Tiny 9V Clip Flashlight! by Radioactive_Legos
Contest WinnerFeatured
A couple of weeks ago, I had the idea to make an LED flashlight that would sit on top of a 9-volt battery clip, but would run on one of those 2 x AA holders with the 9V clip attachment. Well, I made it and documented the process and was very happy with the finished product. It can be used for finding your way in the dark, looking for that box of batteries you know you left in your closet, or better yet, (by adding a toggle switch) it can be used on your bike or scooter when riding home at night. The pictures of the light with a 9V battery are just for ease of recognition, I guess.
Step 1: Stuff You'll Need
For some people, getting the materials for this light will be as easy as looking around your desk. For others, most all the parts can be easily obtained at RadioShack or somewhere similar. The things you'll need are:
- A 9-volt battery clip like the one shown
- A tactile switch*
- A non-diffused LED in the color of your choice
- A resistor to fit the requirements of your LED**
- A little holder for your LED***
- A battery****
- Soldering iron w/ solder
- Hot glue gun w/ glue
*You can salvage these out of tons of electronics. Listen for the buttons that make that characteristic 'click' sound when you press them
**Resistance equals Voltage divided by Amperage (R=v / i)
***Optional. If you want one, you can buy one, or you can make one, or you can get one out of disposable cameras as the holder for the neon lamp (that's what I did)
****A 9-volt works okay, but it may overpower your LED. You may want to try those 2 x AA holders with the 9-volt style clip on top from Radioshack that I talked about earlier.
TheWelfareWarrior says: Nov 10, 2008. 4:07 PM
Red is better because it doesn't effect "night blindness" nearly as much as blue, or green. Thats why they use red when submarines go into "combat mode" or whatever...
Radioactive_Legos (author) says: Nov 10, 2008. 4:50 PM
good point!
PKM says: Nov 11, 2008. 9:53 AM
Alternatively, superbright white is good. At the price I guess these cost, why not build one of each? If you were using 9V then you could stack two or three LEDs in series to get the most out of your battery.
Radioactive_Legos (author) says: Nov 11, 2008. 10:12 AM
Good idea about multiple LEDs. I actually had a white one with me at the time, I just didn't want to use it and glue it in because they are so valuable. Thanks for the feedback!
mweston says: Nov 11, 2008. 12:31 PM
Your LED holder also looks like it is east to change out diodes, so you could do that, or even get a multicolor LED and add a 3 position switch so you can control the colors by the flick of a switch... Cool project anyway!
Kiteman says: Nov 11, 2008. 3:15 PM
Nice project. Good to chuck in the glove compartment.
GENERALCHAOS says: Jul 21, 2010. 4:32 PM
lol u call that messy u sould look at my desk now thats messy
DELETED_craz meanman says: Dec 21, 2008. 5:48 PM
(removed by author or community request)
atombomb1945 says: Nov 29, 2009. 7:48 AM
I like your four LED version of the 9v flashlight.  What resistor did you use on it?  I am thinking of something similar and was curious.
serith says: Nov 27, 2009. 12:20 PM
 how many amps are in a 9v batt.?
or, even better, how many ohms does it take to reduce a 9v batt. to a 3v batt.?
dark sponge says: Nov 18, 2008. 7:12 PM
I made a couple of these a long time ago. I used super bright white leds and didn't bother to include a switch. by the way, DON'T waste your money on 9v clips! Just dissasemble an old 9v battery and use the top of it as clip. You also get a nice metal case for other small projects and six AAAA batteries.
duckythescientist says: Sep 26, 2009. 4:25 PM
I have done the 9v clip thing before to great success. I needed a smaller clip for a altoids amp. Saving space with that clip was necessary to get a 9v battery, a half watt speaker, two potentiometers, a toggle switch, a headphone jack, a 1/4" male plug, an LM386 amp and circuit, a 2N2222 preamp, and a blue led into one altoids tin.
Plusea says: Nov 19, 2008. 6:45 PM
that is a great idea. i'd never thought of that.
technodude92 says: Nov 20, 2008. 4:20 PM
the AAAA batteries are only in certain brands of 9v batteries I know Duracell has them. Other brands is hit and miss but at any rate you still get the 9v clip.
dark sponge says: Nov 20, 2008. 5:11 PM
Energizer also. But I have a big pile of dead AAAA batteries that I might never use. I have only taken apart dead 9v batteries so the AAAA batteries I get are dead also =(
Tommyhzy says: Aug 18, 2009. 4:16 PM
Most dollar store brands are layered acid cakes... But I'd go with Energizer or Rayovac because Duracell goes cheap with some batteries (Particularly 6v lantern batteries) Woohoo I replied to a prehistoric conversation!
DIY-Guy says: Oct 28, 2011. 11:50 AM
Heh! Prehistoric conversation.
Due to the nature of the net, each set of comments is fresh for each reader down through history. And if we get to interject with a fresh post, the conversation has become time independent. Sort of like multitasking with long breaks between texting.
Nice comment about the brands with AAAA's inside of them, very usefull!
dark sponge says: Aug 18, 2009. 8:04 PM
Bumping topics is fun!
Tommyhzy says: Aug 19, 2009. 6:59 AM
firecracker125 says: Sep 22, 2009. 5:31 PM
good work
chuckr44 says: May 13, 2009. 7:51 AM
How long does it take to charge the caps? How do I know they are charged when I put my battery on the terminal?
james.mcglashan says: May 1, 2009. 3:04 AM
i might make this but smailer with 2 wires in a heat shrink tube and then add to a project pox with a curcit behind the leds power and a nice toggle switch in the box so i can use a simple regulator and 9volt ac-dc power plug... who thinks that would be handy for many leds arround my soldering stationg so i can light up my solder from all angles for beta easer soldering???
knexsuperbuilderfreak says: Apr 24, 2009. 3:42 AM
hmmmm good job but can i use a switch instead of a button?
james.mcglashan says: May 1, 2009. 3:01 AM
thats verry easy it only needs the power conecting with the led and resistor so u can easly do as with ease.
pyroten says: Apr 24, 2009. 4:30 AM
course u can. just replace the tactile with a toggle or whatever
knexsuperbuilderfreak says: Apr 24, 2009. 1:56 PM
ok thanks
Learndy says: Apr 5, 2009. 1:01 AM
You can even make the flash light smaller by using a smaller battery. There are some instructables on LED throwies showing how.
And if you use some Joule Thief circuitery you can use a regular AAA or AA battery. Or a supercap. Have a look at http://www.instructables.com/id/Flashlight_Without_Batteries_from_the_book_quot/ where you can find a schematic for that. Yes, I've tested it with two super bright white LEDs running on a single AA cell!
Airspace V - international hangar flying!
http://www.airspace-v.com/ggadgets for tools & toys
james.mcglashan says: Apr 4, 2009. 11:27 PM
y not just make it a 9volt battery volt changer so when u change the batter amount of power gong through it...
Thaikarl says: Nov 24, 2008. 11:40 PM
strangely enough, just after reading this Instructable, i was at a dollar store and found this light. it has some weird gravity switch (the blue thing in the picture) that turns the light off when it's on it's side (tends to flicker alot tho) but it has all the ingredients in this instructable, except the switch... for 99 cents!
mspark400 says: Mar 6, 2009. 1:09 PM
Was the store called odd lot or something because i saw those and got a bunch lol great ible' cheers, mspark400
11010010110 says: Nov 11, 2008. 10:57 AM
2 things to make it simpler and cheaper 1 disassemble a dead 9 V battery for the clip and dont buy one 2 how to avoid the switch (making it less reliable - may light up unintentionally if placed in pocket etc) unfold the 'flower' on the clip (that goes to battery +) with pliers and hammer it to make it absolutely flat. now connect the LED without switch at all when you just put it on the battery there is tiny space between it and the + and it does not light. when you press it lights if it tends to light all the time insert a piece of plastic packaging foam in the battery + so it sticks out a bit and prevents accidental contact
raykholo says: Feb 16, 2009. 7:58 PM
i like the original idea with a tact switch more...
DYLEGO says: Jan 25, 2009. 9:51 AM
that will definitley light in your pocket, not a tact switch.
11010010110 says: Jan 26, 2009. 2:38 AM
the piece of styrofoam prevents it from doing that
DrWeird117 says: Jan 24, 2009. 10:05 PM
My switch won't close the circuit. : (
ledsales says: Dec 4, 2008. 3:50 PM
I love simple ideas like this, is one of the reasons I did them as a kit a few years back, if anyone's interested, see www.ledsales.com.au
billytwix says: Dec 4, 2008. 11:56 AM
sweet but this idea is already patented, and used by the us military http://www.9voltlight.com/
that dollar store one looks interesting/cheezy but its a dollar. i hope it lasts a while for the money...
cool use of the double-AA's. and i love the hand puppet!
joedog86 says: Nov 26, 2008. 7:02 AM
Radioactive_Legos (author) says: Nov 26, 2008. 4:37 PM
Those are cool!
Colonel88 says: Nov 26, 2008. 1:32 PM
sweet. but i have a rather hard to glue switch.im thinkin between making this or another one. I have a strong led and dont want to waste it
1up says: Nov 23, 2008. 11:13 AM
This is so awesome. :D I'm gonna build one with a bigger resistor so it can run from a 9v battery!
GitarGr8 says: Nov 25, 2008. 8:06 AM
Or just hook up multiple LEDs in series to eat up the extra voltage.
1up says: Nov 25, 2008. 9:39 AM
Good idea. ;)
Sandisk1duo says: Nov 10, 2008. 10:49 PM
Yay salvaging!
Radioactive_Legos (author) says: Nov 11, 2008. 12:09 AM
w00t!
hot-fresh-rider says: Nov 21, 2008. 4:15 AM
FTW !!
Chris Tucker says: Nov 14, 2008. 10:41 AM
"disassemble a dead 9 V battery for the clip and dont buy one"
Buy a Duracell and dissemble it. You get the battery clip and a set of AAAA batteries, as well. Each with (after you carefully cut them in the middle) a handy soldering tab on each end.
jedi pen-gui-n says: Nov 20, 2008. 1:04 PM
the energiser 9v batterys are not wrapped together and the 9v clip is stronger i don't know about others
Yerboogieman says: Nov 19, 2008. 6:47 AM
l like this, its very clean and nice.
Arbitror says: Nov 18, 2008. 4:15 PM
This is really awesome!
qs says: Nov 14, 2008. 2:33 PM
Check out this 9-volt battery powered LED circuit here which I've been building since 2007
Also: my other LED circuits: http://www.quantsuff.com
lowbike1 says: Nov 11, 2008. 9:36 PM
you can buy these at The source here in Canada... I like your idea of making your own though.
Rob K says: Nov 11, 2008. 4:10 PM
I am going to make something like this with some of my new LEDs soon.
LED Specs
  • 0.5W
  • 55K mcd at 140*
  • 3.2-3.6 fV at 100ma
First pic is one and a cellphone battery pointed at the camera. second pic is what they look like compared to a 3mm LED.
Radioactive_Legos (author) says: Nov 11, 2008. 5:17 PM
Sweet!
Rob K says: Nov 11, 2008. 8:48 PM
Well 6 of those using a 9v not on a battery clip :)
paulomichael says: Nov 11, 2008. 6:24 PM
nice work, radioactive_legos!
geeklord says: Nov 11, 2008. 4:40 PM
Is there any REAL difference putting resistors or switches on the cathode of an LED?
Not that I know of. If you are referring to when I said to check the polarity, I just meant that one lead off the battery clip should go from switch to resistor to LED, and the other should go directly to the LED. Hope this clears up any confusion!
JellyWoo says: Nov 11, 2008. 2:10 PM
cool!
Plasmana says: Nov 11, 2008. 1:40 PM
That is really cool!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
