3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tip-Top Flower Pots: Maximize limited space to grow plants and flowers!
This cool project will allow you to take advantage of even the tiniest place to grow flowers and plants- on patios, decks, balconies, etc. These supplies are easy to find (some recycled from your friends, family, and garage) and the final product is unique and spectacular. Your friends will be asking you "How did you do that?"
Step 1Gather your materials.
OK, either dig through your stash of flower pots or make a trip to your local home improvement store (or your mom's house) and gather what you need:
1 12" flower pot
1 saucer to go under the base pot (optional)
4 8" flower pots*
1 4' garden stake (sturdy- steel covered in plastic- I got mine at Wal-Mart)
20" of 1/2" PVC or similar (look around in your garage- you don't need much)
Potting soil
Flowers/plants- I planted 3-4 four-inch flower squares on each tier
  • I used plain terra cotta pots- I wouldn't recommend using the azalea terra cotta pots. Your pots MUST have the drainage hole on the bottom.
39 comments
May 7, 2012. 11:29 AMlove2die100 says:
thx4sharing,my neighbour has one the same assembled here but instead of using plants can you convert it into fountain,when yes how.
Feb 13, 2011. 2:40 AMemad_sh says:
Very Nice and Easy
thanks for sharing.
Jan 3, 2011. 11:19 PMismailkumar says:
i.m.p.- point
Nov 9, 2010. 11:12 AMalanfindaly says:
Wow, this is a great way to use all of the clay pots I have laying around. I'll have to go out and buy some shop flowers , but it will be worth it if it turns out as nice as the pictures here look.
Jul 3, 2010. 6:43 AMbrennawalters says:
I bet that if you used sturdy pvc for the center post, and drilled holes intermittantly along its length, you could use a funnel to water all your plants through the center. No evaporation loss! You would arrange your most water-loving plants on the bottom, with the more dry-climate plants on top. From mint on the bottom to cacti on the top!
May 16, 2010. 10:43 AMtaia82 says:
To make this more sturdy, I would recommend that you got a threaded galvanized pipe and a floor flange. You could then attach it to a piece of small board, or you can screw it right to the floor. It would keep it upright, so you would just have to re-arrange the pots if they get blown around.
Aug 11, 2009. 4:50 PMchalky says:
heres mine:)
Aug 7, 2009. 6:57 AMNancy52 says:
Ok!!!!!!! Like daaaa Nancy. That does make a lot of sense. There is one of the tip-top flower pots here in town and they are always rearranging it after the wind blows hard. Also could you just put the vertical pole through the drain hole in the bottom 12" pot and into the ground and just skip the dish under the bottom pot? If so, would you still need the PVC in bottom pot? I was thinking of using an electric fence post to run through the whole thing. It fits through the holes. I already tried that fit. Thanks for your replys.
Aug 4, 2009. 4:31 PMNancy52 says:
What is the purpose of the PVC pipe in the bottom of 12" pot?
Jul 5, 2009. 9:09 PMjaded30720 says:
I really do like this project. One lady made hers into a herb garden which is what I would like to do. Kudos.
Jul 4, 2009. 6:30 PMaklesh3 says:
Here's the one I made. Being in Florida, it drys out really fast, so that when you water it, you have to water it sloooooooooow, or the water just runs off.
Jun 16, 2009. 12:54 PMblackturtle says:
This is so awesome! I think I need one (or 7) for around my house! thanks for sharing!
Jun 10, 2009. 1:25 PMjeffrey1965 says:
I did one for my wife for Easter. Everything is growing well and it looks nice.
May 27, 2009. 9:43 PMIDmom says:
How do the holes need to be drilled for the stake to go through causing the pots to lean? I'm sure the hole and stake placements have something to do with making the pots lean, but I can't picture it. Please explain for this newbie, thanks!
May 30, 2009. 10:23 AMwgoble says:
Awesome! I think we'll be building one of these over the weekend.
May 27, 2009. 9:08 PMRoBear613 says:
I could see getting a lot more strawberry plant in this (and therefore more strawberries) than a "strawberry pot" for the same price. Take your bowl of corn flakes out to the patio and enjoy.
May 26, 2009. 6:29 AMluckysuzy says:
Love it! I made mine into an herb garden. It is awesome and very easy to do! Thanks for the instructable!
Apr 21, 2009. 9:51 AMfleurdejava says:
very nice and clever! I did it yesterday, it costs only 8 euros for the 5 pots (I leave in France). Thank you so much.
Apr 22, 2009. 1:10 AMfleurdejava says:
In my garden, in France
Apr 20, 2009. 3:40 AMgaz9448 says:
built one over the weekend thanks to your instructable. i used stuff which i'd saved from previous fun and used these instead so might not be as sturdy. I used a metal pole, that used to be part of one of those cheap canvas marquees you can get, as the canvas didn't hold up to a full season. the pots weren't all terracotta, but looked nice and have the drainage including an old wine cooler with the bottom partly drilled out. fantastic mate.
Apr 21, 2009. 8:34 AMalphaseinor says:
I'm in the contest as well, and I voted for you! Very nice instructable, and a good use of space!
Apr 17, 2009. 3:48 PMMaureclaire says:
Fabulous ! Gotta do it ! I'm thinking if I put it on the ground, won't need pvc pipe at all, and just have stake go well into ground, won't even need to cut it.. Even easier ! Thanks for idea !
Apr 17, 2009. 2:01 PMlady4feet says:
I love it! I saw something similar at the flea market but they wanted $22 for just the pole. Now I can make my onw, thank you.
Apr 17, 2009. 10:20 AMyngla says:
Great instructable! This idea is so cool and the end result is stunning!
Apr 17, 2009. 7:46 AMmajeral says:
This is great!!! and easy and cheap ( Can't spell inexpensive ) I saw something years ago on a home improvement show that took a tomato cage and made it into a stand to hold poinsettia They never showed how to do it. Thanks again Vie !
Apr 17, 2009. 3:02 AMknittinandnoodlin says:
Great instructable! I just bought a kit for this at the Philadelphia Flower Show - such a cool idea to stack flower pots! Your instructions/photos are really clear - good work!
Apr 15, 2009. 10:57 PMalex-sharetskiy says:
very clever!
Apr 15, 2009. 3:19 PMRustar says:
Reminds me of something out of Alice in Wonderland.
Apr 15, 2009. 6:56 AMBroom says:
Great idea! I'm betting you meant a 4' stake, and not a 4" pole.
Apr 15, 2009. 7:09 AMdontwealllovebuda92 says:
amazing idea
Apr 15, 2009. 6:01 AMAimless says:
Sweet idea, I'm going to try it out this summer :)
Apr 14, 2009. 11:57 PMgmjhowe says:
A simple idea that actually looks alot more complicated! Great work.
Apr 14, 2009. 11:28 PMtink1272 says:
I love this! It's very cute, would make a great gift and is perfect when you only have a 3x6 patio! Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:jholland
