3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tiny AVR Microcontroller Runs on a Fruit Battery
Some of the fruit and vegetables we eat can be used to make electricity. The electrolytes in many fruit and vegetables, together with electrodes made of various metals can be used to make primary cells. One of the most easily available vegetable, the ubiquitous lemon can be used to make a fruit cell together with copper and zinc electrodes. The terminal voltage produced by such a cell is about 0.9V. The amount of current produced by such a cell depends on the surface area of the electrodes in contact with the electrolyte as well as the quality/type of electrolyte.
The AVR microcontroller is a leading low power microcontroller that has been around for almost a decade now. Recently, new lower power devices have been added to the AVR family, called the PicoPower AVR microcontrollers.
In this instructable, we show how even the regular AVR devices can be set up and programmed to run off a fruit battery.
Step 1Preparing the Fruit Battery
For the battery, we need a few lemons for the electrolyte and pieces of copper and zinc to form the electrodes. For the copper, we just use a bare PCB and for the zinc, there are a few options: use galvanized nails or zinc strips. We chose to use zinc strips extracted from a 1.5V battery.
Start with a piece of bare PCB. The size of the PCB should be large enough so that you can create 3 or 4 islands on it. Each island will be used to place a half cut lemon on it.
18 comments
Mar 31, 2011. 3:08 PMDumchicken says:
at first glance i thot it was a tenis ball battery
Jan 19, 2011. 9:15 AMlunus says:
I know I'm probably a bit too serious, but when you look at the chemistry, the power doesn't come from the lemons or the apple juice--they just provide an ion conductive path between the metal plates (which are consumed) any energy produced in the battery must be more than countered by the energy expended in refining those metals. (to get technical, one metal will be consumed)
May 26, 2009. 7:00 PMPSPerson says:
energy crisis:solved Solution: Lemons!! lol thats pretty awesome!
Apr 5, 2010. 2:39 PMcodongolev says:
that'd be a good thing to say at a press conference. "I have solved the energy crisis. lemons." and then just walk away without answering questions.
Jun 15, 2009. 7:59 AMgeeklord says:
"One of the most easily available vegetable, the ubiquitous lemon can be used to make a fruit cell. " That sentance contradicts itself. I'm pretty sure that lemons are fruit......
Apr 5, 2010. 2:38 PMcodongolev says:
yep.
Feb 20, 2010. 8:10 PMbrooklynlord says:
"Do not reuse the lemons for any purpose after the experiment."
Can you use the lemons for the same experiment again?
Nov 27, 2008. 2:52 AMghzyy says:
4C1'
Aug 29, 2008. 1:24 PMMaarek says:
I was wondering why you used HVSP to program this with the STK500 and not using the SPI (SCK, MISO, MOSI) on PB0-2?
Apr 4, 2007. 6:37 AMzanshin says:
great instructable!!!! i hope i'll have time to make this one
Apr 2, 2007. 5:09 PMLasVegas says:
In step 8, you could have easily put the video right in the Instructable by using the Video button. Other than that, pretty cool Instructable. Did you try other fruits/vegetables for power?
Apr 3, 2007. 10:05 PMLasVegas says:
Zinc nails are easy to come by and work quite well for this type of application.
Apr 3, 2007. 3:10 PMARVash says:
Taters :3. (they work too :p)
Apr 3, 2007. 10:46 AMalex_weber says:
Very nice instructable. And I like the ATtiny13v, they can run on almost nothing. Can you reuse the copper and zink plates? Regards, Alex
Apr 2, 2007. 11:30 PMCameronSS says:
Cool system. How do you get the zinc strip from the batteries? I.e., is it the outside part, alkaline or carbon-zinc (I assume the latter), AAA, AA, C, or D? Good Instructable though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Gadre
