Tool Rack - Swing Away
8,491
51
4
Posted
Introduction: Tool Rack - Swing Away
Making do in a less than perfect garage of a rental house, I am always short of order and space for my tools, so over the years i have tried various versions of swing away tool racks, but always been stumped by how to pivot them with out spending a fortune in hinges.
The other day while doing something far and removed from working in my shed ( yeah i can multi task it seems!) I figured out how to do it....
What you need:
Length of 2 x 4 framing timber
Length of timber ( timber to cut your edges from - i split cheap 1.5 planks with band saw.)
"head set" bolt from a bicycle ( thats the one in the centre of the handle bar stem)
Hack saw
Vice
Drill and bits
Clamps
Wood Glue
Wood screws
Pen
Combination square / square
Ruler
Saw
What its very useful to have;
Band saw
Drill press
Sander
Skill saw
Step 1: Construct the Back Board
I made my back board about 50 - 60cm across ( later ones varying depending on the tools to be placed) and about 60 - 70cm long to match the position of a rafter in the garage.
After marking these dimensions up on a sheet of 7mm ply, i cut it out with the skill saw and squared up the edges on the jointer.
Using the band saw (luxury) i split some cheap form wood (cheap rough swan timber)- in too 3cm x 2cm wide strips, placing the first two the fully length of the back board,(See picture 2 (e) and (b)) clamping and gluing with wood glue over night.
Next i did the same with the two shorter end lengths (picture 2 (a) and (c)) these being butt jointed between the first too. (see picture 3)
Step 2: Find Corner Centres.
Now that you have your basic back board all edged and glued, turn it on its side on the bench with the side up at the end that you desire to be the top.
Using your square with the blade parallel to the inner edge of (c) and 90 degrees across the edge of (b) as shown in picture 4 - scribe a line. (black line)
You have formed a square between the black line and the end of the long edge.
Now split this sqaure by drawing in the two diagonals (green lines in picture 5) from each corner of the square
The intersection of the green lines is the drilling centre for the hinge pin.
Repeat the process for the opposite edge in picture 2(e)
Step 3: Hinge Pin
Take your head set bolt, these two are about 18cm long and 1cm thick, match the appropriate drill bit to it so that its tight but doesn't split the wood when you force it in....
This is where a drill press is the best option, so that you can drill a hole that is exactly 90 degrees to the timber..... ( good luck if you are using a power drill..)
Place the bottom edge in a drill vice to keep it the edge 90 degrees to the drill (see picture 6)
Now using the center you made in the last step, (picture 7) drill about quarter the length of your head set bolt or the length of the drill bit which come first... on each side.
Then prepare the bolt;
Place the head set bolt in a vice and first cut the head off, then cut it in halve.(Picture 8)
Now place each halve in the holes that you have drilled and tap in to place (see picture 9)
Step 4: Hinge Bearers
First I figured out where i was going to attach the board - this governs the length of the bearers, then i cut the right shapes to fit (see picture - 10 ) this is entirely personal to your needs.
In my case the framing of the garage is small (cheap) and i have no desire to pepper it with holes, so i figured a method of clamping it between the top plate and roof - ( picture 11 for your interest)
Once you have figured out how far out from the wall you want your board, add at least 10cm to this and round off the ends (see picture 12 (2)) (best done held together on a band saw so they are the same.)
Then place your bearers up in position and mark with a notation representing the inner most face( the edge facing the other) and clamp them so the inside faces are outer most.( see picture 12)
Using a fine drill,P (say 3mm) drill a pilot hole at your required centre - right through the upper most bearer in to the one below.(picture 13)
Un clamp them, and put the top one aside, and continue to drill the pilot hole right through the bottom one on its own. ( picture 14)
You now have matching centres.
Step 5: Hinge Pin Holes - Bearers
Now match a drill bit to the thickness of your hinge pin bold (set in the board edges) so that it will rotate with ease.
Place the drill bit in the drill press and place each bearer with the inside face up individually on the drill table. Adjust your drill press depth so that the bit at full depth doesn't exceed halve the thickness of your bearer ( see picture 15)
Now drill each hole - (being careful to do so only in the inside face - so that when the bearers are placed in their positions to mount the two holes are facing each other) ( picture 16)
Fix the first bearer in position by what ever method you are using, then take the back board, push the hinge pin in to the hole on the first bearer,(picture 17) place the second bearer hole over the opposite hinge pin, and then place and secure the bearer in place...(picture 17 a)
Step 6: Fit Out
Now fit out your tool racks to fit with in the profile of the back board edges.(picture 1)
The next step that I haven't completed yet is to set the roof attachments.
in a past version i simple fixed a length of bicycle chain to the rafter above were the bottom end will swing up and a large screw with the head removed in the back board. which i just hooked in to the chain.
or you could fix a little pulley in the roof and have a string that you pull it up with and then tie off.....
Pictures to come when i compete this step.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
4 Comments
Neat. I'm planning something similar for my workshop.
great - be great to see when your done.. the ways people solve problems is great
Wouldn't using simple door hinges also work? I have those, but no spare bike parts.
yes indeed it would be - however in that shed i wasn't able to drill holes to attach hinges - nor did i have any - so i made the clamp/ hinge system instead:-)
