Titanium Snow Saw
 by nierk
Featured
Here is a complete set of instructions on manufacturing a snow saw out of titanium. Before we start building anything, we need to start out with a list of tools and supplies used to complete this project. A water-jet or other CNC is required for cutting titanium. For this, I used a local waterjet service.
Step 1: Materials and Tools
Materials List:
Some sort of 2-Dimensional software that can read/write AutoCAD DXF files
A piece of metal, either sheet or flat bar, 36” long and 3” wide – I used titanium because I had access to it, and it has ideal properties for the final saw, but any 5000, 6000, or 7000 series aluminum between .080 and .125 inches thick will work pretty well too.
Scrap wood – 1/4-inch thick for the handle, you will need enough to fabricate the type of hand you want.
Some sort of fastener for holding the handle to the blade – I used two (2), 3/8-inch diameter by 1/2-inch long aluminum binding posts
Plasti-Dip – or some other sort of coating that will give a good grip through your gloves in cold, wet weather.
Tools List:
Sander – I used an angle grinder to sand both the wood on the handle, and add a finish to the titanium
Drill and bits for drilling holes for attaching the handle
Screwdriver –For attaching the handle
Wood Saw – I used a band saw, but any saw that can cut wood it fine
A few clamps
1 cheap disposable paintbrush
Now that we have a list of materials, we can start the build process of the saw.
joeaaabbb says: Mar 23, 2012. 10:12 AM
What a great idea! this is the exact thing I was looking to make. Great job and keep the instructables coming!
iglitchhalo2 says: Mar 8, 2012. 7:21 AM
Why titanium? I'd have thought stainless steel would be ideal
nierk (author) in reply to iglitchhalo2Mar 8, 2012. 10:29 PM
Titanium is lighter weight than stainless steel by volume by quite a bit, and if you are backpacking, weight plays a large factor in what you bring along.
viperguy says: Mar 8, 2012. 4:22 PM
I don't have a use for such a saw but thanks for the nice write up. If anything, I learned something new.
Codus says: Feb 29, 2012. 9:33 AM
Two things:
1)What is a snow saw, and what are its uses?
2)Beaustiful pictures. Real nice quality!
justin_the_jack in reply to CodusMar 8, 2012. 11:00 AM
It is also nice for snow sculpting--mostly for the initial "roughing-out" phase. A longer saw, with a handle on each end, is good for sawing parts off of a big block when used by two people.
nierk (author) in reply to CodusFeb 29, 2012. 8:03 PM
When I go backpacking in the winter, I have on occasion slept in an igloo that I build out of snow. The snow saw is the tool that I use to cut the bricks. There I dimensioned the handle for measurements as I cut the bricks.
pyromanic says: Mar 2, 2012. 8:11 AM
cool goes right through snow
kingzilla says: Feb 27, 2012. 3:28 PM
Since this is titanium, you could anodize it!
It would produce some nice colours and should increase the rust resistance and surface hardness.
All you need is some diet coke and a power supply.
nierk (author) in reply to kingzillaFeb 29, 2012. 8:06 PM
I might try that with another project, thanks for the ides
curious youth in reply to kingzillaFeb 27, 2012. 11:35 PM
you should make an ible!
TheCritic in reply to kingzillaFeb 27, 2012. 8:26 PM
(removed by author or community request)
Danielk in reply to TheCriticFeb 29, 2012. 5:27 PM
You drink the diet coke on your way to the anodizer. duh. lol
black hole says: Feb 28, 2012. 3:28 PM
Where did you get the titanium?
nierk (author) in reply to black holeFeb 29, 2012. 8:05 PM
It was given to me by a guy who was using it for something, It isnt the best alloy, and it is acid diped, buy hey, it was free and now I have a sweet saw. Thanks for your comment.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
