Tiny UHF Tracker Transmitter
40,758
270
68
Posted
Introduction: Tiny UHF Tracker Transmitter
This is a little circuit that could be used to track an object up to 400m.
It is essentially an SAW stabilized OOK modulated RF transmitter. The modulation is done with two low frequency ultra low power oscillators that activate the transmitter every two seconds for a short period.
With the setup shown here I got up to 400m range. Current consumption is about 180uA average so it'll work for a couple of days with the little button cell. Frequency 915MHz.
Step 1: Circuit
The first oscillator to the left activates the second to its right every 2 seconds or so. The second oscillates at about 800 to 900Hz. Its output signal modulates the RF transmitter which is essentially just a SAW based oscillator with some of the RF energy coupled to a whip antenna.
The adjustment of the RF oscillator can be tricky but works fine with the components shown here. The jumper resistor over the SAW element allows the frequency to be adjusted near the SAW fundamental frequency, then the jumper is removed and the circuit will oscillate at the SAW frequency.
The lower you go in frequency the easier this adjustment will be, so you could go for 433MHz for example too. The component to be changed would be the inductor then (about 22nH).
Use NPO caps for the RF area. The type of the inductor is not critical, I used ceramic.
The circuit would actually benefit from a buffer stage or a matched antenna output, but frankly I didn't fell like investing more time in it. :-) If you want to experiment, I added a pic with a matching circuit for 433MHz that worked pretty well, The inductor for the oscillator changes to about 22nH in that case.
(If you click on the image twice and then on "original DIY file" just below the low resolution picture it will open in hi-res.)
Step 2: Build
Building it requires a hotplate and solder paste or a soldering iron with a fine tip and steady hands.
Make your own PCB layout or download mine from here: Google drive link These are EAGLE files, Schematic and BOM are also included.
Upload the .brd file to your favourite cheap PCB manufacturer, I used Oshpark.com, will take two to three weeks and then:
1. Put solder paste on every pad a component will be placed on
2. Place all components
3. Heat the entire board on a hotplate and wait until the solder paste liquifies
4. Remove the board form the hotplate , let it cool down
5. Flip the board around and solder the battery holder on it
6. Solder the antenna wire into the hole
7. Important: Put some conformal coating or silicon etc on the component side. This will protect the circuit from contamination and humidity. The LF oscillators use pretty high resistance values, which means they are easily detuned if for example you put your finger on it.
Step 3: Range and Stability
The RF frequency is SAW stabilized so shouldn't drift. I did not test the circuit in extrem conditions, but it worked fine from room temp to minus 15C.
Range was about 400m line-of-sight ( does that make sense in this case? :-) )
You can play around with the antenna length and also try to increase the ground area adding some conductive material to the GND pin of the battery holder for example. The short green wire increased the range in my case.
Step 4: Receiver
The receiver is comprised of a YAGI antenna, an adjustable attenuator and a RTL-SDR receiver.
The RTL-SDR dongle is connected to a cellphone that runs a paid app called RF analyzer. It's not expensive.
If you mount the antenna on a car for example the dongle could be connected to a Windows PC though, and there is free software available for Windows.
The YAGI antenna design came form here: https://273k.net/gsm/designing-and-building-a-gsm-antenna/yagi/
There are many other designs on the net and you could also buy an antenna.
The RTL-SDR dongle comes from here: https://www.rtl-sdr.com/buy-rtl-sdr-dvb-t-dongles/
It's an incredible versatile and very useful gadget for the occasional RF Hobbyist, AND its price is unbeatable.
The attenuator is made of a shielded box with three DPDT switches and attenuates 10dB for each stage. Use small resistors and short connections. Its performance at these high frequencies I didn't feel like evaluating but it attenuates a good amount and that's all that counts. I didn't use any particular website for this part so you have to look this up for yourself. Search for How-Tos of RF attenuators with resistors.
Step 5: See It in Action
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    53 Comments
    Hi, I would like to make this but I can't understand the section about tuning. What is it that needs tuning, are some of the components adjustable with a screwdriver? They look too small. Or maybe I need to change some of the components to different values in order to tune this? Can I use an oscilloscope? I've made microcontroller and surfacemount pcb stuff before but never rf so I have no idea. If you could tell me or direct me to another website which explains this that would be really appreciated. Thanks!!!
    .... sorry, I mean the section where you say
    "The adjustment of the RF oscillator can be tricky but works fine with the components shown here. The jumper resistor over the SAW element allows the frequency to be adjusted near the SAW fundamental frequency, then the jumper is removed and the circuit will oscillate at the SAW frequency".
    p.s. thank you for posting this it looks really great! :)
    hi again, if I didn't use NP0 capacitors will that make a big difference do you think?
    For RF circuits, everything that influences the oscillation frequency should be NPO.
    Ok, thanks very much!! :)
    No need to tune anything if using component values from the schematic. If you change the SAW resonator you will need to reajust some values as I described.
    ah, ok, thanks!!! :) I will have a go and see how it goes, I plan to use it for tracking animals (for my post-grad. zoology course). If I can get it working I will then try to find a way to make the battery last longer. Thanks again!
    LOOK my friend also very cheap and READY to use with an app on your phone, you can see track movement, where the watch was in FOOTPRINTS on a map, you can set boundaries, and MUTCH MUTCH MORE.
    LINK. https://www.banggood.com/Anti-Lost-Smart-Watch-GPS...
    and look soon on my website how i even make it smaller to use it on smaller drones..www.wannaduino.com and all for FREE
    i help others i love OUR COMMUNITY and OPEN SOURCE
    WannaDuino www.wannaduino.com
    sorry to be rude, but to walk around with that GIANT ANTENNA setup, would not work.
    if you can make the receiver as small as the telephone oke, but this is nothing compared with the transmitter i already have and receivers for my drones, called RSSI work amazingly and i use also GPS in a watch style cost 14USD and works by an app, so in that case you work backwards in time instead of forward?
    You can buy it here,
    https://www.banggood.com/?p=NI03162039418201508L
    GPS type: GPS tracker
    Screen size: 0.96" LED
    Communication Module: GSM / GPRS
    GPRS:Class 12 TCP IPbuild in GSm MODULE
    GPS Senstivity: -159 dbm
    GPS Positioning Accuracy: 10m (2D RM)
    Gsm Positioning Accuracy: 50-200mm
    Speed Accuracy: 0.1m/s
    Maximum Altitude: 18000m
    Stand-by time: 100 hours
    Battery Capacity: 400mA
