Just about all saws available for less than $100 US have steel bases stamped from relatively thin metal. While in a store, raise the blade as if for a more shallow cut, lock the adjustment nut, and press on the base with your thumb as shown in the photo. On many saws you will see the base deflect. The base is too weak. But, you can strengthen it.
Remove these ads by
Signing UpStep 1Add additional support
The steel piece with the adjustment slot is from 1/8 x 1 inch strap iron about 6 5/8 inches long. The slot was cut with a friend's oxy-acetylene cutting torch. (Grind away any bumps left by molten metal.) The slot needs to be long enough to cover the full range of adjustment possible on your saw from the lowest motor position to the highest, from a fully vertical blade setting to a full 45 degree bevel, and with any combination of both.
The slot could also be cut with a hacksaw (after drilling a couple of holes next to one another to make an opening for inserting the blade and then re-attaching the blade in the hacksaw frame). A cutting wheel on an angle head grinder could also be used, although it is easy to wander off of the desired line with an angle head grinder.
I have a B&D with the same problem since 25 years and I barely use it since I have other equipment as well.
now I I can fix this cheap circular saw (actually the 1st electric equipment I ever bought) and use it for again ...
