Introduction: Crochet Tissue Pouch
Crochet and knitting is some thing that I have been always wanting to learn.I found so many nice Ibles explaining for the biginners.I kept on viewing and watching the videos over and over again and tried out for months,made so many mistakes and was so frustrating at the biginning and finally learnt the basic.But still I make mistakes....... :(
I did not even have the basic knowledge to crochet or knit,when I started to learn from ible.
I came up with an idea to crochet a simple Single crochet Tissue Pouch as it is the time for tissues in every ones pockets in this winter season,so this instructables will be a very usefull for all those who knit and Crochet.
I have used only single crochet for the whole Pouch and this is my first Crochet ,so please be nice with your comments.
The size of this Pouch is 5 x 3 Inches.
** The third image is a sample to show the mistakes I repeated over and over again.This does not count in to this single crochet Pouch.**
Step 1: Supplies
Yarn in contrast colors
Crochet needle 3.5 (to match the yarn)
Tissues
Scissors
Darning needle
Sewing Needle
Matching thread
Cork bord
Water spray
2 flat pins
Pins
Tissues
Scissors
Darning needle
Sewing Needle
Matching thread
Cork bord
Water spray
2 flat pins
Pins
Step 2: Casting
I learnt the single crochet from this instructable.Very clearly described and was very easy to follow.I did about 21 chain stitches to the length of the Tissue Packet.Then one more turning chain.
Step 3:
Bigin with a length of chain .Insert the hook in the second chain from the hook, wrap the yarn around the hook and pull the new loop through the chain only.Now there are two loops on the hook.. Wrap the yarn around the hook and pull a loop through both loops on the hook.
one loop remains on the hook,Repeat this step until end of the row.
Step 4: Pin It.
You have to continue to go back and forth, until the desired width you need for the pouch.The width was exactly 6 inches to wrap a packet of tissue.See image 3.I read in a magazine that ,to keep the crochet edges straight and flat (square/Rectanglar pieces) to pin it on a cork bord and spray a little bit water over it,and leave it over night.I did so and found that the edges were straight and stiff.
Step 5: Add Another Color
Now I did the same single crochet on both sides lengthwise in a contrasting color pink.While doing the pink hold the two ends along and crochet over it and cut off, if it is too long .See last image
Step 6: Fold & Pin
Once you have done single crochet on lengthwise ,fold on both sides to get the opening in the middle and pin it in the middle.With a darning needle insert the end of the pink yarn to the wrong side from the corner and pass it in to the loops..Sorry I forgot to take a picture,but you can see it in the next step .
Step 7: Crochet Sides
Now do single crochet on both sides ,at the end put a knot and take it inside to the wrong side and pass it along the loops.
Step 8:
Step 9: Hand Sew
On the opening, on both ends do a small hand stitch to keep it firm when you pull the tissues out.
Step 10: Admire
Don't you think it's an awesome work for a first timer?
Thanks to all those who have published crochet instructables which helped me to learn Crochet. Ahh... I am still learning.... .And watch out for my First knitting which I hope to publish soon.
Thank you very much for taking time to view my first Crochet ible,and please don't forget to caste your vote if this has touched your heart.
