Tomato, Mozzarella and Basil Sandwich
Introduction: Tomato, Mozzarella and Basil Sandwich
One of my favorite sandwiches of all time is the tomato, mozzarella and basil sandwich. It's simple, doesn't require any cooking, and is really really tasty.
Step 1: Ingredients
A tomato, mozzarella and basil sandwich has the following ingredients:
  • ripe tomatoes
  • fresh mozzarella (this is the soft stuff in liquid - not the hard kind you put on pizza)
  • Italian bread or a baguette
  • fresh basil
  • olive oil
  • balsamic vinegar
  • salt and pepper
Some people like to add in additional elements to this sandwich, like avocado, prosciutto, roasted peppers and more. I like it just fine with the basic ingredients.
Step 2: Slice the Tomatoes and the Mozzarella, and Chiffonade the Basil
The first step is to start slicing the tomatoes and mozzarella. Cut the mozzarella and the tomatoes at roughly the same thickness - about a 1/4". This is a bit thicker than sandwich shops will cut their tomatoes and mozzarella but since I am making it myself I get to cut it how I like it.
Having a sharp knife really helps cut through a soft ripe tomato. If you push too hard you will crush it, so be careful.
I like to cut basil in a chiffonade - which is a fancy way of creating thing uniform strips out of a bunch of leaves like basil, spinach or lettuce. See my instructable on How to Chiffonade for detailed instructions.
But by all means, cut, rip, or chop the basil up any way you like.
Step 3: Assemble the Sandwich
To assemble the sandwich begin to lay your slices of tomato and mozzarella.
I like to lay the tomato down first in a cascade manner where the top of each tomato rests on the bottom of the one above it. I this ensures total tomato coverage and allows me to stack a few more slices than if I just laid them down flat on the bread.
On top of the tomato goes the mozzarella cheese. Again, I like to use a cascading effect to maximize my cheese to area ratio.
After the cheese comes the basil. I like to add in a pretty liberal amount, so what is pictured below might be a bit more than you might like on your sandwich.
Step 4: Seasonings
The sandwich is finished off with some olive oil, balsamic vinegar, salt and pepper.
Put the olive oil and vinegar on first, and then add on the salt and pepper - this way the salt and pepper will stick to the sandwich and wont get "washed away" when you pour on the liquids.
I like the sandwich to be a little wet, which means that it can get a little messy to eat with all the olive oil and vinegar. If your going to be making ahead of time, or need to be able to eat it without making a mess put on less oil and vinegar.
Step 5: Finished Sandwich
Put on the top piece of bread and you are finished with the sandwich.
Modifications/Improvements to the basic sandwich can include:
  • adding your olive oil, vinegar, salt and pepper to your tomatoes and mozzarella before you assemble the sandwich so that the liquids don't make the bread wet and soggy.
  • pre-salting the tomatoes before you assemble once they are sliced. This helps draw some water out of the tomatoes and makes them taste better once the sandwich is assembled.
  • toasting the bread if you like a crunchy sandwich.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    I made this and it was SO good! I made it everyday for lunch in the summer when i had the good supplies! YUM!!!!!!!!!!!
    Second day having this....DELICIOUS!
    Going to have this for lunch tomorrow. Looks delicious. Thanks!
    looks awesome. does someone knows how is "basil" in portuguese ? looks delicious, but by the pictures i could not identify it how is called around here.
    Manjericão is what i know basil to be called in Portuguese. good luck.
    Basil in Portuguese is "alfavaca". Have a look at []...
    I don't know but maybe I can give you a hint. Basil is an herb. You eat the leaves. It tastes sort of sweet and minty, but it's not mint. It is used a lot in Italian food. You can make pesto with it.
    Hi, I made it with the left overs I had from killerjackalope's "Simple Stuffed Peppers" (Sorry the lightning is really bad and I was to lazy to cut the basil ;-))
    OMG. I love this sandwich. A couple suggestions, or at least, the way I do it. Make it kind of like a pressed Cuban. So get a Ciabatta roll to put everything on instead of just loaf bread, light up the grill, set the whole sandwich on there and then wrap a brick in foil and put it on the sandwich. I can't remember how long I put it on for, but I probably flipped it 2-3 minutes in and then left it on another 2 minutes or so. Just to where everything gets warm, ciabatta gets crispy, cheese gets melty. Mmmm... I'm at work, but I think I need to go get a second lunch here soon.
    Made my own with pesto, came out awesome! I recommend some definitely firm tomatoes for this, the softer ones just can't stand up to being handled in a sandwich. Also for some reason my mozzarella fell apart. I am a messy sandwich eater.
