This Instructable is an improvement on a prototype like design that I submitted some time ago. See Semi-Automatic Hydroponic Planter/Sprout Grower. There were some inherent "problems" that I believe to have solved in one way or another. The biggest of which was access to the sprouts. This design has a completely removable grow chamber tub for easy filling/dumping/cleaning.
Having run for some time and not getting sick in the least after eating many harvests, I am satisfied that "I" will not succumb to any potential pathogens able to resist the frequent rinsing with chlorinated water. I'm still more worried about the door knob in any office building or coffee shop than "my" bathroom air. I can speak for no one else. I'm also more worried about the store bought, slimy, sulfur smelling, growth stunted sprouts/salads that come "fresh" in a bag.
If that still worries you, this unit could be placed in series with a drip as well. Anywhere, in fact, where there is a sufficient supply of safe water. A leaky tap (which should actually be fixed ya know), rain water, a stream or drip of any kind that can be fed into the top of the unit and supply coverage.
That being said, the new design incorporates a different and more convenient access grow chamber as well as superior, wall mount bracing. You're on your own if it's pretty you're looking for.
Remove these ads by
Signing UpStep 1What You Need
1 ea 2L pop/soda bottle
1 ea 4 inch dia. margarine or yogurt container w/lid
1 ea toilet tank...rest of the toilet optional...
Flexible tubing as req'd to interface with the tank hardware and create a sprinker/shower head inside the "grow chamber". Because I had a variety of tubing, I was able to something up using the following..... 2 ft of 3/8" OD vinyl tubing
4 inches of 1/4" ID x 3/8" OD polyethylene tubing (it's stiff and it melts to itself)
1 inch of 7/16" OD vinyl tubing (cut into 4 O-rings to act as ring clamps)
2 inches of 7/16 " OD vinyl tubing (coupler)
Drill
1/16" and 5/16" Drill bits
Pliers to bend coat hanger as req'd by mere mortals (2 pair)
Side Cutters to cut tubing
Scizzors
The need to flush at least twice a day doesn't hurt either. Actually, it's essential.
Are you sure this is edible?
I didn't understand a word, but the pictures made me all giddy... much like National Geographic magazine when I was a kid. :P
No need to apologize for being a multilingual Italian... I'm a uni-lingual Canadian, and I'm not even good at mastering that. I'm so ashamed.
Has anyone pointed out that the purpose of the water flowing out that little tube when you flush is to go down the overflow tube and refill the bowl; any excess just goes down the drain once the usual 'full' level is attained. There's a similar sink which replaces the toilet lid. Every time you flush, water flows out a small faucet attached to the sink. When the tank is full, the water stops flowing. The difference is the drain tube from the sink goes down the overflow tube. One can wash their hands withOUT turning water on (and touching the handles) at a conventional sink.
I would recommend locating the inverted rinse bottle so most of the water draining off the sprouts goes down the overflow tube to refill the bowl. If there's room enough to reach in there and wash your hands with the sprout rinse water, so much the better! BTW, the vast majority of folks don't let the water at the sink run long enough to get hot enough to make a difference. It just fills the water line with heated water = wasted heat AND wasted water. This is a great idea: using water which is already being used for one or two other things FIRST.
See my ible about building your own growing containers from recycled wood here:
http://www.instructables.com/id/How-to-Build-Your-Own-Growing-Containers/
sail4free
I also agree 110% about the idea not being that "green" minded. I was bored and plotting future LAZINESS!
