Introduction: Toilet Papering Assistant
Picture of Toilet Papering Assistant
This little thing will easily launch toilet paper nice and high in the air
Right over the tree
It is is a little helping hand when tp'ing
Step 1: Gathering
Picture of Gathering
Materials you will need
1 inch PVC = I used a 16" piece and 8" piece and 4" piece
90 Degree Elbow
Tee
Cap
PVC Primer
PVC Cement
Black Spray Paint
I found the PVC stuff at Home Depot for about 4 dollars
Step 2: Painting
Picture of Painting
Next you should go into the garage
Grab some newspaper and throw it on the ground
lay down the PVC pieces and start painting
Spray down all the pieces black and after about an hour flip them over and paint the other side
After everything is dry this is how it should look
Step 3: Connection
Picture of Connection
The pieces will come together like this
Go into the garage and break out the PVC Cement and Primer
Take the primer and put it on the edges of PVC and then put the cement over it
Push the two pieces together and twist
The cap should never be cemented to anything
just leave it be
Let it dry overnight
Step 4: Tp Time
Picture of Tp Time
Now that everything is together i will show you how it works
Video
invalid movie: http://www.mydeo.com/videorequest.asp?XID=504&CID=190983
You should hold it like this
Enjoy TPing!
imthatguy1125 (author)2009-01-17
how do you use it
Berky93 said it swing your arm upwards towards the target and centrifugal force launches the roll.
joe57005 (author)2008-11-10
I'd make a TP-gun using a low friction roller and compressed air pointed at the roll. ideally, the air will spin the roll and propel the TP. But i would never do this, espectally on a church. (unless it was Jeremiah Wright's church, but i'm too far away)
berky93 (author)2008-11-03
the video is invalid but I'm assuming it works like this: swing your arm upwards towards the target and centrifugal force launches the roll.
The Urban Spaceman (author)2008-11-03
If Prop 102 wins here in Arizona, I am going to use this to hit up some LDS churches.
ve2vfd (author)2008-11-03
Daaaaam! Thats a good idea! I wish I were still young enough to TP someones house now... :-)
johnson_steve (author)ve2vfd2008-11-03
You're never to old for petty vandalism. :)
About This Instructable
2,143views
5favorites
License:
More by littlegandhi1199:Transfer A Halo 3 Map From One Account To Another (Xbox 360)Toilet Papering Assistant
Add instructable to:
