I wanted to use the water pressure in a toilet basin to power a tiny waterfall effect in a zen garden that could grow plants with minimal effort. Since I love plants, but I hate maintenance, this project removes the need to regularly water your garden so long as you regularly flush the toilet. :) If you use plants with a natural perfume, you also eliminate the need for deodorant products for the bathroom, which come in all sorts of nasty formats like aerosol cans and disposable plastic diffusers. This project can be modified to suit your needs or your available materials.
If you enjoy this project, please remember to vote for me for the Epilog Challenge. Thank you!
Here are the materials you will need:
- rectangular planting pot
- rocks for drainage
- plastic tubing
- plants
- decorative rocks
- shallow plastic dish
- aquarium rocks (optional)
- drill
- glue gun
- waterproof (kitchen/bathroom) silicone
When selecting your tubing, you will want to chose a size that will fit snuggly over the tube that supplies the water in your toilet basin.
The concept of this self watering garden is simple. When you flush the toilet, water is added to the container. When a certain amount of water has filed the container, there is an overflow tube which redirects all further water back into the toilet basin. To create this overflow tube, simply drill a hole 1/2 way up the side of the planter with a drill, insert your tube, and seal around the tube with waterproof silicone. Allow 24 hours for the silicone to completely dry and cure. After the 24 hours, test that your overflow tube is properly sealed by running low-pressure tap water into your planter and watch the water overflow from your tube to the sink. If there are no leaks, move on to the next step.
Some sort of diverter might work for us.
Great 'ible.
Occasionally, we need to open up the basin to do some work, and when you do that, you don't want to have to pull apart the whole assembly!
Also, if the water comes to the waterfall and into the plastic container, how does it get to the plants roots? Is the plastic container supposed to overflow into the clay pot?
After that, the water flow would also enhance the smell of any herb in the planter... so this is a very effective design.
very nice.
