Tips and Jigs Part 1: Circular Saw Straight-Cutting jig
For many of us, the cost of a table saw is too much just to be able to make long straight cuts in sheet lumber. If you buy a smaller table saw, you are actually creating a very dangerous situation as these are not meant to cut large pieces of lumber. What about space. A table saw is a space hog, especially when not in use.
SOLUTION? BUILD A JIG! A circular saw is a very common tool for home owners. You can buy battery powered versions that come in kits or go for a nice corded one. This should take you about an hour if you have all the supplies.
This instructable is a follow-on to a concept presented by http://www.instructables.com/id/Cutting-plywood-the-easy-way/
Step 1Getting Started: Supplies and Information
Items you need:
Circular saw (1)
Hand Drill (1)
Countersink (1)
#10 Drill Bit (1)
Countersunk 10-24 sheet metal screws (15)
10-24 nuts (15)
lockwashers (15)
Sheetrock screws
4x8 1/4" Hardboard
1"x1"x1/8" Aluminum Angle (Length as desired)
15 comments
May 26, 2011. 1:38 PMgephardt says:
Hmmm. I have always felt safer with a table saw, and mine cost no more than most decent circular saws. Does take up some space, but it suits my needs better.
Jun 27, 2010. 5:43 AMsabr686 says:
I don't get it
Jun 30, 2010. 2:34 AMsabr686 says:
Okay, thanks mate.
Feb 26, 2010. 12:14 PMevertonp says:
Hello,
I really enjoied your instructable. Congratulations.
Regards,
Everton
Jun 27, 2009. 1:03 PMbobtannica says:
Really liked your instructable. I would be very interested in seeing a table saw base as you suggested. Keep up the good work.
Dec 18, 2008. 11:19 PMgarethfarfan says:
Wow, this is a lot of work for nothing. Something wrong with just clamping your angle to your piece of wood being cut and running your saw's existing edge against that?
Aug 18, 2008. 6:29 PMboognishmofo says:
This is a great instructable. I thought at first you were going a completely different way with it. Since you have a pretty darn sturdy base on it could you not turn it upside down mount it in a table and put a switch to make a table saw? I have an old wet tile saw that I was thinkin bout turning into a table saw but I have way more old circular saws lying around. Any info would be greatly appreciated.
Jun 12, 2008. 11:32 AMjdege says:
What are you doing to ensure that the aluminum angle is straight, when you screw it to the hardboard? The stuff does flex, and any error that's present in it will be replicated in your cuts. Even if it is straight at the time you screw it to the hardboard, screws won't keep it straight. Over time, play will develop in the screw joints, and the angle will move out of true.
Jun 12, 2008. 4:30 PMjdege says:
"I clamped a level to the aluminum angle when I mate-drilled the holes to the hardboard." You should add that to the instructions. It's a critical step.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:Pkranger88
I am an engineering manager for an aviation parts manufacturer in MO. In addition, I am a CATIA V5 instructor and a subject matter expert in Design processes, Design for manufacturing, Knowledge bas...
more »
