loading
between the astronauts, the bases, the space-station, the Earth.
the most important thing is the communication!
EX : It's the link between the space-station to the Earth.
and you need a remote probe to fly into an area for information.
In outer space
1)the weight must be light:not take things that unused(think of all in one).
2) a bit AI : for RADIO, you could manually operate turning instead of
AUTO-tuning.
3)consume the energy: have to operate without battery.
Step 1: Material
i use 2 SSDs and 2 LEDs
to display the value and scale for all resistor i use 330 OHM to limits the current down. because the arduino mini have the MAX current limits ! and then one LED is for the decimal point, the other LED is as uF indicator. i use a solar panel instead of 3v battery.
Step 2: Tools and Range
to display the value and scale for all resistor i use 330 OHM to limits the current down. because the arduino mini have the MAX current limits ! and then one LED is for the decimal point, the other LED is as uF indicator. i use a solar panel instead of 3v battery..
Step 3: Open the Phone Line Box and Clean All
use the "+" screw driver to remove all the copper bars and all the screws.
Step 4: Cutout the Hole for SSD
use the cutter to cut the cover of phone line box.
in order to embed the Seven Segment Displayer parts.
Use the hand drill to drill 2 holes in order to
show the u led and to show the point led.
Step 5: Prototype With Breadboard
it is a cap mark 331 pF,
in order to measure it i use the 2.2M OHM to charge.
the first PHOTO is c = 0 pF, and
the second PHOTO is c = 330 pF.
use cutter to shorten the PCB, in order to fit it into the cover.
i didn't connect to the second digit to display
the "F" because the MAX current limits too !
Step 6: Testing
after soldering the resistors and mini.
And make some test.(4.7uF, 100nF, 0.66nF)
PS:
1)C<99.9 uF then turn ON c', d', e' .
2)C<1 uF then turn ON c', e', g' .
Step 7: Fixed the PCB With Hot Glue
use the hot glue gun to fixed the PCB on the cover.
Step 9: Fixed the Solar Panel
i use a hot glue gun to fixed the solar panel on the back !
a bit feature:
Since you could auto-measuring the capacitors, and then
the next thing you could do is making a network (RF TANK)
auto-turning !
<p>You do show a snippet of code.</p><p>But I don't see the conversion math or selection to place a digit to a segment.</p><p>And it is a good idea to drive the motor from the Arduino direct because speed is not important tracking the sun... At night the sensor needs turn to point back East..</p><p>Where is that code ??</p>
Wow~ !<br>it's really not my point here! it is<br>just a device portable here and out there<br>outer space that for auto measure capacitor ?!<br><br>but, still thanks ~
Yup! Thank you for your comment anyway.
where is the arduino program<br>
<p>Oh... sorry for that !</p><p> it's just finished for now . :-)</p>
About This Instructable
524views
15favorites
License:
Bio: As a young kid, my curiosity in electronics was compelling.... why does thunder interrupt the radio reception? .... and I've been hooked on making thing ... More »
More by David_Lin:Alexa Go Go With RPi 3_part_2 Tiny Robot Plat Form With Pi Zero_part1 Alexa Go Go With RPi 3_part_1
Add instructable to:
