Remove these ads by
Signing UpStep 1Steady camera, long exposure, no flash
I used a Canon PowerShot A70 to take all the pumpkin pictures. It has some manual settings modes were you can adjust the exposure time and F-stops. I actually used the "Tv" setting which allows me to set the exposure time and the camera automatically adjusts the F-stop.
If your camera doesn't have any manual modes, turn the flash off and see if it can compensate enough. The answer is it probably isn't enough. If you're really into taking pictures of pumpkins, like me, make sure your next camera has a manual exposure mode (my other criteria was a water proof case...).
My phone is a Nokia 5800. It has a high-resolution Carl Zeiss 3.2 megapixel lens with built in flash. I opted for this phone because I could not afford both a new cellphone and camera. It takes amazing photos, but I haven't found any great user information that would allow me to learn how to take photos at night. What happens is the flash goes on and lights up everything as though it were daytime... without the flash the image is black.
I know my question is a long shot at best, but if you have any advice I would appreciate it.
Thanks.
Thanks!
Regarding jack-o-lanterns, to extend their lifespan, wash the pumpkin thoroughly with a mild soap solution to get rid of any dirt, etc from the outside, rinse and then dry with paper towel. Make a bleach solution (1 tbsp bleach to 1 qt water) and put in a spray bottle. Now clean out your pumpkin, removing seeds, pulp etc. and then carve your design. As soon as your pumpkin is carved, spray the inside and outside thoroughly with your bleach solution. Let it penetrate and dry for about 30 mins. After that you can pat any wet areas dry. Finally, use some paper towel and petroleum jelly and give Jack a good thin coat on the inside and outside.
Store your pumpkin out of direct sunlight and keep it as cool as possible without allowing it to freeze. With this method, we have been able to keep our jack-o-lanterns looking good for well over a week (one year it lasted 2 weeks!)
The bleach keeps bacteria and mold in check, and the petroleum jelly keeps the pumpkin from becoming dehydrated.
