3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Toaster Oven Reflow Soldering (BGA)
Step 6Start 'em cooking.
Start \
Close the toaster oven door, (make sure you don't bump the component out of alignment.) Set the temperature dial for somewhere around 450 and start the timer at around 20 minutes. Later on once you've determined the characteristics of your particular toaster oven then you can start using exact values. But for right now we're going to use our oven thermometer and the external timer to keep track of what's happening.
2 comments
Mar 14, 2008. 7:36 AMdrsoubhi says:
Dear Mr. Colin
Hi,
I have an old Minolta Dimage 7 Digital Camera.
I think that the BGA Processor has some cold welding.
Is it possible to use your procedure to reflow the affected AGP pins?
Also you didn't mention the duration needed for that operation.
I'm a dentist, and I prefer to use a ceramic electronic oven which is more accurate and it's available in any good Dental Lab.
You can read my trouble by visiting the following link:
http://forums.steves-digicams.com/forums/view_topic.php?id=587881&forum_id=20&jump_to=866089#p866089
Please help me regarding this issue.
Soubhi Sabbagh
email: lego(at)aloola.sy
GSM +963944416832
Jul 17, 2006. 12:24 PMM40 says:
It is preferable to heat rapidly. Laser systems and some of the induction heating units used for solder paste can reflow paste in less than 1 second with no issues. Problems arise when extremely long heating cycles are used (more than 10 minutes). This is because there is only so much activity in flux chemistries. Expend this activity, and you will have issues. This is due to the fact that flux is used to remove oxides from the surfaces to be bonded. The hotter you get a metal, the faster these oxides form. Once you have expended the activity in a given flux, oxides take over, and nothing bonds well... if at all. That said, toasters and hot-plates are fine as long as you can heat the item(s) to be soldered within a few minutes. 10 minutes is the maximum that I would go on this. Preheat the toaster, and this should be feasible.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:colin
