This will show you how to make it roll much easier, and protect the core from getting crushed during use.
Remove these ads by
Signing UpStep 1Items needed
Saw
PVC pipe
Since the only kind of TP I use is on Mega-rolls, this will refer to that size. A standard size may differ in the inner and outer diameter, so measure before buying the PVC pipe. Since standard rollers don't have the extensions that the mega-rollers do, you could just cut a length of PVC pipe to size and slide it in. Because the mega-rollers have the extensions, you have to cut a piece for each end.
The cardboard core on a mega-roll is 1 5/8 inches in diameter. Get a short length of PVC pipe that has that outer diameter (measure across the circle, from outside edge to outside edge).
I never even knew about extensions at all. I totally see what you are talking about and understand why the rings are necessary. I really support your work!
I've got to go get some of those extenders - my mega rolls fit way too tightly inside of their holders.
See here
