Introduction: Tips for Airsoft
Step 1: Find a Good Spot to Airsoft
When you go airsofting, it is good to be on a team but most importantly, find a good spot to go airsofting. When you airsoft you don't want to be in plain field. If you do go in a field then you have to have at least tall grass or a base because you don't want to be seen or hit. A good spot to go, is in the woods because there are many things to hide behind. Also going to airsoft battle field such as ~black ops airsoft~ is good to go airsofting too!!
Step 2: Get a Good Gun
When you airsoft you don't want a bad gun. The better gun you have, the better you will do. That doesn't mean that you have to get a very expansive gun. You can still get a pretty good gun for a cheap price. The good thing about airsoft is that you can get whatever gun you want. But you do want a good gun, such as the guns in the pictures which are the G36c, Tar 21, and the M4A1
Step 3: Get Good Equipment
For airsoft you need good equipment. You should get a good mask or a good helmet, and a vest or a backpack to put any other things you need on there such as a pistol or grenade. If you want any other things than go ahead get it but the things that I said before are things that you are most likely going to need :)
