Tomato Tainer Grow HUGE Plants With Little Maintenance!
3,582
58
6
Published
Introduction: Tomato Tainer Grow HUGE Plants With Little Maintenance!
Through years of trial and error, we have found what we feel is the best way to grow Tomatoes, peppers, and many other vegetables with little maintenance, and amazing, consistent results. (we often end up with very productive 8 to 9 foot plants.) What we affectionately call the "tomato Tainer"
To get started, you will need a few tools, and a few materials. Here is the list.
Materials and tools:
6" to 8" U.V. resistant zip ties (Wal mart is a great source.)
A Sharpie, or other permanent marker. (easy to find.)
A small bucket (We get 1.5 gallon empty food grade buckets from Wal Mart's bakery for free)
A 55 gallon food grade barrel (Tree top sells their empty barrels near us for $5.00 each.)
A Electric ( or battery operated) drill, with a 1/4" bit
A skill saw, or other saw to do some surgery on the barrel
A Jig saw
A piece of 1 1/2" PVC (Schedule 40 or thin wall), about 14" long
About a half hour of free time to accomplish the project
Step 1: Cut the Barrel, and Prepare the Bucket.
First, make sure your barrel is washed out, and well rinsed. If there are two lids, remove one.
We cut about the bottom 6" off the barrel, this becomes the base of your tainer.
Next, cut the top 12" off the barrel, this will be your "pot"
Using your drill, drill holes all over the bucket, to allow water to wick into the compost in your plant pot.
Place your bucket (right side up) on top of what was the barrel top in the center, and use your sharpie to mark a line around the bottom of the bucket.
Next, use your jig saw to cut out the circle that you just marked. I suggest cutting about 1/4" outside the line, to make it a little bigger, so your bucket will fit snugly into the bottom of the container when we are done.
Drill holes in the top piece of the barrel around the hole you have made for the bucket, this will allow for aeration to the roots of the plant(s)
Step 2: Mark and Drill Some Holes, and Put Your Tainer Together.
Place the top of the barrel upside down, on the bottom of the barrel we cut off earlier, and make marks on top and botton (lined up, as this is where your zip ties are going to go). The easiest way I have found to keep it lined up is to make your first mark a long one, so that you can line them up easily after drilling your holes.
Mark both top and bottom (Right under the ridge on the "top" of the barrel, angled down to make it easy, and straight in on the bottom section.) These marks should be around 4" to 5" apart. The more zip ties you put in, the stronger it will be).
Drill your holes.
After drilling all the holes, place the top of the barrel (inverted) on the bottom, match up your marks, and start putting zip ties in, DO NOT ZIP THEM DOWN YET! Once all your zipties are in, you can go around and tighten them, tucking the tail into the top hole to keep it looking neat.
Step 3: Add Bucket, and PVC, Fill, and PLANT!
Push your bucket all the way down in the hole, (it will be SNUG). and place the length of PVC into the open bung.
Fill with soil, making sure to pack it down tight as soon as the bucket is full, to keep it from washing out later. Top off your tainer,
I suggest a good top watering before plants go in, and then put the hose into the pipe, and fill until the water overflows out of the zip tie holes.
Now it is time to plant! Tainers accomplish a couple things, for one, your tainers will only need to be filled about once a week, maybe even less in the beginning of the season, by the end of the season, with a inderterminate plant, you may need to fill it every couple days, but that is a small price to pay for a 8 to 9 foot tomato plant!
In addition, tomatoes specifically, do not like their foliage to be watered, so by watering at the root level, you make your plants super happy!
As a side note, the row of tainers in the 2nd to last picture have 8 foot cages, and you can see that the plants are getting close to the tops.
~Happy Gardening!!
Step 4:
3 People Made This Project!
  • Creative Misuse Contest
  • Game Life Contest
    Game Life Contest
  • Oil Contest
    Oil Contest
6 Discussions
Sokota
1 year ago
Hello Suzanne, and thank you for your comment. The bucket ensures that the water reservoir stays clear of soil, to hold a good supply of water. We do top water a little bit here and there, (especially at first, until the little plants get their feet into the ground) after they are well established, there is no need, as the roots will find their way to the water, either though the holes around the bucket, or though the holes in the bucket itself. A 6" net pot could be used as well, the bucket is just more cost effective, being free, and seems to work out really well. I just put in Italian tree tomatoes yesterday, and will be adding photos of their progress over the course of the summer! :)
Hello. Impressive plants. Im missing something though. Why have the buckets? If you are watering from the bottom it seems you would just be vonstricting them by keeping them within bucket walls. Unless you water from the top as well? Directly into the bucket? Thx.
Very well done. I am going to build a few of these. Thanks for sharing!
You are MOST WELCOME! You will not be dissapointed! You should post some end of season pics later this summer. Please vote for me in the contest!
gm280
1 year ago
WOW with that many tomato plants, you are never going to be able to eat all them. Nice project though.
We actually sell Heirloom seeds, do a lot of canning, and dehydrating as well as make tomato wine, so they get put to good use! :) Thank you for taking time to look, and comment!
Kind Regards,
Sokota
