Tire to Stools!
18,532
306
38
Posted in WorkshopFurniture
Introduction: Tire to Stools!
About: I'm a mom of 4 and I love to craft! Anything and Everything interests me and i love to create in the process of learning.
My children's school wanted outdoor stools and asked me if I could make them some. They wanted something like my ottomans but smaller.
Enter Trishaw tires! In Asian countries Trishaw or Three Wheelers are commonly used for transport. We have loads of Trishaws and hence loads of waste tires! Luckily for me there was a tire shop near my mom's and they happily gave me 24 tires FREE!
Wheels Contest
Runner Up in the
Wheels Contest
squeeze more awesome out of summer contest
Finalist in the
Step 1: Materials
Now I had to make 6 stools for school and I wanted to make another 2 for me. I seriously couldn't see myself drilling and joining all these tires! My arms would kill me!! So I looked for other options and came across 2 part epoxy glue which also glues rubber. Yipppeee! saved :-D
3 tires per stool
2 part epoxy - I used EPI FIX. I'm sure you could find other options for this in your country.
2" sponge foam
9mm plywood for lid - You could also use the lid of 5L paint buckets. ( I couldn't find any at hand else I would have used it
Leather/ synthetic leather
Heavy duty Stapler Gun
Step 2: Glue It Up!
First you need to give your tires a good wash to remove all the grease and grime.
Now mix your two part glue and apply on the highest point where the tires would meet and stack the other tire. Glue and stack till you get your required height. 3 was just right for me.
Wait for 24-48 hrs. My children put the glued up tires to some tests and it passed :-)
Step 3: Cover It Up
Measure the height of the tire and take 6" extra. Measure the diameter of the tire and take about 1" extra for sewing allowance. Cut the rectangle.
Cut a smaller circle than the diameter of the tire for the bottom cover.
Wrap the rectangle fabric with wrong side facing up. Pin it to form a tube. make sure it's a tight fit. Now slowly remove the tube and sew it. Fold the tube width wise twice and make a mark so that it's divided in to 4 equal parts and the corners will be marked.
Now fold the circle in 4 and cut a bit or make a mark so that you would also divide the circle in 4 parts.
Pin a mark from the circle to the tube. Do it to all 4. Now evenly distribute the fabric and pin. Sew and attach the circle to the tube.
Turn inside out and wriggle it over the tires. Now pull the tube tight and turn so that the opening is at top. Pull tight and stapler a flap down. Now do the same to the opposite side. Do the same to the side marked B. Keep pulling and stapling till it is all done.
We now have to do the lids
Step 4: Lid
For the lid I cut 9mm plywood.
Measure the diameter of the tire and reduce about 1.5" from it and cut in plywood.
I'm sorry I didn't take a picture of the wood separately. I forgot!
Now place your sponge on top and cut around about 1" larger. (In my picture it's not 1" cause I had to be a scrooge as I ran out of sponge :-( ).
Glue the sponge to the wood. Now place this on your fabric and cut again 1" larger than than the sponge.
Now start to staple as you did the stool base. First one side, then opposite and so on.
Now apply glue on both the bottom of the lid and also the highest point on the stool base. Place lid on top and keep a weight on top so that it would firmly glue down. Leave for 24 hrs!
These tires are not the real hard ones that I used on my ottomans. They are a bit spongy which is also how poofs normally are :-).
I have demonstrated in a picture how much it depresses when a adult sits on it. In this case the adult is 70kg.
Step 5: Storage?? of Course
The above stool can easily be modified to allow storage.
1. Place the wooden disk on tire and drill through. Mark the respective holes on the tire to match the lid so that if there is a mistake in alignment we would not have a problem later in finding the correct holes. Now remove the lid and drill with a bigger bit on the tire. Why do we do this? be cause the rubber will contract and the hole will be too small for the bold to go through. Gradually drill with larger bits till the bold will go through. It should be snug. Not too big that the bolt just slips through. If that happens the lid might just fall off when kids roll the stool (which they are bound to do!)
2. Place glue on the lid side of the bolt and tighten the nut. Now glue on the sponge and cut your fabric. The sponge should be larger than the lid and the fabric should be larger than the sponge.
Now stapler around like shown in the previous steps.
3.Sew the cover the same way as shown in step 3. Now Pull the cover over the tires. Remember now that the drilled tires should come in the opening side.
Pull your fabric over and punch the hole through the fabric in to the tire. I used eyelet rings to make it neater but it's not necessary. Now place a bolt the same size in the hole and pull fabric and stapler in the under side of the tire. This way it is very neat when you open the lid.
That is it. The space in this is very small as the tires are small. Of course the bigger the tire the larger the storage space!
Step 6: Enjoy!
These look wonderful outside and as it's done with synthetic leather it's also waterproof!
I hope you enjoy this instructable and please ...pretty please vote for me!! You would get a nice warm feeling inside for making someone happy! lol
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    38 Comments
    I am going to tray this project will let you know how I due, Thank you
    I will be doing the type with storage inside, and the tires I will most likely be using are a total of 14" high with a diameter of 22.5". So the circumference must be ~71". Do I need a rectangle of fabric measuring 20" by 75", then?
    First of all I love to be bothered with questions if someone wants help with any project I can help :-)
    First- you wanted to know if you need to double up your fabric. Well that depends on your tires. How is the surface of it? is it smooth? If smooth no problem. If not it's best to either glue/staple wadding( used for quilting) or sponge around the tire like shown in my round sofa.
    Then you measure the circumference of your tire.
    As you are doing with storage measure the height from inside rim all the way out and down the tires plus 3". The circumference 75" is correct. The diameter for the under fabric should be 22".
    19" or 20" diameter is fine for the plywood base. Just a couple of inches smaller than the tire diameter :-).
    Hope the above helps you, if not please feel free to ask more questions!
    BTW I would love to see a picture of your project once compleated :-)
    Thanks for the response!! One more question -- how do I attach the fabric to the tires and wood? Staple gun?
    Project is currently on hold because I don't have the tool(s) to cut a circle of plywood. Am looking around the house & garage for items to reuse in its place before I go buy the type of saw I would need. Thinking about using a chair that is similar in shape to this one, though it has a more rounded seat and no legs. I'd glue the seat to the top tire, as well as cushion the seat & back. Trying to figure out how I'd maintain storage capabilities. I don't think velcro would be strong enough to replace epoxy. Maybe use only the seat of the chair...? Thoughts would be appreciated!
    Oh, and I will definitely take pictures! :)
    Sorry for the delay in replying. I seem to have missed it in my email.
    If you don't have a stapler you can always use nails.I think it should hold.
    if you can't find epoxy to glue the bolt, then use a nut to tighten from under.
    And yes, you can use the sest :^)
    Hope I helped you :-)
    Hi,
    First off, I love this idea! I'd really love to try it, but I'm having a hard time following the instructions.
    I have a few medium sized tires that I'd like to find a use for. I haven't decided upon a height of two or three tires yet. Once I wash them down, glue them together, and test the glue bond, what measurements of fabric should I use? Is it six inches in addition to the height of the cylinder, or should I add more since my tires are bigger? Is it okay to use fabric instead of leather? Should I double up on the fabric since it is somewhat thin? What size should I make the plywood base in relation to the diameter of the tires?
    So sorry to bother you with all the questions, but I am completely new to working with tires!
    It was my pleasure Rima
    Great stools! Although I don't think that I would be able to make them, they are really cool!! Nancy
    Thanks Nancy! Once you try it, you find it not so difficult. I'm positive you can do it :-)
    This had to be a winner Shazni :). Congratulations!!!!!
    Thanks! I'm really excited :)
    Oh definitely! Thanks for stopping by :-) would love your votes too!
    yes you could :-) . If you scroll down in the comments you would see a picture of an orange stool I have uploaded. I did that without taking pictures. I have to do another, so once I do I shall add another step if you need it :-)
    Wow, amazing! Perfect for outdoor furniture pieces! Probably super heavy too! :)
    Thanks !. Actually it's not so heavy. Trishaw tires are not heavy and it's small. My 11yr old can carry it with no problem, and she is skinny :)
    This is really cool it looks great
