Toilet Paper Core Protector and EZ-Roller
  • last photo ←
Ever get a roll of TP that has the inner cardboard core bent so that it doesn't roll? Often when getting the TP home from the store, the inner core is misshaped, so it doesn't roll very well. This causes you to get only a couple sheets at a time, and usually when you really, really need a lot more.
This will show you how to make it roll much easier, and protect the core from getting crushed during use.
Step 1Items needed
Items needed
Toilet paper roll
Saw
PVC pipe
Since the only kind of TP I use is on Mega-rolls, this will refer to that size. A standard size may differ in the inner and outer diameter, so measure before buying the PVC pipe. Since standard rollers don't have the extensions that the mega-rollers do, you could just cut a length of PVC pipe to size and slide it in. Because the mega-rollers have the extensions, you have to cut a piece for each end.
The cardboard core on a mega-roll is 1 5/8 inches in diameter. Get a short length of PVC pipe that has that outer diameter (measure across the circle, from outside edge to outside edge).
5 comments
Dec 31, 2007. 3:54 PMnoahw says:
Why cut rings off of the PVC tube and not just use a section of pipe that runs the entire length of the toilet paper tube? It would actually give the roll some nice momentum (like a flywheel almost), which could help when you are trying to build up some speed for those really really big un-rollings. I love projects that make bathrooms better! Nice work!
Jan 2, 2008. 2:58 PMnoahw says:
WHOA!
I never even knew about extensions at all. I totally see what you are talking about and understand why the rings are necessary. I really support your work!
I've got to go get some of those extenders - my mega rolls fit way too tightly inside of their holders.
See here
Dec 31, 2007. 6:24 PM!Andrew_Modder! says:
lol i cant say this has ever happened to me :-\.
Dec 31, 2007. 3:48 PMGorillazMiko says:
Cool, I hate it when you get those toilet paper rolls all squished.. but I just squish them back super hard. Haha, cool Instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:impulse94
