Titanium Snow Saw
 by nierk
Featured
Step 3: Finishing The Blade
I used to my angle grinder and sanding disks to finish the blade. I just used 60-grit disks for all the blade work (polishing and sharpening).
On the pointed end, I used the 60-grit to bevel the edges to about 45 degrees, to put a decent edge on it (perfection is not required).
I then drilled the holes to 3/8” to fit my binding post fasteners. This took forever as titanium is very hard to drill. This is where I realized I should have modeled in the correct size holes for the posts for the waterjet to cut. This would have saved me time.
I then cleaned up the holes with the angle grinder by sanding off the burrs left from drilling.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
