Tiny Felt Pies
1,136
21
4
Published
Introduction: Tiny Felt Pies
About: For more about my costumes, crafts and general craziness, check out my blog: http://modmischief.blogspot.com/
These teeny tiny pies are so cute!
When I saw someone with a mini bottle cap pie I knew I needed to create some of my own. Attached to a hair clip they are a great accessory for Pi Day!
Step 1: Materials
You'll need:
  • Bottle caps - you can buy bottle caps from home brewing suppliers or use clean recycled ones.
  • Tan coloured craft felt
  • Seed beads in red and blue (size 10 royal blue beads for blueberries and a mix of red beads for strawberry-raspberry)
  • Glue - I used clear gel tacky glue to glue together the pies and a hot glue gun for the final step
  • Magnets or hair clip (optional)
Step 2: Cut Felt
Trace the bottle caps onto the felt.
Cut out the circles, these will form the crust.
If you would like a pie that is missing a slice, cut a triangular section out of the felt.
Step 3: Glue
Glue the felt circles into the bottle caps.
Remove the plastic bit first if you are making a pie with a missing slice (you can lift the edge with the tip of your scissors and peel it back).
Add a generous dollop of glue to the inside of the felt crust and then pour on the seed beads. You can use a toothpick to spread the glue and move the beads around until you are happy with the placement.
Step 4: Add the Lattice Crust
Cut some very thin strips of felt.
Glue them to the top of the pie, over the beads, to make the lattice top.
Step 5: Finish
Your pies are done!
Glue them to a hair clip or add little button magnets to the back to decorate your fridge.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    4 Comments
    Oh my goodness. These are adorable, I have to make one for myself. I would buy one too! I would wear one as a pin and a ring!
    These are super cute and look very easy to make! Would be fun to glue to a brooch backing and wear as a pin.
    You rock ModMischief! Thanks for sharing these adorable, easy, fun crafts.
    Every detail about these is adorable and perfect :D
