Toddler Flintstone Car
Step 4Car Top
Car Top
To make the top I ran a 2x4 through a table saw several times turning it slightly each time. This produced poles that looked like they were whittled from wood. I then cut them to length.
Once the cutting was complete Pebbles and Bambam tested the car to ensure it was the right size and then decided they wanted to help.
After the kids were safely inside I used a hole saw and electric drill to cut openings through the sides. I then mounted the upright poles to the plywood using Gorilla Glue and screws. I took care to mount them securely since they would also serve as the handles to push the car.
I found that any time I needed to screw a part to the sides I could simply drill a hole through the fiberglass coating and re-bondo it once the screws were in place. Due to the roughness of the sides you couldn't tell that I ever touched it.
Once the uprights were in place I added the rest of the pieces using 3" screws and glue. I always drilled pilot holes to ensure the wood would not split. After painting the top wooden parts I lashed them with natural fiber twine. I then glued all knots and other cross joints so the twine could not loosen or unravel.
The cover is cut from white vinyl canvas and is held in place with heavy-duty Velcro strips. The Velcro strips are attached to the vinyl and crossbeams using contact cement giving a seamless look. The Velcro holds the cover tight but it can be easily removed if needed.
3 comments
Sep 26, 2008. 2:04 PMchrisbonheur says:
very cool! Think I'll scale up for my older children. thanks.
Mar 10, 2009. 2:44 AMMerlynswolf says:
bugger the older kids im 30.. ill up scale it for me :D
Nov 3, 2007. 12:42 PMmarkc says:
War Eagle! What an incredible job you did on this. I wish I had your skills!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:lemaster63
My wife is awsome, daughter #1 is married to a fantastic aerospace engineer, daughter #2 won the Montgomery Idol competition and is about to marry a really smart computer guy, and my 20 year old son i...
more »
