iImage Information
Doing solder reflow work can be expensive and difficult, but thankfully there exists a simple and elegant solution: Toaster Ovens. This project shows my preferred setup and the tricks that make the process run smooth. In this example I'll focus on doing reflow of a BGA (ball grid array).
Step 1Find a toaster oven.
iImage Information
You're looking for two main things, an adjustable temperature knob, and a timer that will time down. The more precision you can get in the timer the better.
Also, if you can get it, some sort of forced air flow will improve the uniformity of the oven temperature, but you have to make sure that the air flow isn't powerful enough to move your components around.
I looked further into reflow and other resources say that the temperature should be between 390F to 420F. NOT 450F. please edit your instructable so other people don't make the same mistake i did.
also, try not the breathe the smoke in that is released from the motherboard, I accidentally did and now I feel light headed.
people have used these torches for laptops more specifically, since most people arent smart enough to try it ont eh desktops, since they figure motherboards are eas to replace anyways.
The author's example is building a BARE PCB up with no mention of plastic.
The author could not anticipate that someone would try to reflow plastic parts, or inhale the fumes. You can not document common sense in the space of a tutorial.
Since you wanted to reflow a populated board, I would have sought one of those tutorials out (there's lots of them, particularly for the x-box, as reflowing the board is something many customers have needed to do).
By the way, your motherboard was not ruined. Capacitor replacement is one of the easier repairs to make. $3 on ebay would get you a replacement cap of the right size, and you could solder it back in with a cheap iron.
I'll also throw in, if you want to do localized reflow without heating the whole board, a heatshrink gun can work (Sparkfun has a Heaterizer 2000 for like $10). You can still make mistakes of course...
If the part is valuable and you are a novice, best to watch someone else do it the first time (youtube is good for this!)
it was a crappy little socket 478 mobo anyway, Yes, lesson learned, atleast i didn't do it to a more expensive component.
Reflowing "smt" chips, resistors, caps, or any other "surface mount" components on a motherboard is the FIRST process they do to it.. BEFORE adding the other components that are "heat sensitive".. ie: "melt at high heat". The plastic based components are added later.. by hand.
Think of it this way.. would you allow your motherboard to run at 390F - 450F? No. Reason is, those plastic components will fry.
There's nothing wrong with this method. Many use their bigger ovens as well. You just need to be sure you are familiar with electronics before you attempt to do something like this.
If you need something directed at a single component on the board, then look for the instructables called "DIY Hot Air Soldering Iron". A "reflow pen" is what you need. More control of where the heat is applied. ;)
Chhers.......................
Toaster oven Reflow Controller
I have nothing to do with sparkfun but I think its a really cool kit.
Did you add solder to the pads?
Will any kind of solder do the job?
quang cao online | quang cao
Imagine a computer case fan spinning at 100RPM instead of 2000RPM. Except a computer case fan would melt in a toaster oven, but you get the idea.
Hi,
I have an old Minolta Dimage 7 Digital Camera.
I think that the BGA Processor has some cold welding.
Is it possible to use your procedure to reflow the affected AGP pins?
Also you didn't mention the duration needed for that operation.
I'm a dentist, and I prefer to use a ceramic electronic oven which is more accurate and it's available in any good Dental Lab.
You can read my trouble by visiting the following link:
http://forums.steves-digicams.com/forums/view_topic.php?id=587881&forum_id=20&jump_to=866089#p866089
Please help me regarding this issue.
Soubhi Sabbagh
email: lego(at)aloola.sy
GSM +963944416832
