Introduction: Tips to Create Eye-catching User-interface for Your Mobile App
In each and every successful mobile app, there are many distinguished success factors behind, it may be an app that is developed by the best mobile app developers, or the app’s creative and attractive design or the app’s capability to perfectly serve the users’ expectation. But I am damn sure, in most of the successful apps, the most prominent success factor is eye-catching UI design.
In mobile app development field, experienced app developers well know which tools and technologies need to be used for developing an app to make it more innovative, in the same way, it is requisite for mobile app designers to well know the UI design of the app. It is even important for app owners to know the UI design elements to bring out eye-catching app.
The whole article is regarding UI design techniques that most of the mobile app designers implemented and succeeded. It can even help you (both app designers, and app owners) to make your mobile app’s UI design more innovative.
I don’t want to drag the things, so let’s move straightaway to know Fruitful UI design tips:
Make your design responsive
It is beginning of the mobile app design, if you fail there, everything will collapse. Mobile app designers should always remember that. The user interface design of the app should be designed as responsive because the same design is used in different mobile devices. So responsive will keep your mobile app design out of an issue. It is mandatory that the designers should focus more on the responsive design and know to tackle the issues while the app is used in multiple devices.
It is good iterating user interface design
As an app designer, you should concentrate on user behavior too. Its interface should be fully engaging and able to retain the attention of targeted users. Once you have done a user interface design, it won’t be waste, you can use the design ideas that was taken during the iteration to the current project, and even for the next app as well.
UI design needs to adhere 508 compliance and security issues
During the mobile app development process, 508 compliance and security issues are considered in the later stage, which increase the project execution time. So as a designer, you should make sure that the right set of data is being implemented in an appropriate manner, by consulting your back end team.
Keep your user interface simple
Most of the app owners concentrate on simple app design. The app should be in such a way that even the first time user should be able to access the app without going through detailed instructions or guides. Doing so allows the user use the app easily, and subsequently, there would be a huge chance that the user could get addicted to your app. Using the colors logically will allow you keep your app's interface as simple as possible.
Evaluate mobile UI design with real users
When your app design is in the nurturing stage, it is good to have some real users to evaluate UI design functions, which allows you to take some suggestion, ideas and opinion from them. Doing so helps designers decide which design elements will work and rock. It saves the time and money significantly that you could spend on redesign.
Want to create an eye-catching UI design for your app?
If yes, FuGenX will help you. FuGenX Technologies is the world’s fastest growing mobile app development company in India. It bagged Deloitte Technology award for its exceptional performance in the mobile app design and development. FuGenX is popularly known as one of the best android app development service provider.
