Toilet water saver
Toilet water saver
It's easy! Just slap an ol' gallon jug in the tank.
Step 1Get gallon jug
Get gallon jug
Any one will do, then empty it out. If it contains milk you are required to drink the gallon in one hour or this trick won't work.
8 comments
Oct 25, 2010. 11:09 AMturbonut48 says:
Dont use bricks, they break down and can clog your system.
Sand or gravel in bottom of bottle, as mentioned, is best.
Jun 22, 2010. 3:54 PMmadcap3k says:
This can be a good idea on a REALLY old toilet. I'm talking a 4+ gallon flusher. The best thing to do would be to get a newer toilet which uses 1.28 gallons per flush or 1.6 gallons per flush. They will flush better and use less water than a toilet with a milk jug or bricks in it. Make sure you get a good toilet too otherwise you'll be plunging all the time. My toilet uses 1.6 gallons per flush and can flush 18 golf balls in one shot. There is a model designed the same except it uses only 1.28gpf, but it wont do 18 golf balls...
Mar 26, 2008. 7:52 PMtictac24 says:
For step two, if possible, you could submerge the bottle in the water already in the tank. Also, if your toilet isn't quite are big as the one shown, I found that using either 2 litre or 24 oz. bottle will work just as good, though if it floats freely in the tank you must tie it to something like the "pipe" below the filler valve or just have the tie overhang the lip of the tank and have the weight of the lid hold it down. Just stay close by for the first few times you flush, to make sure the bottle doesn't move around too much and/or interfere with anything.
Apr 12, 2009. 10:27 PM2 stroke says:
if u are using 24 oz bottles fill em up with sand or small gravel
May 9, 2008. 3:51 PMmikemmcmeans says:
cool i`m doing this or you could just throw a few bricks or rocks or large chunks of heavy stuff
Oct 31, 2007. 1:40 PMSwartzkip says:
is it me or is that toilet tank massive!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Nardazal
