthetic 'feelers' or a skin around your humanoid robot as well as temptature sensors. plug the receptors into the neuron chips and you could even put in a bypass in case it touches a spike in temptature to react with out signals having to go to the main processing unit. (kind of like the human reflex.)
    all of these together could get you somewhere close to your terminator all you have to do is program a goal for it to complete.
    So to answer your question budhaztm, it is getting closer.
    Thank you for your contribution.
    I do not understand why you used a .sch file which I and most people don't know how to open without a special program.
    If you sincerely want to share, you could simply post a JPEG.
    Lots of work goes into this.....   .   .   .     A
