Step 2Ice Chest set up
Bilge pump: It will work in any position so I didn't mount it. Most pumps have a mounting bracket, you can try gluing it to the bottom or side of the chest. It's easier to clean the pump and chest if it's not mounted. My pump has a 3/4" OD, find an adapter to fit yours. The seal does not have to be water tight on the bilge pump.
Connect the wires to the bilge pump wires outside the ice chest. The Rule model pumps are not polarized, but if yours is connect it correctly! If you want to put a switch in line, go for it. You can also wire it to your car's fuse box with a disconnect.
The supply and return tubes are interchangeable. Make the lines long enough to reposition around ice bottles if needed.
Use the nylon ties on the inside to keep the tubes and wires from being pulled out. Not too tight!
Add Comment
