Step 5Aromatic stages...
-Week 1-2 smells like wet grass.
-Week 3 smells very strongly like raisins.
-Week 4 the tobacco chamber should have the sweet smell of a walk in humidor. The tobacco color should also change to a much darker hue of brown.
-An extra week or two of fermentation beyond the 4th week wouldn't hurt.
this pic is just a couple of late bloomers that iv put in a pot outside if you notice on the dried leaf there is type of mould when cured outside have you had this proble befor or has this happened because its still attached to the plant?
has not been a good year for growing this year but the other plants were about 5ft with broard leafs what was left after the slugs
The cooler method traps in heat, but because the seals are not air tight there seems to be a lot of air exchange going on. In the cooler situation, I am fighting to keep things moist enough...in your case it looked like it was the opposite effect! It was a good shot at it though! And it sounds like you will be able to modify your system for next year!
Just one note! From your pictures, your plants were very immature, their growth stunted mostly due to the small pot size. Remember these are monstrous plants that are supposed to reach 7' tall, if you can provide a minimum 5 gallon pot, lots of full direct sun and water, your plants will flourish! You will also have healthier, more mature/thicker leaves that will respond better to air curing and fermentation...a little more meat to chew so-to-speak.
